03-28-2025 06:51 AM
Hello.
I'm having problems with a SPA-1X10GE-WL-V2 on my Cisco ASR 1002x.
I currently have two SPA-1X10GE-L-V2 and a SPA-1X10GE-WL-V2 but the WL is not working.
I researched and found the command to force the LAN mode, because without, it wasn't linking with my Huawei S6720.
Once I got it to link with my switch, I put it on a Port-Channel, with the other. But the LACP haven't worked either.
I thought it was incompatibility with the other two modules, so for a test I made another Port-Channel with just that one port. It didn't worked either.
So finally i just decide to put some vlans on the port and tried use, but then again, it didn't worked.
My final thought is that this module is simply not working. Do I have some troubleshooting to do with it? Another test? Some debbuging command for verifiyng the health of the SPA module?
Many thanks in advance.
03-28-2025 10:05 AM
Is this module recognised on the device ?
can you post show modules and check the on the device log , do you see any information ? what IOS XE code running ?
what SFPs have you tried ?
03-28-2025 11:02 AM
Yes, it does recognize the board, it is a different version than the others, newer.
I didn't see anything on log. It just gets the interface UP then nothing happens. Just it doesn't work. No errors.
The SFP is a Cisco branding one, model XFP-10GER-192IR+. It works on the other two boards, the SPA-1X10GE-L-V2.
