No response from 'cgn_ma' cisco ASR9000
kzryumov1
Cisco ASR9006 IOS XR 4.3.1 doesn't show NAT statistics. For example: show cgn nat44 natXX statistics
RP/0/RSP0/CPU0:Oct 17 11:42:22.964 : sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65900, node
0/RSP0/CPU0). No response from 'cgn_ma' (jid 1075, node 0/RSP0/CPU0) within the timeout period
(100 seconds)
RP/0/RSP0/CPU0:Oct 17 11:42:34.527 : sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat2/stats' from 'show_cgn_nat44_stats' (jid 65900, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 17 11:42:46.096 : sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat3/stats' from 'show_cgn_nat44_stats' (jid 65899, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 17 11:44:09.403 : sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/cgn1/stats' from 'show_cgn_nat44_stats' (jid 65898, node
(100 seconds)
(100 seconds)
(100 seconds)
(100 seconds)
(100 seconds)
Recently, everything works fine. There was no any changes.
Could anyone help me to resolve the issue?
Konstantin
3 Accepted Solutions
Hi Konstantin,
Yes, you can restart cgn_ma process which normally should not have service impact. We provide that as a work-around in similar cases. You can give it a try with that and see if it fixes the issue or not.
Can you pl. send "show process blocked" output as well ? If it shows cgn_ma in the list of blocked processes, process restart is a good way of coming out of it.
If you want detailed level trouble-shooting, you can raise a service request (SR) and Cisco support team can help.
regards,
Somnath.
Hi Konstantin,
What was before "SYSDB-SYSDB-7-INFO" line ? Can you pl. cut and paste multiple error msgs (as part of "sh logging") ?
I'm not aware of any known issue with this msg.
If you would like to us to do detailed analysis, we would need complete log and the commands that were executed before the issue was seen. Did ISM card go through any reload during that time ?
Does it work fine after 'process restart cgn_ma' ?
regards,
Somnath.
Those are caused by CSCui39371 (can be ignored) in this context.
17 Replies 17
somnathr
Hi Konstantin,
Can you please send the following output ?
- show run
- show platform summary location
- show process cgn_ma
regards,
Somnath.
Hi Somnath,
#show platform summary location all
Fri Oct 18 13:17:04.992
     Platform Node : 0/RSP0/CPU0 (slot 0)
               PID : A9K-RSP-4G
         Card Type : ASR9K Fabric, Controller, 4G memory
            VID/SN : V03 / FOC15078EWY
        Oper State : IOS XR RUN
        Last Reset : User Initiated reload
Process: reload
                   : Tue Aug 20 10:25:59 2013
     Configuration : Power is enabled
                     Bootup enabled.
                     Monitoring enabled
        Rommon Ver : Version 1.06(20120210:003513)
        IOS SW Ver : 4.3.1
        Main Power : Power state Enabled. Estimate power 205 Watts of power required.
            Faults : N/A
     Platform Node : 0/RSP1/CPU0 (slot 1)
               PID : A9K-RSP-4G
            VID/SN : V02 / FOC142683EY
Process: reload
                   : Tue Aug 20 15:00:03 2013
                     Bootup enabled.
                     Monitoring enabled
        IOS SW Ver : 4.3.1
            Faults : N/A
     Platform Node : 0/0/CPU0 (slot 2)
               PID : A9K-8T-L
         Card Type : 8-Port 10GE Low Queue Line Card, Requires XFPs
            VID/SN : V03 / FOC153282Z2
        Last Reset : Reloading managed node
Process: insthelper
                   : Fri Aug 16 11:48:31 2013
                     Bootup enabled.
                     Monitoring enabled
        Rommon Ver : Version 1.03(20100211:014208)
        IOS SW Ver : 4.3.1
        Main Power : Power state Enabled. Estimate power 575 Watts of power required.
