08-12-2022 12:53 PM - edited 08-12-2022 01:01 PM
System:
(2)CE: Cisco IOS running eBGP advertising two loopback networks (To represent customer subnets) advertises loopback10 and loopback11, using 192.168 subnets.
(2)PE: Cisco vXR running eBGP to CE routers, connects to P / RR network and advertises MPLS labels via BGP-LU off RR.
CE01(AS65011) CE02 (AS65011)
PE01 (AS65000) PE02 (AS 65000)
\ -- P network (AS 65001) -- /
RR network (AS 65000)
Here is bgp config of two CE routers BGP configurations
CustA-CE-1:
CustA-CE-1#show run | s router
router bgp 65011
bgp router-id interface Loopback0
bgp log-neighbor-changes
network 192.168.111.0 mask 255.255.255.128
network 192.168.111.128 mask 255.255.255.128
neighbor 10.11.1.1 remote-as 65000
CustA-CE-2:
CustA-CE-2#show run | s router
router bgp 65011
network 192.168.112.0 mask 255.255.255.128
network 192.168.112.128 mask 255.255.255.128
neighbor 10.11.2.1 remote-as 65000
There are two separate PE routers they connect to. Here are their configurations:
RP/0/RP0/CPU0:PE01#show run vrf
Fri Aug 12 19:30:02.564 UTC
vrf CustA-CE-1
vpn id 65011:11
address-family ipv4 unicast
import route-target
65011:11
export route-target
65011:11
vrf CustB-CE-2
vpn id 65013:13
import route-target
65013:13
export route-target
65013:13
RP/0/RP0/CPU0:PE01#show run router bgp
router bgp 65000
timers bgp 30 90
bgp router-id 7.7.7.7
mpls activate
interface GigabitEthernet0/0/0/3
interface GigabitEthernet0/0/0/5
bgp graceful-restart
bgp bestpath compare-routerid
ibgp policy out enforce-modifications
maximum-paths ebgp 6 selective
maximum-paths ibgp 2 selective
redistribute connected route-policy SET_REDIST_CONNECTED_V4
allocate-label route-policy SET_BGP_LABEL_ALLOCATION_V4
address-family vpnv4 unicast
address-family ipv4 flowspec
neighbor-group CustA
remote-as 65011
route-policy CE-PASS in
route-policy CE-PASS out
neighbor-group CustB
remote-as 65013
vrf CustA-CE-1
rd 65011:11
neighbor 10.11.1.2
use neighbor-group CustA
vrf CustB-CE-2
rd 65013:13
neighbor 10.13.2.2
use neighbor-group CustB
And PE02
RP/0/RP0/CPU0:PE02#show run vrf
Fri Aug 12 19:34:23.804 UTC
vrf CustA-CE-2
vpn id 65011:11
import route-target
65011:11
export route-target
65011:11
vrf CustB-CE-1
vpn id 65013:13
import route-target
65013:13
export route-target
65013:13
RP/0/RP0/CPU0:PE02#show run router bgp
Fri Aug 12 19:34:56.802 UTC
router bgp 65000
timers bgp 30 90
bgp router-id 9.9.9.9
mpls activate
remote-as 65011
remote-as 65013
vrf CustA-CE-2
rd 65011:11
neighbor 10.11.2.2
vrf CustB-CE-1
rd 65013:13
neighbor 10.13.1.2
NOTE: There are much more configurations in these systems but I just wanted to share the PE <-> CE legs. There is also a VRF for CustB networks but I did not share that here as its the same problem. the PE router config is slimmed down, there are many routing-policies, and neighbors to the P and RR systems, I just did not include them.
Here is the interesting part. If I check the vrf routes I can see the subnets populating that the CE networks are being advertised. This is what shows up on PE01:
RP/0/RP0/CPU0:PE01#show bgp vrf all
Fri Aug 12 19:38:10.372 UTC
VRF: CustA-CE-1
BGP VRF CustA-CE-1, state: Active
BGP Route Distinguisher: 65011:11
VRF ID: 0x60000001
BGP router identifier 7.7.7.7, local AS number 65000
Non-stop routing is enabled
BGP table state: Active
Table ID: 0xe0000001 RD version: 66
BGP main routing table version 69
BGP NSR Initial initsync version 7 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 65011:11 (default for vrf CustA-CE-1)
*> 10.11.1.0/30 0.0.0.0 0 32768 ?
