no access-group xyz out egress hardware-count issue.
kzryumov1
Beginner
Beginner
                   Hello cisco team,
We faced with an issue on XR 4.2.1.
After we had removed access-group from interface:
interface Bundle-Ether4.89
service-policy output INET89
ipv4 mtu 1500
ipv4 point-to-point
ipv4 address
ipv4 verify unicast source reachable-via any allow-self-ping allow-default
ipv4 unreachables disable
lldp
  transmit disable
load-interval 30
flow ipv4 monitor proton sampler proton ingress
flow ipv6 monitor proton-v6 sampler proton ingress
encapsulation dot1q 89
ipv4 access-group mtk-inet-out egress hardware-count
description Mostelekom Internet
ipv4 mtu 1500
ipv4 point-to-point
ipv4 address ipv4 verify unicast source reachable-via any allow-self-ping allow-default
lldp
  transmit disable
load-interval 30
#show configuration commit changes 1000001011
Tue Nov 19 12:57:36.421 MSK
Building configuration...
!! IOS XR Configuration 4.2.1
no ipv4 access-group mtk-inet-out egress
end
the cisco router stopped ldp/ospf peering with all neighbors. Also, router didn't answer on ping. The issue resolved only after reboot.
There was no any strange messages in logs.
Does anyone can help us what is wrong?
Konstantin
there was a known bug with acl modification in XR421.
from the looks of it, sounds like you're hitting that.
recommend using 423 (which has a load of smu's) or 434 that is coming out any day now.
regards
xander
5 Replies 5
kzryumov1
Beginner
Beginner
One comment.
The ACL is very big (1500 string).
Konstantin
regards
xander
Hi Alexander,
Thanks.
Could you provide me a bug detail?
Konstantin
Do you mean CSCuc94735?
Konstantin
hi konstantin,
I am checking the ddts's quickly, but I cant find it that quickly. I verified the contents of smu pack1 for 421 which does not have the fix either.
if there is a possibility I would either verify 423 with all the smu's or wait for XR434 which is coming out any day now.
if I find the relevant ddts I will post it.
the one you have is not the one I had in mind, but nice find either way!
cheers!
xander
Recognize Your Peers
