NCS 55A2 XR 6.6 QoS
Seth Beauchamp
I am trying to do a simple shaper with a basic scheduler to prioritize EF traffic across a link. With the policy that I have tried, I get an error upon commit "!!% 'DNX_QOSEA' detected the 'warning' condition 'Invalid egress policy, Cannot have both queuing & marking in the same policy'"
The policy is:
interface TenGigE0/0/0/0.102
 service-policy output WAN_SHAPE_1Gbps
policy-map WAN_SHAPE_1Gbps
 class class-default
  service-policy WAN_TRAFFIC
  shape average 990 mbps
 end-policy-map
policy-map WAN_TRAFFIC
 class PRIORITY
  priority level 1
  police rate percent 95
 class class-default
 end-policy-map
class-map match-any PRIORITY
 match qos-group 1
 end-class-map
I also have an inbound policy on another interface which matches dscp EF and sets QoS group 1.
So the question is.. why does the error suggest this policy has both queuing and marking?
Also should I be setting/matching traffic-class instead of Qos-Group? Whats the difference between the two?
I found an example, you actually apply two policy-maps to the egress, one for marking and one for queuing. But yes what you have should work too.
Sample Ingress Policy-Map
policy-map ingress-classif
class cos2
set qos-group 1
set traffic-class 3
class cos3
set qos-group 2
set traffic-class 5
class cos4
set qos-group 3
set traffic-class 4
class class-default
set qos-group 7
set traffic-class 6
end-policy-map
class-map match-any cos2
match cos 2
end-class-map
class-map match-any cos3
match cos 3
end-class-map
class-map match-any cos4
match cos 4
end-class-map
Sample Egress Marking Policy
policy-map egress-marking
class qos1
set cos 1
class qos2
set cos 2
set dei 1
class qos3
set cos 3
class class-default
set cos 7
end-policy-map
class-map match-any qos1
match qos-group 1
end-class-map
class-map match-any qos2
match qos-group 2
end-class-map
class-map match-any qos3
match qos-group 3
end-class-map
Sample Egress Queuing Policy
policy-map egress-queuing
class tc3
shape average 2 mbps
class tc4
shape average 5 mbps
class tc5
shape average 7 mbps
class class-default
end-policy-map
class-map match-any tc3
match traffic-class 3
end-class-map
class-map match-any tc4
match traffic-class 4
end-class-map
class-map match-any tc5
match traffic-class 5
end-class-map
Attaching policy to a Interface
RP/0/RP0/CPU0:ios(config)#interface tenGigE 0/0/1/0/0
RP/0/RP0/CPU0:ios(config-if)#service-policy input ingress-classif
RP/0/RP0/CPU0:ios(config-if)#service-policy output egress-marking
RP/0/RP0/CPU0:ios(config-if)#service-policy output egress-queuing
RP/0/RP0/CPU0:ios(config-if)#commit
RP/0/RP0/CPU0:ios#show running-config interface tenGigE 0/0/1/0/0
interface TenGigE0/0/1/0/0
Sam
12 Replies 12
smilstea
Hi Seth,
A few things, qos-group matching on egress counts as a marking action and queuing and marking are not supported at the same time. On NCS5500 we have to apply different service-policy statements on the interface for queuing and for remarking actions. This means separate policy-maps  have to be created for marking and queuing respectively.
NCS5500 implements a different concept for marking. It is based on traffic-class and qos-group. On egress we match on these two parameters to remark traffic and to select queues.Traffic-class determines priority through the fabric.
While “match traffic-class” has to be used for queuing features “match qos-group” can only be used for marking.
Another issue is that policing is only supported on ingress and shaping only supported on egress.
Sam
Thanks for the response. If I may ask a follow up...
What would be the simplest way to ensure EF traffic gets prioritized with a low latency queue on these devices? Essentially, I have the NCS 55A2 positioned as a P router and want to ensure EF traffic (or mpls exp 5) gets LLQ treatment outbound.
on the ingress ports, do I need a marking policy that sets sets traffic class using a class-map matching dscp ef and mpls exp 5? Then a policy on egress matching the traffic-class? Does the dscp EF and mpls exp 5 markings stay preserved after leaving NCS 55A2 with this method?
