Redistribute OSPF E1 route to BGP vpnv4
Hi everyone,
I have OSPF as a CE to PE which is up and all looks good, my PE (ASR 9001) has a load of prefixs:
RP/0/RSP0/CPU0:POP-01-PE1#sh ip route vrf A
O*E1 0.0.0.0/0 [1172/51] via 172.16.214.231, 16:54:21, Bundle-Ether10.214
               [1172/51] via 172.16.214.232, 16:54:21, Bundle-Ether10.214
O    172.201.0.0/16 [1172/41] via 172.16.214.231, 16:54:21, Bundle-Ether10.214
                   [1172/41] via 172.16.214.232, 16:54:21, Bundle-Ether10.214
O    172.203.0.0/16 [1172/82] via 172.16.214.231, 15:31:36, Bundle-Ether10.214
                   [1172/82] via 172.16.214.232, 15:31:36, Bundle-Ether10.214
O    172.16.200.0/24 [1172/82] via 172.16.214.231, 15:31:36, Bundle-Ether10.214
O    172.16.201.0/24 [1172/82] via 172.16.214.231, 15:31:36, Bundle-Ether10.214
O    172.16.211.0/24 [1172/41] via 172.16.214.231, 16:54:21, Bundle-Ether10.214
O    172.16.212.0/24 [1172/41] via 172.16.214.231, 16:54:21, Bundle-Ether10.214
O    172.16.213.0/24 [1172/41] via 172.16.214.231, 16:54:21, Bundle-Ether10.214
C    172.16.214.0/24 is directly connected, 3w0d, Bundle-Ether10.214
L    172.16.214.254/32 is directly connected, 3w0d, Bundle-Ether10.214
O    172.16.215.0/24 [1172/41] via 172.16.214.231, 16:54:21, Bundle-Ether10.214
O    172.16.230.0/29 [1172/42] via 172.16.214.231, 15:31:36, Bundle-Ether10.214
                     [1172/42] via 172.16.214.232, 15:31:36, Bundle-Ether10.214
O    172.16.231.0/24 [1172/42] via 172.16.214.231, 16:54:21, Bundle-Ether10.214
                     [1172/42] via 172.16.214.232, 16:54:21, Bundle-Ether10.214
O    172.16.233.0/24 [1172/82] via 172.16.214.231, 15:31:36, Bundle-Ether10.214
O    172.16.234.0/24 [1172/82] via 172.16.214.231, 15:31:36, Bundle-Ether10.214
I am then redistributing OSPF into BGP:
vrf A
  rd 57:1
  address-family ipv4 unicast
   redistribute ospf 1 match internal external 1 metric 20
I can see all the intra area routes going into BGP but the E1 default isn't :
RP/0/RSP0/CPU0:POP-01-PE1#sh bgp vpnv4 unicast
Status codes: s suppressed, d damped, h history, * valid, > best
              i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network            Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 57:1 (default for vrf A)
*> 172.201.0.0/16      172.16.214.231          20         32768 ?
* i                   1.1.1.3          20    1720      0 ?
*> 172.203.0.0/16      172.16.214.231          20         32768 ?
*> 172.16.200.0/24    172.16.214.231          20         32768 ?
*> 172.16.201.0/24    172.16.214.231          20         32768 ?
*> 172.16.211.0/24    172.16.214.231          20         32768 ?
*> 172.16.212.0/24    172.16.214.231          20         32768 ?
*> 172.16.213.0/24    172.16.214.231          20         32768 ?
*>i172.16.214.0/24    1.1.1.3          20    1720      0 ?
*> 172.16.215.0/24    172.16.214.231          20         32768 ?
*> 172.16.230.0/29    172.16.214.231          20         32768 ?
*> 172.16.231.0/24    172.16.214.231          20         32768 ?
*> 172.16.233.0/24    172.16.214.231          20         32768 ?
*> 172.16.234.0/24    172.16.214.231          20         32768 ?
*> 172.16.251.0/24    172.16.214.231          20         32768 ?
*> 172.16.253.0/24    172.16.214.231          20         32768 ?
*> 172.27.224.0/24    0.0.0.0                  0         32768 ?
Can someone help me with this please
Harold Ritter
BGP does not allow the redistribution of the default route by default. You need to use the "default-information originate" to change the default behavior.
vrf A
  rd 57:1
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold Ritter
vrf A
  rd 57:1
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
