06-03-2015 10:53 AM
I have been asked to use Cacti to graph IPv6 counters on our AS9K interfaces running XR 5.1.3.
Is there a corresponding SNMP OID for the IPV6_UNICAST counter shown here or from the "show monitor" commands?
RP/0/RSP0/CPU0:ios#show interfaces te0/0/0/4 accounting rates Wed Jun 3 10:33:39.495 CDT TenGigE0/0/0/4 Ingress Egress Protocol Bits/sec Pkts/sec Bits/sec Pkts/sec IPV4_UNICAST 1862641000 165296 229371000 155620 IPV4_MULTICAST 0 0 0 0 IPV6_UNICAST 366815000 36364 2934000 2738 IPV6_MULTICAST 12000 21 0 0 ARP 16000 35 0 0 IPV6_ND 13000 20 0 1
I found these in some other posts but no success yet:
Solved! Go to Solution.
06-03-2015 11:06 AM
Jamie,
nms-server2:~ % snmpwalk -v 2c -c public 172.18.87.48 1.3.6.1.2.1.4.31.3.1
IP-MIB::ipIfStatsHCInReceives.ipv6.27 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.27 = Counter64: 0
IP-MIB::ipIfStatsHCOutTransmits.ipv6.27 = Counter64: 0
IP-MIB::ipIfStatsHCOutOctets.ipv6.27 = Counter64: 0
IP-MIB::ipIfStatsHCInMcastPkts.ipv6.27 = Counter64: 0
IP-MIB::ipIfStatsHCInMcastOctets.ipv6.27 = Counter64: 0
IP-MIB::ipIfStatsHCOutMcastPkts.ipv6.27 = Counter64: 0
IP-MIB::ipIfStatsHCOutMcastOctets.ipv6.27 = Counter64: 0
Eddie.
06-03-2015 11:06 AM
Jamie,
Eddie.
06-03-2015 11:21 AM
Thanks very much for the response. To take this another step further, I do receive similar results.
$ snmpwalk -v 2c -c public 192.168.1.1 1.3.6.1.2.1.4.31.3.1.6
IP-MIB::ipIfStatsHCInOctets.ipv6.5 = Counter64: 5507656796
IP-MIB::ipIfStatsHCInOctets.ipv6.53 = Counter64: 2889781036972
IP-MIB::ipIfStatsHCInOctets.ipv6.68 = Counter64: 33395567336320
However, I get this when I try to poll one of the specific instances/interfaces so I can graph the specific counter;
$ snmpwalk -v 2c -c public 192.168.1.1 1.3.6.1.2.1.4.31.3.1.6.68
IP-MIB::ipIfStatsHCInOctets.ipv6.5 = Counter64: 5507660887
Error: OID not increasing: IP-MIB::ipIfStatsHCInOctets.68
>= IP-MIB::ipIfStatsHCInOctets.ipv6.5
Is that not the correct OID for the specific interface counter?
Thanks again!
Jamie
06-03-2015 01:15 PM
This worked for me. 68 is the interface ifindex.
$ snmpwalk -v 2c -c public 192.168.1.1 1.3.6.1.2.1.4.31.3.1.6.ipv6.68
IP-MIB::ipIfStatsHCInOctets.ipv6.68 = Counter64: 33411092662585
$ snmpwalk -v 2c -c public 192.168.1.1 1.3.6.1.2.1.4.31.3.1.5.ipv6.68
IP-MIB::ipIfStatsInOctets.ipv6.68 = Counter32: 767076210
The Cacti graphs are working.
Thanks again!
Jamie
12-04-2015 12:21 PM
Hi am doing the same but cacti is nor graphing. Did you try by index query?
Your reply will be helpful.
Pradeep
12-06-2015 01:19 PM
This is the cheat sheet I use to create the Cacti IPv6 graphs. Please try this and let me know if you have any problems. Good Luck!!
