01-18-2018 12:42 AM - edited 03-01-2019 03:21 PM
Hi!
Could you please point me to document which describes differences between 880 RSPs? TR vs SE are pretty clear, but I confused a bit with LT version. Seems it is newer than TR/SE, but seems it lacks some features/options. Usually BRKARC-2003 answers all such questions, but few last sessions have no any info on that.
Thanks in advance
09-12-2018 02:49 AM
The only difference between the -TR and -SE on RP/RSP is how much RAM the RP CPU has.
If you need features that are only supported on -SE line cards (e.g.: PWHE), but don't run BNG and don't have a huge routing table, you can use -TR RP|RSP with -SE line cards.
09-12-2018 04:21 AM
09-12-2018 04:30 AM
That is also supported.
06-11-2020 03:05 AM - edited 06-11-2020 03:06 AM
Hi Aleksandar,
What about in ASR 9006 mixing RPS880-TR with RSP880-LT-TR is supported or not? İs it possible to redundant these two types RPS?
thanks
06-11-2020 10:07 AM