            Faults : N/A
     Platform Node : 0/1/CPU0 (slot 3)
               PID : A9K-ISM-100
         Card Type : Integrated Services Module
            VID/SN : V01 / FOC1706N0P0
        Last Reset : MBI-HELLO reloading node on receiving reload notification
Process: mbi-hello
                   : Thu Aug 29 10:55:57 2013
                     Bootup enabled.
                     Monitoring enabled
        Rommon Ver : Version 1.2(20091201:235620)
        IOS SW Ver : 4.3.1
        Main Power : Power state Enabled. Estimate power 405 Watts of power required.
            Faults : N/A
     Platform Node : 0/1/CPU1 (slot 3)
         Card Type : Integrated Services Module (Service Engine)
        Oper State : APP-READY
   Last Start Time : Tue Sep  3 14:37:10 2013
   Last Ready Time : Tue Sep  3 14:39:13 2013
            Uptime : 1078:37:53
          BIOS Ver : 0.17 (Thurley.3.60.18.0033)
            SW Ver : 1.1.1.0 (Built on May 08 2013, from services/cgn@r431-support/3)
        App Status : 8 CGv6 Application instance(s) is/are running
     Platform Node : 0/2/CPU0 (slot 4)
               PID : A9K-ISM-100
            VID/SN : V01 / FOC1704N09P
Process: mbi-hello
                   : Thu Aug 29 11:31:19 2013
                     Bootup enabled.
                     Monitoring enabled
        IOS SW Ver : 4.3.1
            Faults : N/A
     Platform Node : 0/2/CPU1 (slot 4)
   Last Start Time : Tue Sep  3 14:37:20 2013
   Last Ready Time : Tue Sep  3 14:39:46 2013
            Uptime : 1078:37:20
     Platform Node : 0/3/CPU0 (slot 5)
               PID : A9K-ISM-100
            VID/SN : V01 / FOC1704N09Q
Process: mbi-hello
                   : Tue Aug 20 10:50:48 2013
                     Bootup enabled.
                     Monitoring enabled
        IOS SW Ver : 4.3.1
            Faults : N/A
     Platform Node : 0/3/CPU1 (slot 5)
            Uptime : 1078:37:54
RP/0/RSP0/CPU0:deg-nat01.#
RP/0/RSP0/CPU0:deg-nat01.# show process cgn_ma
Fri Oct 18 13:18:53.717 MSK
                  Job Id: 1075
                     PID: 602460
         Executable path: /disk0/iosxr-service-4.3.1/0x100000/bin/cgn_ma
              Instance #: 1
              Version ID: 00.00.0000
                 Respawn: ON
           Respawn count: 1
  Max. spawns per minute: 12
            Last started: Tue Sep  3 14:35:27 2013
           Process state: Run
           Package state: Normal
       Started on config: cfg/gl/service-cgn/
           Process group: central-services
                    core: MAINMEM
               Max. core: 0
               Placement: DLRSC Tracker
            startup_path: /pkg/startup/cgn_ma.startup
                   Ready: 1.757s
        Process cpu time: 81.527 user, 6.092 kernel, 87.619 total
JID   TID CPU Stack pri state        TimeInState    HR:MM:SS:MSEC   NAME
1075   1    1   52K  10 Reply         25:48:11:0377    0:01:27:0579 cgn_ma
1075   2    0   52K  10 Receive     1078:43:26:0449    0:00:00:0001 cgn_ma
1075   3    0   52K  10 Receive     1078:43:26:0427    0:00:00:0000 cgn_ma
1075   4    0   52K  10 Condvar       97:04:59:0192    0:00:00:0025 cgn_ma
1075   5    1   52K  10 Receive     1078:38:43:0702    0:00:00:0013 cgn_ma
RP/0/RSP0/CPU0:deg-nat01.# show process cgn_ma detail location all
Fri Oct 18 13:18:18.805
node:      node0_0_CPU0
No such process cgn_ma
node:      node0_1_CPU0
node:      node0_2_CPU0
node:      node0_3_CPU0
node:      node0_RSP0_CPU0