*>i10.11.2.0/30 9.9.9.109 0 100 0 ?
*> 192.168.111.0/25 10.11.1.2 0 0 65011 i
*> 192.168.111.128/25 10.11.1.2 0 0 65011 i
*>i192.168.112.0/25 9.9.9.109 0 100 0 65011 i
*>i192.168.112.128/25 9.9.9.109 0 100 0 65011 i
Processed 6 prefixes, 6 paths
VRF: CustB-CE-2
BGP VRF CustB-CE-2, state: Active
BGP Route Distinguisher: 65013:13
VRF ID: 0x60000002
Table ID: 0xe0000002 RD version: 69
Route Distinguisher: 65013:13 (default for vrf CustB-CE-2)
*>i10.13.1.0/30 9.9.9.109 0 100 0 ?
*> 10.13.2.0/30 0.0.0.0 0 32768 ?
*>i192.168.131.0/25 9.9.9.109 0 100 0 65013 i
*>i192.168.131.128/25 9.9.9.109 0 100 0 65013 i
*> 192.168.132.0/25 10.13.2.2 0 0 65013 i
*> 192.168.132.128/25 10.13.2.2 0 0 65013 i
And on PE02
RP/0/RP0/CPU0:PE02#show bgp vrf all
Fri Aug 12 19:38:48.061 UTC
VRF: CustA-CE-2
BGP VRF CustA-CE-2, state: Active
VRF ID: 0x60000001
BGP router identifier 9.9.9.9, local AS number 65000
Table ID: 0xe0000001 RD version: 60
BGP main routing table version 63
BGP NSR Initial initsync version 19 (Reached)
Route Distinguisher: 65011:11 (default for vrf CustA-CE-2)
*>i10.11.1.0/30 7.7.7.107 0 100 0 ?
*> 10.11.2.0/30 0.0.0.0 0 32768 ?
*>i192.168.111.0/25 7.7.7.107 0 100 0 65011 i
*>i192.168.111.128/25 7.7.7.107 0 100 0 65011 i
*> 192.168.112.0/25 10.11.2.2 0 0 65011 i
*> 192.168.112.128/25 10.11.2.2 0 0 65011 i
VRF: CustB-CE-1
BGP VRF CustB-CE-1, state: Active
VRF ID: 0x60000002
Table ID: 0xe0000002 RD version: 63
Route Distinguisher: 65013:13 (default for vrf CustB-CE-1)
*> 10.13.1.0/30 0.0.0.0 0 32768 ?
*>i10.13.2.0/30 7.7.7.107 0 100 0 ?
*> 192.168.131.0/25 10.13.1.2 0 0 65013 i
*> 192.168.131.128/25 10.13.1.2 0 0 65013 i
*>i192.168.132.0/25 7.7.7.107 0 100 0 65013 i
*>i192.168.132.128/25 7.7.7.107 0 100 0 65013 i
So I know MPLS is forwarding correctly ( I think ).
But when I check the routes on the CE, only the transit route appears for the other CE.
