OSPF Redistribution limit in XR Platform
Anuj Singhi
Hi Team,
I am getting below error log in my ASR9K for ospf stating that the limit for redistribution has been reached
ospf[1021]: %ROUTING-OSPF-4-REDIST_MAX_PFX : Redistribution prefix limit has been reached - 10240 prefixes
Can somebody help me to identify if its a bug or a known error which can be rectified?
Anuj
Elvin Arias Soto
Hi Anuj Singhi,
There is an OSPF maximum redistributed-prefix set by default as warning-only. Is just an informational message to indicate that default threshold has been reached. Warning threshold is set to 75% by default.
Refer to, https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-4/routing/command/reference/b-routing-cr-asr9000-64x/b-routing-cr-asr9000-64x_chapter_0110.html#ref_2015871.
Elvin
mivens
Check your configuration. You probably have
maximum redistributed-prefix 10240
set.
No I don't have it any config statement like that.
Hi Anuj,
can we check how many routes are present?
please provide "show route summary"
Elvin Arias Soto
Hi Anuj Singhi,
Elvin
