NCS5501-SE microflow policing (UBRL)
benediktsv
Hi all
We have a NCS5501-SE in a edge configuration towards IX'es
We have been running microflow policing on 7600/RSP720 - and we need to apply this to the NCS .
match criteria should be /32 ip addresses to be capped to some reasonable value
I'm not seeing that  UBRL is supported in the NCS - is that correct ?
Is it bidirectional or only one way ?
if it's supported, does someone here have some pointers or better, config examples.
- B
smilstea
Unfortunately the only XR product supporting UBRL is the ASR9K.
I would suggest talking with your account team to get this on the roadmap for NCS5500.
Sam
smilstea
Sam
Thanks for the reply
I was starting to suspect this, just wanted to be 100% sure I was not missing something before going to the alternative solution.
guess we hope for some other major fixes before they introduce this into the mix ;)