CustA-ce-01:
CustA-CE-1(config-router)#do show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 10.11.1.0/30 is directly connected, Ethernet1/0
L 10.11.1.2/32 is directly connected, Ethernet1/0
B 10.11.2.0/30 [20/0] via 10.11.1.1, 00:57:15
11.0.0.0/32 is subnetted, 1 subnets
C 11.11.11.11 is directly connected, Loopback0
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/24 is directly connected, Ethernet0/0
L 192.168.0.131/32 is directly connected, Ethernet0/0
192.168.111.0/24 is variably subnetted, 4 subnets, 2 masks
C 192.168.111.0/25 is directly connected, Loopback10
L 192.168.111.1/32 is directly connected, Loopback10
C 192.168.111.128/25 is directly connected, Loopback11
L 192.168.111.129/32 is directly connected, Loopback11
And CustA-ce-02
CustA-CE-2#show ip route
B 10.11.1.0/30 [20/0] via 10.11.2.1, 00:49:49
C 10.11.2.0/30 is directly connected, Ethernet1/0
L 10.11.2.2/32 is directly connected, Ethernet1/0
12.0.0.0/32 is subnetted, 1 subnets
C 12.12.12.12 is directly connected, Loopback0
L 192.168.0.132/32 is directly connected, Ethernet0/0
192.168.112.0/24 is variably subnetted, 4 subnets, 2 masks
C 192.168.112.0/25 is directly connected, Loopback10
L 192.168.112.1/32 is directly connected, Loopback10
C 192.168.112.128/25 is directly connected, Loopback11
L 192.168.112.129/32 is directly connected, Loopback11
So If I check the PE advertised routes, thats exactly what I see, only the transit route is being advertised to CE's
PE01
RP/0/RP0/CPU0:PE01#show bgp vrf CustA-CE-1 advertised
Fri Aug 12 19:41:28.266 UTC
10.11.1.0/30 is advertised to 10.11.1.2
Path info:
neighbor: Local neighbor router id: 7.7.7.7
valid redistributed best import-candidate
Received Path ID 0, Local Path ID 1, version 26
Attributes after inbound policy was applied:
next hop: 0.0.0.0
MET ORG AS EXTCOMM
origin: incomplete metric: 0
aspath:
extended community: RT:65011:11
Attributes after outbound policy was applied:
next hop: 10.11.1.1
MET ORG AS
aspath: 65000
10.11.2.0/30 is advertised to 10.11.1.2
Path info:
neighbor: 5.5.5.5 neighbor router id: 9.9.9.9
valid internal best import-candidate imported
Received Path ID 0, Local Path ID 1, version 64
next hop: 9.9.9.109
MET ORG AS LOCAL EXTCOMM
origin: incomplete metric: 0 local pref: 100
aspath:
originator: 9.9.9.9 cluster list: 5.5.5.5
next hop: 10.11.1.1
ORG AS LOCAL
origin: incomplete local pref: 100
aspath: 65000
PE02:
RP/0/RP0/CPU0:PE02#show bgp vrf CustA-CE-2 advertised
Fri Aug 12 19:42:09.464 UTC
10.11.1.0/30 is advertised to 10.11.2.2
Path info:
neighbor: 5.5.5.5 neighbor router id: 7.7.7.7
Received Path ID 0, Local Path ID 1, version 58
next hop: 7.7.7.107
aspath:
originator: 7.7.7.7 cluster list: 5.5.5.5
next hop: 10.11.2.1
ORG AS LOCAL
aspath: 65000
10.11.2.0/30 is advertised to 10.11.2.2
Path info:
neighbor: Local neighbor router id: 9.9.9.9
Received Path ID 0, Local Path ID 1, version 14
next hop: 0.0.0.0
MET ORG AS EXTCOMM
aspath:
next hop: 10.11.2.1
MET ORG AS
aspath: 65000
Why are none of advertised CE network routes being forwarded to the other CE's in the vrf?
I am being conservative with my configurations as there are many, also the P and RR are Juniper vMX systems. If you need to know anything about them let me know, however I have a feeling this is a CE <-> PE configuration issue.
Solved! Go to Solution.
08-12-2022 06:08 PM
HI @davehouser1 ,
Since both CEs are configured with the same ASN (65011), you need to configure the following on the PE01 and PE02 to allow the updates to be accepted on the CEs.
as-override
08-12-2022 01:46 PM
Hi @davehouser1 ,
I do not see any BGP neighbor sessions with address-family vpnv4 unicast in your configuration. Can you confirm that you configured VPNv4? Also, can you please confirm what you are trying to achieve. If I understand you correctly, you want to run L3VPN without using LDP, right?
08-12-2022 02:13 PM
@Harold Ritter
That is correct, I am using BGP-LU to distribute labels, and using a RR with vpnv4 to reflect those routes.
Here is the vpnv4 unicast neighbor connection to the vpnv4 enabled RR. I am using iBGP to connect to it via the PE's Loopback0 address.
