Im working out p2p L2vpn between ASR9K and IOS platforms (7600). PE-CE connectivity is using vlan encapsulation at both ends. Default PW type negotiated is ethernet (VC type 5) and VC comes up. But CE to CE communication is not happening. I changed the interworking mode to IP at both ends and it started working.
What is the difference between these PW types. Has anyone come across the same problem? I believe it should work with Ethernet type itself.
Below are the output details before and after changing PW types.
Default PW-type:
Group ASR-G2, XC A-G2, state is up; Interworking none
AC: GigabitEthernet0/0/0/1.607, state is up
Type VLAN; Num Ranges: 1
VLAN ranges: [607, 607]
MTU 1546; XC ID 0x840004; interworking none
Statistics:
packets: received 1045, sent 25782
bytes: received 123094, sent 1706886
drops: illegal VLAN 0, illegal length 0
PW: neighbor 10.20.0.3, PW ID 107, state is up ( established )
PW class not set, XC ID 0xc0000004
Encapsulation MPLS, protocol LDP
Source address 124.7.227.20
PW type Ethernet, control word disabled, interworking none
PW backup disable delay 0 sec
Sequencing not set
PW Status TLV in use
MPLS Local Remote
Label 16022 45285
Group ID 0x4000100 0x0
Interface GigabitEthernet0/0/0/1.607 unknown
MTU 1546 1546
Control word disabled disabled
PW type Ethernet Ethernet
VCCV CV type 0x2 0x2
(LSP ping verification) (LSP ping verification)
VCCV CC type 0x6 0x2
(router alert label) (router alert label)
(TTL expiry)
Incoming Status (PW Status TLV):
Status code: 0x0 (Up) in Notification message
Outgoing Status (PW Status TLV):
MIB cpwVcIndex: 3221225476
Create time: 19/06/2013 16:23:08 (00:02:30 ago)
Last time status changed: 19/06/2013 16:25:28 (00:00:10 ago
Interworking IPv4:
Group ASR-G2, XC A-G2, state is up; Interworking IPv4
MTU 1546; XC ID 0x840004; interworking IPv4
Statistics:
packets: received 1045, sent 25780
bytes: received 123094, sent 1706750
PW type IP, control word disabled, interworking IPv4
Sequencing not set
MPLS Local Remote
Label 16022 45280
MTU 1546 1546
PW type IP IP
(TTL expiry)
Create time: 19/06/2013 14:16:02 (02:04:47 ago)
Last time status changed: 19/06/2013 15:18:07 (01:02:41 ago)
Statistics:
packets: received 25780, sent 1045
bytes: received 1706750, sent 123094
Appreciate your help!
Darshak
Solved! Go to Solution.
sorry. necro posting. cisco page loading slow today.
I recommend you to create PW Classes:
7600 Series
Router(config)#pseudowire-class TESTRouter(config-pw-class)#encapsulation mpls
Router(config-pw-class)#interworking ?
ethernet Ethernet interworking
ip IP interworking
vlan VLAN interworking
Router(config-pw-class)#internetworking ethernet
And call above in the interface
Router(config-if)# xconnect
pw-class TEST
ASR9k SeriesRP/0/RSP0/CPU0:router# configure
RP/0/RSP0/CPU0:router(config)# l2vpn
RP/0/RSP0/CPU0:router(config-l2vpn)# pw-class TEST
RP/0/RSP0/CPU0:router(config-l2vpn-pwc)# encapsulation mpls
RP/0/RSP0/CPU0:router(config-l2vpn-pwc-encap-mpls)# transport-mode ethernet
RP/0/RSP0/CPU0:router(config-l2vpn-pwc-encap-mpls)# exit
RP/0/RSP0/CPU0:router(config-l2vpn-pwc-encap)# exit
RP/0/RSP0/CPU0:router(config-l2vpn-pwc)# exit
RP/0/RSP0/CPU0:router(config-l2vpn)# xconnect group TESTGROUP
RP/0/RSP0/CPU0:router(config-l2vpn-xc)# p2p TESTP2P
RP/0/RSP0/CPU0:router(config-l2vpn-xc-p2p)# neighbor
pw-id RP/0/RSP0/CPU0:router(config-l2vpn-xc-p2p-pw)# pw-class TEST
RP/0/RSP0/CPU0:router(config-l2vpn-xc-p2p-pw)# exit
RP/0/RSP0/CPU0:router(config-l2vpn-xc-p2p)# interface TenGigE0/0/0/0.40 //Example
Recommended:
L2VPN on ASR9k
Regards.
Please don't forget to rate helpful posts.
Hello Samil,
Thanks for the response.
As I mentioned earlier, VC stays up in all the cases. I tried VCtype 5 (Ethernet) and VCtype4 (Ethernet Vlan). I beleive it should be VC type 4, since im using vlan encapsulation on both attachmet circuits. But there is no communication between CE's.
It starts working after configuring Interworking IP on both ends, which removes the layer2 header while sending the payload across the pseudowire.
Darshak
Hello everyone,
I got this solved. I applied " rewrite ingress tag pop..." command on the AC interface. Below is the working configuration.
XR Config:
interface GigabitEthernet0/0/0/1.900609 l2transport
encapsulation dot1q 900 second-dot1q 609
rewrite ingress tag pop 2 symmetric
mtu 1522
l2vpn
pw-class MPLS
encapsulation mpls
transport-mode vlan
xconnect group ASR-J2
p2p ASR-J2
neighbor 10.10.10.255 pw-id 109
pw-class MPLS
IOS Config:
interface G0/1.609
xconnect 124.7.227.20 109 encapsulation mpls
What I observed is the difference in the L2 header size calculation. Without the "rewrite" command, XR is calculating L2 header size as 14 bytes without taking the double tag (extra 8 bytes) in consideration. So to get the payload size as 1500 bytes, i applied 1514 bytes on the interface. This matched with the remote end device MTU 1500. But there is no communication between CE.
After applying "rewrite ingress tag pop2 symmetric" command, it does consider the extra bytes as well. I had to set the MTU as 1522 to get the payload size as 1500. Now the CE is able to commmunicate with each other. I tested with IOS and JUNOS on the remote end, the behavior remains the same.
"rewrite ingress tag pop2 symmetric" removes the vlan tags (both outer and inner) while sending the packet across MPLS pseudowire and add both tags back while sending to Attachment circuit.
So here are my questions ,
Appreciate your response.
Darshak
because IOS pops the tage by default and XR does not.
on XR interface.. you have 2 dot1Q tags so with rewrite POP 2 symmetric
you are removing tags when sending to Core and adding them back when going towards AC side
Thanks Satish,
"because IOS pops the tage by default and XR does not. "
So the Packets are carried through the MPLS pseudowire with native ethernet header (14 bytes SA + DA + Ethertype). Vlan Tags will be stripped out.
Darshak
Thats correct...the core wont have any dot1q tags
Hello ALL,
by any chance does any one have this configuration working between Junos and Cisco 7600 with the double tag
