Power on new RSP880 at ASR9K
Moh Ka
Hi Expertise,
i will power on new RSP880 at ASR9K, So what's default/current ios release on that RSP
9 Replies 9
Eddie Chami
That would be 5.3.3 Moh.
Eddie.
Thanks Eddie, can u guide me with needed files to upgrade release to 5.3.3
ASR9K-iosxr-px-5.3.3-bridge_smus
Mo, which release is the RP on now? is it running XR or it didn't come with XR installed? All you need is the you don't need ASR9K-iosxr-px-5.3.3-bridge_smus.
You just need the 5.3.3.TAR, there is one with k9 and one without it, download your preferred and just do an update. If you want to learn more about automating upgrades take a look at the following:
https://supportforums.cisco.com/document/12747091/cisco-software-managercsm-v32-now-cco
Eddie.
thx Eddie, it's working now with 5.3 and need to upgrade to 5.3.3, so is tar file is enough.
Yes easy one. Download ASR9K-iosxr-px-K9-5.3.3.tar or ASR9K-iosxr-px-5.3.3.tar
1) untar it
2) put it on your ftp server
3) From the router do an install add source ftp://user:pass@ipadd/directory/ mini.5.3.3.pie mpls.5.3.3.pie etc.. activate
Install sheet cheat if you need it:
https://supportforums.cisco.com/document/12440491/ios-xr-install-upgrade-cheat-sheet
Eddie.
Hi Eddie,
when i boot the RSP from the first time it logged in to ROMMON, i used below steps but i don't know right mini file to use?
unset BOOT
unset TFTP_FILE
sync
unset BOOT_DEV_SEQ_OPER
unset MIRROR_ENABLE
sync
priv
diswd
IP_ADDRESS=192.168.1.241
IP_SUBNET_MASK=255.255.255.0
DEFAULT_GATEWAY=192.168.1.254
TFTP_RETRY_COUNT=4
TFTP_TIMEOUT=6000
TFTP_CHECKSUM=1
TFTP_SERVER=192.168.1.11
TFTP_MGMT_INTF=0
TFTP_BLKSIZE=1400
TURBOBOOT=on,disk0,format
sync
If you are turbobooting, you boot the mini vm file (asr9k-mini-px.vm-5.3.3).
See https://supportforums.cisco.com/document/123576/asr9000xr-understanding-turboboot-and-initial-system-bring
Thanks Mark,
I get the problem, it was when using 5.2.2 mini-vm and solved when using 5.3.3.
Moh Ka
I found below table for new one
Table 5.       Ordering Information
Product Description
Supported Software Release
Part Number
ASR 9000 Route Switch Processor 880 for packet transport
Cisco IOS XR Software Release 5.3.0 and later
A9K-RSP880-TR
ASR 9000 Route Switch Processor 880 for packet transport, spare
A9K-RSP880-TR =
ASR 9000 Route Switch Processor 880 for service edge
A9K-RSP880-SE
ASR 9000 Route Switch Processor 880 for service edge, spare
Cisco IOS-XR Software Release 5.3.0 and later
A9K-RSP880-SE =
http://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/datasheet-c78-733763.html
SO, the quetion now is release 5.3.0 supporting 100G LC, or need upgrade to 5.3.3