                  Job Id: 1075
                     PID: 602460
              Instance #: 1
                 Respawn: ON
           Respawn count: 1
           Process state: Run
                    core: MAINMEM
               Max. core: 0
                   Ready: 1.757s
            Running path: /disk0/iosxr-service-4.3.1/0x100000/bin/cgn_ma
            Package path: /pkg/bin/cgn_ma
             Job-id-link: 1075
               group_jid: 8600,0,0,0
              fail_count: 0
                this pcb: 0xe7ffe838
                next pcb: 0x6016f400
             jobid on RP: 0
          Standby Status: 2
1075   1    1   52K  10 Reply         25:47:38:0871    0:01:27:0579 cgn_ma
1075   2    0   52K  10 Receive     1078:42:53:0943    0:00:00:0001 cgn_ma
1075   3    0   52K  10 Receive     1078:42:53:0922    0:00:00:0000 cgn_ma
1075   4    0   52K  10 Condvar       97:04:26:0687    0:00:00:0025 cgn_ma
1075   5    1   52K  10 Receive     1078:38:11:0197    0:00:00:0013 cgn_ma
node:      node0_RSP1_CPU0
                  Job Id: 1075
                     PID: 606510
              Instance #: 1
                 Respawn: ON
           Respawn count: 1
            Last started: Tue Sep  3 14:36:43 2013
           Process state: Run
       Started on config: cfg/gl/service-cgn/cgn1/ord_a/enter
                    core: MAINMEM
               Max. core: 0
                   Ready: 1.940s
             Job-id-link: 1075
              fail_count: 0
             jobid on RP: 0
          Standby Status: 2
       role_event_clinfo: 5009c234
         Proc role state: backup
        Process cpu time: 31.437 user, 12.015 kernel, 43.452 total
1075   1    0   36K  10 Receive        0:00:00:0228    0:00:43:0449 cgn_ma
1075   2    1   36K  10 Receive     1078:41:35:0991    0:00:00:0001 cgn_ma
1075   3    1   36K  10 Receive     1078:41:35:0811    0:00:00:0000 cgn_ma
The config is too long. I absolutely confident that recently it works.
Is it possible to restart cgn_ma process? Would be any service impact?
Konstantin
Hi Konstantin,
regards,
Somnath.
Hi Somnath,
Very thanks.
The cgn_ma process was in blocked state.
I noticed that this occured after these message:
%SYSDB-SYSDB-7-INFO :
exec:oper/tty/gl/________/________/vty/3/stats/conn-out/: rc 0x40824200 ('sysdb' detected the
'warning' condition 'A SysDB client attempted to register for verification or as an EDM on a
path which was already registered')
What does it means? Could we avoid this problem  in the future?
Konstantin
Hi Konstantin,
regards,
Somnath.
Hi Somnath.
I've calculated from time when process was blocked in logs were:
LC/0/2/CPU0:Oct 17 04:21:55.946 cgv6_services[140]: core_event_logging_init[835] core 2, Error code 1, Msg: **  i-vrf: 0x11 :: ipv4 addr: 0xae5405d :: port: 0xb0d6 ::  ** , 'cgv6_services' detected the 'warning' condition 'No CGN config'
LC/0/2/CPU0:Oct 17 04:21:55.946 MSK: cgv6_services[140]: %PLATFORM-CGV6_SERVICES-7-GENERIC_ERROR : core 2, Error code 1, Msg: **  i-vrf: 0x11 :: ipv4 addr: 0xae5405d :: port: 0xb0d6 ::  ** , 'cgv6_services' detected the 'warning' condition 'No CGN config' 0x49418200
R LC/0/2/CPU0:Oct 17 04:21:55.946 cgv6_services[140]: core_event_logging_init[835] core 2, Error code 1, Msg: **  i-vrf: 0x11 :: ipv4 addr: 0xae5405d :: port: 0xb0d6 ::  ** , 'cgv6_services' detected the 'warning' condition 'No CGN config'
There was no any change in config at this time. What does these messages mean?
