Hi All,
It appears that 7.3.2 is not available if i specifically select NCS-55A1-24Q6H-S on the cco software download page.
Now as far as i know the image is the same across the various NCS5k platforms, so I could get it by selecting 55A2, but just wanted to check if anyone came across this, and if its not available under NCS-55A1-24Q6H-S for some specific compatibility reason. Same goes for SMU. None seem to be available to select under NCS-55A1-24Q6H-S !
thanks
Mark
