as per the topic title is there a command that will allow me to display the traffic stats of a l2transport interface or is this achievable only through SNMP?Thanks a lot
I need to connect two redundant firewalls working as Active/Standby to a single ASR router. The ASR router is having 2 line cards and each firewall is connected to both line cards as per the diagram.What is the best way to ensure high availability du...
Hi, All.I want to integrate IOS router to oxidized. I tried to login with pub key, but IOS asks password. Status, Current ConfigurationVersion RP/0/RP0/CPU0:RTR# sh ver
Cisco IOS XR Software, Version 7.9.2
Copyright (c) 2013-2023 by Cisco Systems, In...
PID : N540-24Z8Q2C-M
IOS-XR : 7.8.2
I want to know about smart licenses.
The command is enable, but when I apply the command below, it behaves as if the license is off.
RP/0/RP0/CPU0:PE-02#show run | inc licWed Mar 27 10:13:34.359 KSTBuilding confi...
Hi everyone,I tried to upgrade IOS-XR from the 6.6.3 version to version 7.6.2 on NCS-55A1-24H and the upgrade failed. I presume that upgrading to version 7.6.2 requires upgrades to lower versions of 7.x IOS-XR as a first step. If that's correct, I wo...
Hello,I have NCS5501 that I get the PCIE Uncorrectable Fatal Error/Surprise Link Down Error on Tomahawk LC. I am trying to look it up to gain a better understanding of what this is. Anyone ever seen this before? Can you clarify what it is refe...
Hi everyone,
I'm hoping to leverage Cisco's validated designs for building a public web hosting service. Ideally, the solution would be:
Cisco Validated Design: Based on Cisco's pre-configured and validated designs to ensure optimal performance and r...
This is a fixed port router with a mix of SFP+, SFP28, QSFP28 and QSFP-DD ports
The install guide says they are split between slice 0 and slice 1 with 24 ports per slice
How does this translate into the rack/slot/instance/port schema ? is the slice ...
Team,,We need to do below similar configuration of ASR1002 in our new ASR9001 please supportip dhcp pool PDY-3network 30.23.0.0 255.255.0.0default-router 30.23.2.1dns-server 8.8.8.8 4.2.2.2bba-group pppoe PDY-3virtual-template 3sessions per-mac limit...
Can the A99-12X100GE modules run in the ASR-9910 or ASR-9906 at line rate (not oversubscribed) with 5 x A99-SFC-S or 5 x A99-SFC-T ?We have options for A99-RSP-TR or A9K-RSP880-LT-TR. Can this work with these RSPs running IOS XR 7.9.2 ?We have tried...
