Cisco Community Designated VIP Class of 2020
185
Highlighted
NCS IOS-XR Trunk Interface CDP configuration
Hello community,
How do I have to configure CDP on a trunk interface on an NCS540 with IOS-XR?
I have added the command "cdp" under the phisical Interface, but it wasn't successful :(
interface GigabitEthernet0/0/0/13
cdp
speed 1000
negotiation auto
interface GigabitEthernet0/0/0/13.12 l2transport
encapsulation dot1q 12
rewrite ingress tag pop 1 symmetric
interface GigabitEthernet0/0/0/13.13 l2transport
encapsulation dot1q 13
Thanks for your feedback
2 REPLIES 2
Participant
Re: NCS IOS-XR Trunk Interface CDP configuration
I think the issue is that CDP on trunked interfaces are tagged.
"CDP, VTP, and PAgP updates are always forwarded on trunks with a VLAN 1 tag. This is the case even if VLAN 1 has been cleared from the trunks and is not the native VLAN. Clearing VLAN 1 for user data has no impact on control plane traffic that is still sent using VLAN 1."
An easy way to get round this is to create a subinterface with tag one on either side - enable CDP on this and everything should work.
cdp enable
FYI - Im not sure why you are hard setting the speed to 1000 - normally this is set to auto.
- maybe there is some hardware compatiabliliy issue - but I wouldnt do that unless I had to.
Thanks for your feedback.
Well I have changed the interface settings to auto negotiation, just to exclude any other problems.
I also have added the default vlan on the trunk configuration, and also allowed the vlan 1 on the opposite device.
cdp
interface GigabitEthernet0/0/0/13.1 l2transport
But I still dosen't get the cdp neighbor ship working :(
I only can enable cdp on the pfysical interface, not on the sup-interface.
RP/0/RP0/CPU0:PE1#sh cdp interface gigabitEthernet 0/0/0/13
Tue Sep 17 10:04:52.448 UTC
GigabitEthernet0/0/0/13 is Up
Encapsulation ether
Sending CDP packets every 60 seconds
Holdtime is 180 seconds
RP/0/RP0/CPU0:PE1#
any idea?
Content for Community-Ad
FusionCharts will render here