Note:
5.5.5.5 = vpnv4 RR
6.6.6.6 = a separate unicast RR
PE01:
RP/0/RP0/CPU0:PE01#show bgp vpnv4 unicast neighbors brief
Neighbor Spk AS Description Up/Down NBRState
5.5.5.5 0 65000 02:17:07 Established
RP/0/RP0/CPU0:PE01#show bgp summary
Fri Aug 12 21:08:01.298 UTC
BGP generic scan interval 60 secs
Table ID: 0xe0000000 RD version: 480
BGP main routing table version 480
BGP NSR Initial initsync version 11 (Reached)
BGP scan interval 60 secs
BGP is operating in STANDALONE mode.
Process RcvTblVer bRIB/RIB LabelVer ImportVer SendTblVer StandbyVer
Speaker 480 480 480 480 480 0
Neighbor Spk AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down St/PfxRcd
6.6.6.6 0 65000 2509 2809 480 0 0 02:17:48 3
10.17.101.0 0 65001 5193 5522 480 0 0 01:58:01 3
10.17.201.0 0 65001 6037 5548 480 0 0 01:58:01 3
PE02:
Fri Aug 12 21:07:52.881 UTC
5.5.5.5 0 65000 03:29:09 Established
RP/0/RP0/CPU0:PE02#show bgp summary
Fri Aug 12 21:07:56.005 UTC
Table ID: 0xe0000000 RD version: 170
BGP main routing table version 170
Speaker 170 170 170 170 170 0
6.6.6.6 0 65000 1155 1291 170 0 0 03:29:19 3
10.17.102.0 0 65001 2250 2394 170 0 0 01:41:09 3
10.17.202.0 0 65001 2616 2407 170 0 0 01:41:24 3
I should have mentioned but I am new to all of this. I am trying to teach myself RR + BGP-LU + MPLS + VRF RD / RI / RE, SO I am sorry if I maybe asking questions that are obvious. I appreciate your patience and help through my learning!
08-12-2022 03:09 PM - edited 08-12-2022 06:28 PM
I know little about the IOS XR but the next-hop for prefix is not change and hence the the BGP NOT validate prefix and not install in RIB,
the next-hop must not change it must be the CE-PE connection IP not the router-ID of PE.
sorry for my little info.
08-12-2022 06:08 PM
HI @davehouser1 ,
as-override
08-13-2022 07:18 AM
@Harold Ritter That worked! I can now see the advertised networks per VRF routes in the CE's. I am getting closer
However, pinging from CustA-ce-01 to CustA-ce-02 on the CustA vrf does not work (Same for CustB), it seems the icmp packet stops at the PE and goes no further. I may need to open a new ticket on this, not sure if you recommend anything I can try to figure out why they cannot ping?
@MHM Cisco World I am not clear on what you mean when saying this:
Based on your statement, what should the IP be for the next hop be? Example, currently, you are right, the next hop listed on PE01 is 9.9.9.109, which is secondary Loopback address on PE02. But it is not the primary ID of that router. Performing a show route on the PE01 I see the following:
RP/0/RP0/CPU0:PE01#show route 9.9.9.109
Sat Aug 13 14:11:01.103 UTC
Routing entry for 9.9.9.109/32
Known via "bgp 65000", distance 20, metric 10, [ei]-bgp, labeled unicast (3107) (AIGP metric)
Tag 65001, type external
Installed Aug 13 13:47:05.770 for 00:23:55
Routing Descriptor Blocks
10.18.101.0, from 10.18.101.0, BGP external
Route metric is 10
No advertising protos.
However when I try to ping 9.9.9.109 from PE01, I get no response. I did a capture on the line to 10.18.101.0/31, but no ICMP pings show to 9.9.9.109.
Feel like I am missing more here. Not sure if simple fix or some other issue possibly in my RR.
08-13-2022 07:52 AM - edited 08-13-2022 08:26 AM
Hi @davehouser1 ,
Great, it sound like the control plane is now working.
