SPA-1X10GE-WL-V2 not working
TarcisioSeanet
Hello.
I'm having problems with a SPA-1X10GE-WL-V2 on my Cisco ASR 1002x.
I currently have two SPA-1X10GE-L-V2 and a SPA-1X10GE-WL-V2 but the WL is not working.
I researched and found the command to force the LAN mode, because without, it wasn't linking with my Huawei S6720.
Once I got it to link with my switch, I put it on a Port-Channel, with the other. But the LACP haven't worked either.
I thought it was incompatibility with the other two modules, so for a test I made another Port-Channel with just that one port. It didn't worked either.
So finally i just decide to put some vlans on the port and tried use, but then again, it didn't worked.
My final thought is that this module is simply not working. Do I have some troubleshooting to do with it? Another test? Some debbuging command for verifiyng the health of the SPA module?
Many thanks in advance.
balaji.bandi
Is this module recognised on the device ?
can you post show modules and check the on the device log , do you see any information ? what IOS XE code running ?
what SFPs have you tried ?
BB
Yes, it does recognize the board, it is a different version than the others, newer.
I didn't see anything on log. It just gets the interface UP then nothing happens. Just it doesn't work. No errors.
The SFP is a Cisco branding one, model XFP-10GER-192IR+. It works on the other two boards, the SPA-1X10GE-L-V2.
