Set PPPoE interface description from Radius
ndebrigode
Hi all,
Is it possible to set a description on a PPPoE interface with Radius on an IOS-XR ?
I can not find information.
On IOS-XE, I do like this in my radius, but it does not work with IOS-XR :
"lcp:interface-config=description <MY BEAUTIFUL DESCRIPTION>"
Thanks in advance.
BR.
Nick
Aleksandar Vidakovic
If it's not listed here, we very likely don't support it:
https://community.cisco.com/t5/service-providers-documents/asr9k-bng-radius-and-coa-deployment-guide/ta-p/3155211
Could you please explain the use case for this? Maybe there's an alternative method to achieve the same functionality.
/Aleksandar
Hi Aleksandar,
Use case, its simply when I type "show interface description", example :
On IOS-XE :
#sh int description
Interface Status Protocol Description
[... snip ... ]
Vi2.9 up up LIGNE *** username1@realm ***
Vi2.10 up up LIGNE *** username2@realm ***
[... snip ... ]
and on IOS-XR its empty, its all :
#sh int description
Thu Jan 17 11:06:33.763 CET
[... snip ... ]
BE19.1799.pppoe8 up up
[... snip ... ]
it's not blocking, it's just that I like all my interfaces to be named correctly ;)
BR.
Nick
hi Nick,
that's a very neat approach, but we don't support it unfortunately on XR BNG. The full list of supported radius attributes is always included in the BNG config guide (e.g. https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-4/bng/configuration/guide/b-bng-cg-asr9000-64x/b-bng-cg-asr9000-64x_appendix_01011.html).
You would have to use a script on XR that parses the output of "sh subscriber session all detail". On 64-bit XR this can be done easily using Python. Python is supported in the linux shell, you can invoke it using the "run" command, e.g.
"run  harrdisk:/my_script.py"
From within Python you can use this kind of sequence to execute the XR CLI command and capture the output into an array:
command = '/pkg/bin/xr_cli \"show subscriber session all\"'
output = subprocess.check_output(command, shell=True)
out_array = output.split('\n')
Hope this helps,
/Aleksandar
Hi Aleksandar,
Thank for this example, it's interesting.
BR.
Nick