I presume that you only advertise the secondary loopback IP addresses via BGP-LU. So when you ping 9.9.9.109 from PE01, you should specify the source as the secondary loopback. If it still doesn't work it means you have and issue with your data plane. You could also try the following command to verify you MPLS data plane between PE01 and PE02:
ping mpls ipv4 9.9.9.109/32 source <secondary loopback interface IP address>
Please provide the following:
"show mpls int" on all routers from PE01 to PE02 and make sure all interfaces are MPLS enabled
"show cef 9.9.9.109/32" from PE01?
"show run router bgp" from PE01
"show runs router static" from PE01
08-13-2022 08:18 AM - edited 08-13-2022 08:20 AM
@Harold Ritter thanks for the tips. Here is the output from the mpls ping (All "Q"s)
RP/0/RP0/CPU0:PE01#show ip int br | i Loopback
Sat Aug 13 15:10:32.790 UTC
Loopback0 7.7.7.7 Up Up default
Loopback10 7.7.7.107 Up Up default
RP/0/RP0/CPU0:PE01#ping mpls ipv4 9.9.9.109/32 source 7.7.7.107
Sat Aug 13 14:59:16.246 UTC
Sending 5, 100-byte MPLS Echos to 9.9.9.109/32,
timeout is 2 seconds, send interval is 0 msec:
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
'L' - labeled output interface, 'B' - unlabeled output interface,
'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
'M' - malformed request, 'm' - unsupported tlvs, 'N' - no rx label,
'P' - no rx intf label prot, 'p' - premature termination of LSP,
'R' - transit router, 'I' - unknown upstream index,
'X' - unknown return code, 'x' - return code 0
QQQQQ
Success rate is 0 percent (0/5)
I read another post where you commented that "Q"s are caused because the entry is not in the the RIB,FIB,LIB, or LFIB
Here are the entries in each, however I do see 9.9.9.109 in each.
RP/0/RP0/CPU0:PE01#show rib tables
Sat Aug 13 15:05:21.006 UTC
Codes: N - Prefix Limit Notified, F - Forward Referenced
D - Table Deleted, C - Table Reached Convergence
VRF/Table SAFI Table ID PrfxLmt PrfxCnt TblVersion N F D C
default/default uni 0xe0000000 10000000 17 439 N N N Y
CustA-CE-1/default uni 0xe0000001 10000000 7 165 N N N Y
CustB-CE-2/default uni 0xe0000002 10000000 7 165 N N N Y
**iid/default uni 0xe0003fff 10000000 0 0 N N N Y
default/default multi 0xe0100000 10000000 0 0 N N N Y
RP/0/RP0/CPU0:PE01#show ip route
Sat Aug 13 15:16:31.569 UTC
Codes: C - connected, S - static, R - RIP, B - BGP, (>) - Diversion path
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
U - per-user static route, o - ODR, L - local, G - DAGR, l - LISP
A - access/subscriber, a - Application route
M - mobile route, r - RPL, t - Traffic Engineering, (!) - FRR Backup path
B 5.5.5.5/32 [20/10] via 10.17.101.0, 00:12:23
B 6.6.6.6/32 [20/10] via 10.17.101.0, 00:12:23
L 7.7.7.7/32 is directly connected, 06:33:31, Loopback0
L 7.7.7.107/32 is directly connected, 06:33:31, Loopback10
B 9.9.9.9/32 [20/10] via 10.17.101.0, 00:12:23
B 9.9.9.109/32 [20/10] via 10.18.101.0, 00:12:51
C 10.17.101.0/31 is directly connected, 00:12:53, GigabitEthernet0/0/0/2
L 10.17.101.1/32 is directly connected, 00:12:53, GigabitEthernet0/0/0/2
C 10.17.201.0/31 is directly connected, 00:12:53, GigabitEthernet0/0/0/4
L 10.17.201.1/32 is directly connected, 00:12:53, GigabitEthernet0/0/0/4
C 10.18.101.0/31 is directly connected, 00:12:53, GigabitEthernet0/0/0/3
L 10.18.101.1/32 is directly connected, 00:12:53, GigabitEthernet0/0/0/3
