MPLS Label Limits
mbehadir
Hi Experts,
How can I learn about ASR9K MPLS Label limits(LIB and LFIB max numbers).Is there any command to check on the device?
Are these limits changing with  LCs and RSPs types.Is there any scaling document to get these values?
Best Regards ...
balaji.bandi
Depends on the model and Ethernet Line card.
check below link may help you to find one you looking :
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-2/mpls/command/reference/b_mpls_cr42asr9k/b_mpls_cr42asr9k_chapter_010.html
BB
Hi Balaji,
Thanks for your cooperation.I will check the documentation.
Best Regards ...
