Static route vrf VRF to Global (vrf default)
Hello.
Trying to route traffic from vrf to global (at 7600 this possible).
Trying to route traffic between:
RP/0/RSP1/CPU0:zip#sh run int tenGigE 0/0/0/0.173
Wed Jan 23 18:49:55.235 UTC
interface TenGigE0/0/0/0.173
vrf kappa
ipv4 address 10.0.0.2 255.255.255.252
encapsulation dot1q 173
RP/0/RSP1/CPU0:zip#sh run int tenGigE 0/0/0/0.5
Wed Jan 23 18:50:02.285 UTC
interface TenGigE0/0/0/0.5
ipv4 address 8.8.8.1 255.255.255.0
encapsulation dot1q 5
Have this loopbacks:
RP/0/RSP1/CPU0:zip#sh run int loopback 0
Wed Jan 23 18:50:38.665 UTC
interface Loopback0
ipv4 address 17.17.191.6 255.255.255.255
RP/0/RSP1/CPU0:zip#sh run int loopback 1
Wed Jan 23 18:50:39.795 UTC
interface Loopback1
vrf kappa
ipv4 address 17.17.191.7 255.255.255.255
Add static routes:
RP/0/RSP1/CPU0:zip#sh run router static
Wed Jan 23 18:52:36.308 UTC
router static
address-family ipv4 unicast
  10.0.0.0/30 vrf kappa Loopback1
vrf kappa
   0.0.0.0/0 vrf default Loopback0
And view routes:
RP/0/RSP1/CPU0:zip#sh route
Wed Jan 23 18:52:26.039 UTC
Codes: C - connected, S - static, R - RIP, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
       U - per-user static route, o - ODR, L - local, G  - DAGR
       A - access/subscriber, - FRR Backup path
Gateway of last resort is not set
L    2.2.2.2/32 is directly connected, 2d00h, Loopback100
C    8.8.8.0/24 is directly connected, 04:03:47, TenGigE0/0/0/0.5
L    8.8.8.1/32 is directly connected, 04:03:47, TenGigE0/0/0/0.5
S    10.0.0.0/30 is directly connected, 00:00:37, Loopback1 (nexthop in vrf kappa)
L    17.17.191.6/32 is directly connected, 04:41:28, Loopback0
RP/0/RSP1/CPU0:zip#sh route vrf kappa
Wed Jan 23 18:52:29.031 UTC
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*   0.0.0.0/0 is directly connected, 00:00:05, Loopback0 (nexthop in vrf default)
C    10.0.0.0/30 is directly connected, 04:45:11, TenGigE0/0/0/0.173
L    10.0.0.2/32 is directly connected, 04:45:11, TenGigE0/0/0/0.173
L    17.17.191.7/32 is directly connected, 02:32:56, Loopback1
But this doesn't work:
RP/0/RSP1/CPU0:zip#ping vrf kappa 8.8.8.1
Wed Jan 23 18:54:01.004 UTC
Sending 5, 100-byte ICMP Echos to 8.8.8.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
dpothier
hi Stanislav,
Afaik that feature is coming in the 4.3.1 It's called "Interafi import (global import) feature" Release.
Details as follows:
Configuration CLI: The following two new CLIs are defined.
The user can configure following under global VRF config to enable importing default-VRF routes to VRF foo.
          import from default-vrf route-policy
Example:
          vrf foo
            import from default-vrf route-policy mypolicyimport
(ii) The user can configure following under global VRF config to enable exporting VRF foo routes into the default-VRF table.
          export to default-vrf route-policy
Example:
          vrf foo
            export to default-vrf route-policy mypolicyexport
These above configurations are per address-family (ipv4 unicast and ipv6 unicast). The new config coexists with the existing VPN import config based on route-targets and route-policy.
Example: When all import/export configurations are enabled:
          vrf foo
            import route-policy myvpnimportpolicy
            import from default-vrf route-policy passall
            import route-target
             1:1
             2:2
            export route-policy myvpnexportpolicy
            export to default-vrf route-policy passall
            export route-target
             2:2
             4:4
             5:1
          end
regards,
David
Hi David,
i've been looking for a similar solution and this appears to be what we've been looking for.
So if i'm to understand correctly what you've said, this way we'll be able to "automate" the import/export of routes
from vrf->global and vice versa, correct?
Could we then apply the same logic to a hub and spoke internet access vpn, where we have the VPN_to_Internet hub vrf that
will eventually leak/export customer VPN routes to default-vrf and import only 0/0 (default route)? This way we can "automate" even more export of customer routes to the global table, and for all customer VPNs with internet access, only use standard import/export or RTs with this hub vrf?
Themis