C 10.18.201.0/31 is directly connected, 00:12:53, GigabitEthernet0/0/0/5
L 10.18.201.1/32 is directly connected, 00:12:53, GigabitEthernet0/0/0/5
L 127.0.0.0/8 [0/0] via 0.0.0.0, 06:33:33
C 192.168.0.0/24 is directly connected, 06:33:30, MgmtEth0/RP0/CPU0/0
L 192.168.0.127/32 is directly connected, 06:33:30, MgmtEth0/RP0/CPU0/0
RP/0/RP0/CPU0:PE01#show ip cef
Sat Aug 13 15:05:54.317 UTC
Prefix Next Hop Interface
0.0.0.0/0 drop default handler
0.0.0.0/32 broadcast
5.5.5.5/32 10.17.101.0/32 <recursive>
6.6.6.6/32 10.17.101.0/32 <recursive>
7.7.7.7/32 receive Loopback0
7.7.7.107/32 receive Loopback10
9.9.9.9/32 10.17.101.0/32 <recursive>
9.9.9.109/32 10.18.101.0/32 (?) <recursive>
10.17.101.0/31 attached GigabitEthernet0/0/0/2
10.17.101.0/32 10.17.101.0/32 GigabitEthernet0/0/0/2
10.17.101.1/32 receive GigabitEthernet0/0/0/2
10.17.201.0/31 attached GigabitEthernet0/0/0/4
10.17.201.1/32 receive GigabitEthernet0/0/0/4
10.18.101.0/31 attached GigabitEthernet0/0/0/3
10.18.101.0/32 10.18.101.0/32 GigabitEthernet0/0/0/3
10.18.101.1/32 receive GigabitEthernet0/0/0/3
10.18.201.0/31 attached GigabitEthernet0/0/0/5
10.18.201.1/32 receive GigabitEthernet0/0/0/5
127.0.0.0/8 receive
192.168.0.0/24 attached MgmtEth0/RP0/CPU0/0
192.168.0.0/32 broadcast MgmtEth0/RP0/CPU0/0
192.168.0.121/32 192.168.0.121/32 MgmtEth0/RP0/CPU0/0
192.168.0.123/32 192.168.0.123/32 MgmtEth0/RP0/CPU0/0
192.168.0.125/32 192.168.0.125/32 MgmtEth0/RP0/CPU0/0
192.168.0.126/32 192.168.0.126/32 MgmtEth0/RP0/CPU0/0
192.168.0.127/32 receive MgmtEth0/RP0/CPU0/0
192.168.0.129/32 192.168.0.129/32 MgmtEth0/RP0/CPU0/0
192.168.0.254/32 192.168.0.254/32 MgmtEth0/RP0/CPU0/0
192.168.0.255/32 broadcast MgmtEth0/RP0/CPU0/0
224.0.0.0/4 0.0.0.0/32
224.0.0.0/24 receive
255.255.255.255/32 broadcast
RP/0/RP0/CPU0:PE01#show mpls forwarding
Sat Aug 13 15:07:42.933 UTC
Local Outgoing Prefix Outgoing Next Hop Bytes
Label Label or ID Interface Switched
24000 Aggregate CustA-CE-1: Per-VRF Aggr[V] \
CustA-CE-1 0
24001 Aggregate CustB-CE-2: Per-VRF Aggr[V] \
CustB-CE-2 0
24002 Unlabelled 192.168.132.0/25[V] \
Gi0/0/0/1 10.13.2.2 0
24003 Unlabelled 192.168.132.128/25[V] \
24004 306400 9.9.9.109/32 10.18.101.0 0
24005 Unlabelled 192.168.111.0/25[V] \
Gi0/0/0/0 10.11.1.2 0
24006 Unlabelled 192.168.111.128/25[V] \
RP/0/RP0/CPU0:PE01#show mpls forwarding detail
Sat Aug 13 15:07:51.232 UTC
CustA-CE-1 0
Updated: Aug 13 09:00:24.988
Label Stack (Top -> Bottom): { }
MAC/Encaps: 0/0, MTU: 0
Packets Switched: 0
CustB-CE-2 0
Updated: Aug 13 09:00:24.992
Packets Switched: 0
Updated: Aug 13 15:03:44.788
Path Flags: 0x6020 [ EXT ]
Version: 163, Priority: 3
Label Stack (Top -> Bottom): { Unlabelled }
NHID: 0x0, Encap-ID: N/A, Path idx: 0, Backup path idx: 0, Weight: 0
MAC/Encaps: 4/4, MTU: 1500
Outgoing Interface: GigabitEthernet0/0/0/1 (ifhandle 0x010000a0)
Packets Switched: 0
Version: 165, Priority: 3
Packets Switched: 0
Updated: Aug 13 15:03:39.764
Version: 423, Priority: 4
Label Stack (Top -> Bottom): { 306400 }
MAC/Encaps: 0/4, MTU: 0
Packets Switched: 0
Updated: Aug 13 15:03:42.599
Outgoing Interface: GigabitEthernet0/0/0/0 (ifhandle 0x01000078)
Packets Switched: 0
Packets Switched: 0
Red flags that are raised for me is the fact that the cef table has a "(?)" next to the 9.9.9.109 entry, also there is not actual interface for the entry in the MPLS forwarding table for 9.9.9.109.
