Can anyone share some details on the Segment routing implementation in XR 5.2.0?
It seems that only Nodal segments gets label allocated. If Adjacency segments do get local labels, how is this information viewed?
I've configured this in addition to the normal isis ipv4 stuff:
router isis core
address-family ipv4 unicast
segment-routing mpls
interface loopback 0
prefix-sid index 4000
My topology is two P-routers with dual links between them, and two PE-routers dual-homed to the P-routers.
MPLS-forwading between loopbacks works fine based on the SR-assigned and-distributed labels.
My lab is running on IOS XRv 5.2.0
Another slightly related question: Is SR remote-lfa (draft-francois-segment-routing-ti-lfa-00) implemented (or getting implemented) yet?
/Mikkel
