01-02-2012 04:07 AM
Hello A9K Experts,
I pretend to implement a PIC Edge Unipath solution but it's no working properly on my lab scenario.
The router learns the following prefix from iBGP (MPLS VPN neighbour 10.181.1.7) and from eBGP (195.9.60.1):
* i40.40.40.40/32 10.181.1.7 0 100 0 1234 i
*> 195.9.60.1 0 0 1234 i
Only the best entry enters the routing table, as it should:
B 40.40.40.40/32 [20/0] via 195.9.60.1, 00:25:10
I have this configuration for the vrf
router bgp xxxxx
vrf TESTE123
rd xxxxx:xxxxxxx
label-allocation-mode per-vrf
address-family ipv4 unicast
table-policy Botnet
additional-paths receive
additional-paths send
additional-paths selection route-policy TESTE123
pass
end-policy
But cef doesn't take into account the PIC Edge configuration, since only the best path is computed there through the eBGP neighbour.
RP/0/RSP0/CPU0:A9k-03#show cef vrf TESTE123 40.40.40.40/32 detail
Mon Jan 2 12:03:53.786 WET
40.40.40.40/32, version 15, internal 0x40000001 (ptr 0x9cfdc21c) [1], 0x0 (0x0), 0x0 (0x0)
Updated Jan 2 11:37:41.672
Prefix Len 32, traffic index 0, precedence routine (0)
gateway array (0x9ccee3c0) reference count 15, flags 0x80600, source rib (3),
[1 type 3 flags 0x901101 (0x9cd8307c) ext 0x0 (0x0)]
LW-LDI[type=0, refc=0, ptr=0x0, sh-ldi=0x0]
Level 1 - Load distribution: 0
[0] via 195.9.60.1, recursive
via 195.9.60.1, 5 dependencies, recursive, bgp-ext [flags 0x20]
path-idx 0
next hop 195.9.60.1 via 195.9.60.0/30
Load distribution: 0 (refcount 1)
Hash OK Interface Address
0 Y GigabitEthernet0/1/0/4.60 remote
Should the PIC EDGE operation pre-compute the label for the iBGP Path ? Or am i seeing this the wrong way ?
PIC EDGE Multipath with eiBGP multipath works perfectly!
Thanks!
David
Solved! Go to Solution.
01-02-2012 12:33 PM
Hello David,
Configure the router policy like this
set path-selection backup 1 install multipath-protect advertise
end-policy
/A
01-02-2012 12:33 PM
Hello David,
end-policy
/A
01-03-2012 02:30 AM
Thanks Akiritch !
It does work! But a few more comments:
The control-plane verification is identical with the PIC Edge Multipath (with eiBGP multipath enabled)
B 40.40.40.40/32 [20/0] via 10.181.1.7 (nexthop in vrf default), 00:01:01
[20/0] via 195.9.60.1, 00:01:01
But the forwarding-plane has it´s difference and it works perfectly has intended! Can i assume this is the normal operation ?
Tue Jan 3 10:27:33.188 WET
40.40.40.40/32, version 19, internal 0x40040001 (ptr 0x9cfdc7cc) [1], 0x0 (0x0), 0x4100 (0x9e511368)
Updated Jan 3 10:12:16.365
via 10.181.1.7, 7 dependencies, recursive, backup [flags 0x110]
path-idx 0
next hop VRF - 'default', table - 0xe0000000
next hop 10.181.1.7 via 16009/0/21
next hop 10.181.64.17/32 Te0/0/0/0.2 labels imposed {16001 16001}
via 195.9.60.1, 7 dependencies, recursive, bgp-ext [flags 0x20]
path-idx 1
next hop 195.9.60.2/32 Gi0/1/0/4.60 labels imposed {None}
My last questions are:
Why is this feature so poorly documented on the IOSXR command reference and configuration guide ?
How can a Customer Technical Team configure this feature without Cisco Engineers help ?
Or am i looking on the wrong documents ?
Once again thank you!
01-03-2012 04:15 AM
Hello David,
Try “show bgp vrf TESTE123 40.40.40.40”, one path should be marked as the best and another as the backup.
Yes, you are correct, the feature documentation is poor and we have provided this feedback to the documentation team.
/A
01-03-2012 06:54 AM
Thanks Akiritch. We did check the bgp table too and the only difference on it between the Multipath and Unipath option is this:
Multipath
10.181.1.7 (metric 200) from 10.181.1.7 (10.181.1.7)
Received Label 16001
Origin IGP, metric 0, localpref 100, valid, internal, multipath, backup, add-path, import-candidate, imported
195.9.60.1 from 195.9.60.1 (195.10.10.4)
Origin IGP, metric 0, localpref 100, valid, external, best, group-best, multipath, import-candidate
Unipath
Origin IGP, metric 0, localpref 100, valid, internal, backup, add-path, import-candidate, imported
Origin IGP, metric 0, localpref 100, valid, external, best, group-best, import-candidate
And the same routing table entry for both
B 40.40.40.40/32 [20/0] via 10.181.1.7 (nexthop in vrf default), 00:03:19
[20/0] via 195.9.60.1, 00:03:19
Interesting to note that admin distance of 20 via 10.181.1.7 when it is an iBGP neighbor. It seems necessary to achieve the intended result. And it works!
Once again thank you.
PS: I cannot stress more the fact that the IOSXR documentation is indeed very poor.
01-15-2018 01:57 AM
Hi Experts
I followed this discussion to create the BGP PIC. However, after e-BGP link failure, new forwarding path was calculated and put into VRF table instead of using the backup. As per site topology, the first backup would be preferred path. Please see output below. Can you advise?
Before e-BGP link down
Routing entry for 10.31.5.128/29
Known via "bgp 64513", distance 20, metric 0
Tag 65042
Number of pic paths 1 , type internal and external
Installed Jan 14 19:32:02.735 for 15:02:59
Routing Descriptor Blocks
10.32.28.74, from 10.32.28.74, BGP external
Nexthop in Vrf: "default", Table: "default", IPv4 Unicast, Table Id: 0xe0000000
Route metric is 0
Label: 0xa3e (2622)
Tunnel ID: None
Binding Label: None
Extended communities count: 0
Source RD attributes: 0x0000:65042:100
NHID:0x0(Ref:0)
10.100.4.100, from 10.100.4.100, BGP backup path
Route metric is 0
Label: 0x5dd0 (24016)
Tunnel ID: None
Binding Label: None
NHID:0x0(Ref:0)
After e-BGP link down
Known via "bgp 64513", distance 200, metric 0
Tag 65042
Installed Jan 15 10:35:02.764 for 00:00:03
10.100.1.100, from 10.100.1.100
Route metric is 0
Label: 0x5e06 (24070)
Tunnel ID: None
Binding Label: None
NHID:0x0(Ref:0)
Route metric is 0
Tunnel ID: None
Binding Label: None
NHID:0x0(Ref:0)
"route-policy BGP_PIC
#***Fast Failover in BGP***
end-policy
"router bgp 64513
bgp router-id 10.100.3.100
bgp graceful-restart
bgp log neighbor changes detail
address-family vpnv4 unicast
additional-paths selection route-policy BGP_PIC
retain route-target all"
Sumanta.