Not sure if there are other commands I can use to check RIB,FIB,LIB, and LFIB, are there?
08-13-2022 08:40 AM - edited 08-13-2022 09:39 AM
Hi @davehouser1 ,
This is definitely the issue.
There is a requirement in XR to have a static route towards the BGP peer used for BGP-LU.
router static
<ip address used for BGP-LU/32> <interface to the neighbor>
You need this on all the routers propagating the BGP-LU routes. This will solve the CEF issue.
08-15-2022 03:43 PM
I am not clear on what I should be doing
router static
<ip address used for BGP-LU/32> : Is this the RR that is serving vpnv4? In this case the bgp neighbor address is its loopback 5.5.5.5/32
<interface to the neighbor> : I am not sure what this should be. Each PE has two physical connections to each P router, which then has a single connection to each RR (One RR for unicast, and One for vpnv4). PE<->P connection1 = BGP-unicast. PE<-> connection2 = BGP-LU. I think I should be using my local loopback address of 9.9.9.109/32 but I am not sure. Right now the cef table shows that 5.5.5.5/32 is trying to use the physical unicast link which does not seem to be right.
Either way I tried the following
This entry was try to use the PE's BGP-LU physical link
router static address-family ipv4 unicast 5.5.5.5/32 gig0/0/0/3
This did not seem to work I cant ping 5.5.5.5/32 still.
This entry was to try and use the PE's Looback10 interface
router static address-family ipv4 unicast 5.5.5.5/32 Loopback10
This did not work either, I cant ping 5.5.5.5/32.
I tried adding these routes in each PE01 and PE02, did not seem to change anything from the CE side (pinging a BGP advertised route in the VRF) or the PE (pinging 5.5.5.5).
Is there something else I am missing?
08-15-2022 04:44 PM - edited 08-15-2022 06:26 PM
Hi @davehouser1 ,
This issue has nothing to do with the BGP VPNv4 configuration, but rather with the BGP-LU configuration. If you want to use BGP-LU to exchange labels instead of LDP, you need to setup BGP-LU on a hop by hop basis between routers in the path between PE1 and PE2. Is that what you have configured?
The static route that I am referring to should be configured to the BGP-LU peer on the directly connected router.
Can you please share the BGP-LU configuration from PE1?
08-18-2022 09:14 AM
as I mention before sorry for little info. but
I do my best to help other
the BGP run between CE-PE is different than any other protocol,
for example run ospf between CE-PE, the PE will advertise all prefix receive from CE (R5) and ALSO the link between CE-PE (which is next-hop for ALL prefix learn from CE)
in BGP this need more config
BGP advertise the prefix receive from CE but link between CE-PE not advertise by default,
this make other CE (R4) can not reach the prefix in CE (R5)
even so the prefix in both PE (R2 & R3)
so advertise the the Link solve the issue make CE (R4) know the next-hop for prefix advertise by CE(R5)
and return to your issue
there is primary and secondary IP in link between CE and PE,
are you advertise correctly?
I prefer advertise the prefix as /32 Why because the LDP is have some issue with not /32 prefix.
hope this help you