Konstantin
Great!
Thanks.
And it is fixed in 4.3.2. Currently, we use 4.3.1.
Hi Somnath,
The problem reproduced again on another ASR and with 4.3.1.
#show processes blocked
Tue Oct 22 11:18:12.172 MSK
  Jid       Pid Tid            Name State   TimeInState    Blocked-on
65551     16399   1             ksh Reply 1152:52:17:0014   16395  devc-conaux
65554     61458   2      devb-umass Reply    0:00:00:0126   53284  io-usb
   98     49187   2      umass-enum Reply 1152:52:21:0728       1  kernel
   98     49187   6      umass-enum Reply 1152:52:15:0896   53284  io-usb
   98     49187   7      umass-enum Reply 1152:52:18:0625       1  kernel
   98     49187   8      umass-enum Reply 1152:52:17:0227       1  kernel
   98     49187   9      umass-enum Reply 1152:52:15:0896       1  kernel
   52     65573   2         attachd Reply 1152:52:18:0576   53292  eth_server
   52     65573   3         attachd Reply 1152:52:18:0574   24595  mqueue
   89     65574   6            qnet Reply    0:00:00:0386   53292  eth_server
65584     65584   2      devb-umass Reply    0:00:40:0630   53284  io-usb
   51     65590   2   attach_server Reply 1152:52:18:0090   24595  mqueue
65594     77882   2      devb-umass Reply    0:00:04:0484   53284  io-usb
65603    798787   1            exec Reply  672:13:27:0244   16395  devc-conaux
  433    237664   1     tftp_server Reply 1152:47:58:0911   24595  mqueue
  315    598246   2         lpts_fm Reply    0:00:00:0176  286865  lpts_pa
1075    610601   1          cgn_ma Reply    0:08:25:0003  454777  node 0/1/CPU0 cgn_ea
65893 616034661   1            exec Reply    0:00:00:0164       1  kernel
65894 616063334   1            more Reply    0:00:00:0075   24593  pipe
65895 609853799   1            exec Reply    0:03:35:0428       1  kernel
65897 616063337   1  show_processes Reply    0:00:00:0000       1  kernel
RP/0/RSP0/CPU0:nag-nat01.msk#
RP/0/RSP0/CPU0:nag-nat01.msk#show processes blocked 1075 extended
Tue Oct 22 11:18:44.970 MSK
1075    610601   1          cgn_ma Reply    0:08:57:0723  454777  node 0/1/CPU0 cgn_ea
Following thread 1 to process cgn_ea, pid 454777 on node 0/1/CPU0
  139    454777   1          cgn_ea Receive         0:01:06:0352
  139    454777   2          cgn_ea Receive       191:03:14:0571
  139    454777   3          cgn_ea Receive         0:08:57:0746
Resuming display of process cgn_ma, pid 610601, jid 1075
1075    610601   2          cgn_ma Receive      1152:46:18:0789
1075    610601   3          cgn_ma Receive      1152:46:18:0674
1075    610601   4          cgn_ma  Cond  191:03:12:0306 (0x50040608)
1075    610601   5          cgn_ma Receive      1151:56:49:0818
And we see only this message:
exec:oper/tty/gl/________/________/vty/1/stats/conn-out/: rc 0x40824200 ('sysdb' detected the
RP/0/RSP0/CPU0:Oct 22 11:10:50.726 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-7-INFO :
RP/0/RSP0/CPU0:Oct 22 11:10:51.084 MSK: exec[65895]: %SECURITY-login-6-AUTHEN_SUCCESS :
Successfully authenticated user 'rancid' from '2a02:2168:202:1:77:37:251:71' on 'vty1'
RP/0/RSP0/CPU0:Oct 22 11:11:03.514 MSK: exec[65895]: %SECURITY-login-6-AUTHEN_SUCCESS :
Successfully authenticated user 'rvp' from '2a02:2168:204:0:227:eff:fe02:7350' on 'vty1'
RP/0/RSP0/CPU0:Oct 22 11:11:27.364 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/cgn1/pcpcounters' from 'show_cgn_nat44_pcp_counters'
(jid 65894, node 0/RSP0/CPU0). No response from 'cgn_ma' (jid 1075, node 0/RSP0/CPU0) within