Cacti IPv6 Graphing
RP/0/RSP0/CPU0:router#show snmp interface Te0/0/0/0 ifindex
Tue Aug 11 04:49:05.353 CDT
ifName : TenGigE0/0/0/0 ifIndex : 279
CACTI
Create the IPv6 IN data source
Cacti –> Console -> Data Sources -> ADD
Template = SNMP-Generic OID Template
Host -> router
CREATE
Name: router Te0/0/0/0 - IN
Maximum Value: 100000000000
Data Source Type: COUNTER
OID: 1.3.6.1.2.1.4.31.3.1.6.2.279 (279 is the SNMP interface index)
SAVE
Create the IPv6 OUT data source
Host -> router
CREATE
Name: router Te0/0/0/0 - OUT
OID: 1.3.6.1.2.1.4.31.3.1.33.2.279 (279 is the SNMP interface index)
SAVE
Create the IPv6 Traffic Graph
Cacti->Console->Graph Management->ADD
Template = SNMP-IPv6 Traffic Graph Template
Host -> router
CREATE
Title: router Te0/0/0/0
Vertical Label: Bits Per Second
Data Source IN: router Te0/0/0/0 – IN (snmp_oid)
Data Source OUT: router Te0/0/0/0 – OUT (snmp_oid)
SAVE
12-22-2015 04:32 AM
Your procedure worked great. Thanks for the information. I wonder why my xml file for index query doesn't work . As per your procedure I can graph for each specific interface. But with my xml file if I did index query i was expecting to graph whatever interface i select but its not. Still am not getting that point. have you experienced the same?
12-22-2015 12:48 PM
I also tried xml but could not get it to work. I am not an xml expert. I'm not sure if it was a problem with xml or just my lack of knowledge to build it correctly. Glad the cheat sheet worked for you!
12-22-2015 12:55 PM
Yes your cheat code saved my life. Thanks a lot
01-05-2016 04:44 AM
Jamie/Jschmied,
The cheat code you have suggested cannot be implemented globally rite? what am trying is creating a template for ipv6 graph. Using snmp index query if we use that template to whatever interface we select it should start graphing. As per your cheat code I can graph it by entering oid of each interface manually. The reason I keep focusing on snmp index query is we have hundreds of interfaces where IPV6 traffic pass through. Creating datasource for inbound/outbound traffic of each interface seems consumption of load and time in my case. Do you have any idea for that?
Pradeep
01-05-2016 06:07 AM
You are correct. The process is manual and would not be efficient if you have a great number of interfaces to graph. In my case, we were only interested in graphing IPv6 traffic at our up and downstream interfaces which added up to 20-25 interfaces total. Unfortunately, I do not have insight into programming Cacti to accomplish this feat. I would be interested in knowing how to do it too.
01-28-2016 05:05 AM
Jamie,
I finally found how to make query. Before that i need to see your xml file for graphing ipv6 counter.Or you can tell what oid you have configured in xml
01-28-2016 06:31 AM
Pradeep,
That is great news! This is the XML. I tried several variations of the OID. It did not work but maybe you can tell me what I did wrong.
<?xml version="1.0"?>
-<interface>
<name>Get Cisco IPv6 Traffic Counter (64-bit)</name>
<description>Queries a Cisco IOS-XR router for IPv6 64-bit Traffic Counter</description>
<oid_index>.1.3.6.1.2.1.4.31.3.1.6.2</oid_index>
-<fields>
-<ipIfStatsInOctets.ipv6Index>
<name>Index</name>
<method>walk</method>
<source>value</source>
<direction>input</direction>
<oid>.1.3.6.1.2.1.4.31.3.1.6.2</oid>
</ipIfStatsInOctets.ipv6Index>
-<ipIfStatsOutOctets.ipv6Index>
<name>Index</name>
<oid>.1.3.6.1.2.1.4.31.3.1.33.2</oid>
</ipIfStatsOutOctets.ipv6Index>
</fields>
</interface>
Thanks!
Jamie
01-28-2016 06:34 AM
Use below code and let me know what happens
<ipIfStatsHCInOctets>
<name>Bytes In - 64-bit Counters IPV6</name>
<direction>output</direction>
<oid>IP-MIB::ipIfStatsHCInOctets.ipv6</oid>
</ipIfStatsHCInOctets>
<ipIfStatsHCOutOctets>
<name>Bytes Out - 64-bit Counters IPV6</name>
<oid>IP-MIB::ipIfStatsHCOutOctets.ipv6</oid>
</ipIfStatsHCOutOctets>
12-28-2015 12:27 PM
Jamie: "The template "SNMP-IPv6 Traffic Graph Template" was created?, but i don´t found the template in the Cacti.
Erick