This for example?
class-map match-any ef
 match traffic-class 1
 end-class-map
class-map match-any tc1
 match dscp ef
 match mpls experimental topmost 5
 end-class-map
policy-map egress
 class class-default
  service-policy priority
 end-policy-map
policy-map priority
 class ef
  priority level 1
 class class-default
 end-policy-map
policy-map ingress
 class tc1
  set traffic-class 1
 class class-default
 end-policy-map
interface te0/0/0/0
interface te0/0/0/1
The markings should stay preserved, for the sake of queuing we need to use traffic-class on ingress and egress. I seem to recall something about needing to use both qos-group and traffic-class on ingress but I can't find those details at the moment.
Sam
ok got it, so my last example should work, however I should also set qos-group 1 on ingress as well?
class cos2
set qos-group 1
set traffic-class 3
class cos3
set qos-group 2
set traffic-class 5
class cos4
set qos-group 3
set traffic-class 4
class class-default
set qos-group 7
set traffic-class 6
end-policy-map
match cos 2
end-class-map
match cos 3
end-class-map
match cos 4
end-class-map
class qos1
set cos 1
class qos2
set cos 2
set dei 1
class qos3
set cos 3
class class-default
set cos 7
end-policy-map
match qos-group 1
end-class-map
match qos-group 2
end-class-map
match qos-group 3
end-class-map
class tc3
class tc4
class tc5
class class-default
end-policy-map
end-class-map
end-class-map
end-class-map
Sam
smailmilak
Level 4
Level 4
I have just started working with NCS. With A9K I didn't had any issues with this particular QoS policy-map.
All I need is to match an Exp bit or dscp and put in in queue (bandwidth percent or police e.g).
What ever I do I get the same error Cannot have both queuing & marking in the same policy.
This is my class map and pmap. What is the equivalent that is supported on NCS55A2 100GigE MPA?
I was reading the guide but it's not entirely clear. Do I really need to match e.g. MPLS EXP bit 4, and set traffic-class 4 or qos qroup 4 so that I can match traffic-class 4 or qos qroup 4 on the egress interface?
class VOICE
  police rate 3 gbps
  priority level 1
 class CONTROL
  police rate 50 mbps
  priority level 2
 class MANAGEMENT
  bandwidth 250 mbps
class-map match-any VOICE
 match mpls experimental topmost 3 5
 match dscp ef cs3
class-map match-any CONTROL
 match mpls experimental topmost 6
 match dscp cs6
class-map match-any MANAGEMENT
 match mpls experimental topmost 1
 match dscp cs1
hi xr-rules,
configure one QoS policy only for marking and another only for queuing. In that case you can apply both egress policies simultaneously to an interface.
/Aleksandar
Thanks Aleks,
the weird part is that I'm only matching, not marking (set exp bit 4 for example). I will receive already marked traffic on this PE (marked by the source i.e. voice GW).
So I should match for example exp bit 4 and set it in qos-group 4 or traffic-class 4?
This qos-group 4 or traffic-class 4 will be matched by the egrees PMAP and put in a queue?
Is this the correct approach with NCS? I have to do it properly before putting the nodes in production.
In an egress QoS policy on DNX platforms (NCS540, NCS560, NCS5k, NCS5500) you cannot match on packet header fields. You can only match on internal scope traffic-class or qos-group. Traffic has to be classified into a given traffic-class or qos-group in an ingress QoS policy. Match on a traffic-class if the action you want to apply is queuing. Match on qos-group if the action you want to apply is egress marking.
Hope this helps!
/Aleksandar
Ok, got it. I have noticed that same by using the examples in the config guide. The funny part is that for LLQ, shaping is used, and back in the old days this was a no go
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/qos/71x/b-qos-cg-ncs5500-71x/b-qos-cg-ncs5500-71x_chapter_0100.html#concept_8B00194217564346A11458F1B9E47260
It's getting clear now. Thanks Aleks, you are supportive as always.
Always a pleasure!
DNX platforms use merchant silicone, which has great benefits but does come with some restrictions. One of them is that policing is supported only on ingress, while and queueing actions (shape, BW, LLQ) are supported only on egress. Hence you will see that on DNX we always configure shaping with LLQ.
In case you didn't know, there is a lot of material on NCS5500 on https://xrdocs.io/ . The content there is authored by NCS5500 experts, you will find lots of useful info there.
/Aleksandar
Thanks Aleks. I know about that site. It’s very useful.