the timeout period (100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:11:43.377 MSK: config[65885]: %MGBL-SYS-5-CONFIG_I : Configured from
console by asaveliev on vty0 (2a02:2168:204:0:290:27ff:fe23:f4dd)
RP/0/RSP0/CPU0:Oct 22 11:12:14.581 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65894, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:12:19.944 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65898, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:12:31.496 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat2/stats' from 'show_cgn_nat44_stats' (jid 65901, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:13:34.229 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65893, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:14:30.973 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for
'oper/service-cgn/gl/nat44/nat1/putil/invrf/CGN1/address-rangefilter/b9131474,b91314e1/' from
'show_cgn_ma_nat44_pool_util' (jid 65893, node 0/RSP0/CPU0). No response from 'cgn_ma' (jid
1075, node 0/RSP0/CPU0) within the timeout period (100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:15:42.562 MSK: exec[65900]: %SECURITY-login-6-AUTHEN_SUCCESS :
Successfully authenticated user 'rancid' from '2a02:2168:202:1:77:37:251:71' on 'vty0'
RP/0/RSP0/CPU0:Oct 22 11:15:56.076 MSK: exec[65894]: %SECURITY-login-6-AUTHEN_SUCCESS :
RP/0/RSP0/CPU0:Oct 22 11:16:08.669 MSK: exec[65882]: %SECURITY-login-6-AUTHEN_SUCCESS :
RP/0/RSP0/CPU0:Oct 22 11:17:23.634 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat1/stats' from 'show_cgn_nat44_stats' (jid 65905, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:17:36.484 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat2/stats' from 'show_cgn_nat44_stats' (jid 65902, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:17:50.271 MSK: sysdb_shared_nc[417]: %SYSDB-SYSDB-6-TIMEOUT_EDM : EDM
request for 'oper/service-cgn/gl/nat44/nat3/stats' from 'show_cgn_nat44_stats' (jid 65898, node
(100 seconds)
RP/0/RSP0/CPU0:Oct 22 11:17:50.787 MSK: exec[65893]: %SECURITY-login-6-AUTHEN_SUCCESS :
Successfully authenticated user 'rvp' from '2a02:2168:204:0:227:eff:fe02:7350' on 'vty0'
Konstantin
Hello Somnath,
We use every 1 and 4 minutes rancid functionaliry to collect counters  from #show cgn nat44 natXX stat via CLI becouse of it is impossible to get this information through SNMP.
Could it be root cause of the issue?
Konstantin
Hi Konstantin,
I think you are hitting the following:
CSCuh61188 cgn_ma process blked/show cmds fail on executing show cgn nat44 mapping
Do not include the following command in your script:
show cgn ... pcpCounters
Try it after that and let me know if it helps.
regards,
Somnath.
Hello Somnath,
Could you explain this bug, CSCuh61188.
I can't view the details.
Is there a workaround for this issue? Or we shall upgrade IOS-XR?
Thanks.
Hi Egor,
Looks like Release-note tag was not set properly - that could be reason why is it not visible.
Here are the details:
Symptom:
After execution of "show cgn <> pcpCounters"  command cgn_ma gets reply blocked on cgn_ea. Afterwards no other "show cgn" cli responds. The mentioned CLI  is not supported on ISM and not handled gracefully. Hence, the process gets blocked.
Conditions:
Execution of "show cgn <> pcpCounters"
Workaround:
"process restart cgn_ma"  to unblock the cgn_ma process.
More Info:
It is present in 4.3.1 release.
regards,
Somnath.
Thanks a lot, Somnath!
This is exactly our issue.
But one little question: is this issue resolved in 4.3.2 or later IOS-XR?
Thanks.
