09-29-2014 02:57 AM
Got some issues with IPSLA/Track on ASR100v ver. 5.2.0. The IPSLA seems to work:
RP/0/0/CPU0:XRv2#show ipsla statistics Mon Sep 29 09:43:36.777 UTC Entry number: 1 Modification time: 09:37:01.893 UTC Mon Sep 29 2014 Start time : 09:37:01.913 UTC Mon Sep 29 2014 Number of operations attempted: 6 Number of operations skipped : 1 Current seconds left in Life : Forever Operational state of entry : Active Operational frequency(seconds): 60 Connection loss occurred : FALSE Timeout occurred : FALSE Latest RTT (milliseconds) : 1 Latest operation start time : 09:43:02.149 UTC Mon Sep 29 2014 Next operation start time : 09:44:02.149 UTC Mon Sep 29 2014 Latest operation return code : OK RTT Values: RTTAvg : 1 RTTMin: 1 RTTMax : 1 NumOfRTT: 1 RTTSum: 1 RTTSum2: 1
But TRACKing doesnt:
RP/0/0/CPU0:XRv2#show track track1 Mon Sep 29 09:44:34.733 UTC Track track1 Response Time Reporter 1 reachability ipsla operation not in progress RP/0/0/CPU0:XRv2#show track track1 bri Mon Sep 29 09:44:38.782 UTC Track Object Parameter Value -------------------------------------------------------------------------------------------------------- track1 IPSLA Operation 1 reachability Down RP/0/0/CPU0:XRv2#
And the debug info:
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (handle_ot_mgd_timer_expired) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]:(handle_ot_mgd_timer_expired) : RTR_SHM_POLL_INTERVAL expired RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: RTR_SHM_POLL_INTERVAL timer triggered for track : track1 RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering(ot_rtr_read_shm_after_timer_expired) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: (ot_rtr_read_shm_after_timer_expired) : track_name = track1 RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (hash_db_get_track_item) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (stop_ot_timer) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (shm_read_ipsla_stats) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (track_rtr_init) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Failed to initialize ipsla shared mem RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Corresponding ipsla operation with op id 1 is not running RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: latestReturnCode = 0, latestResponseTime = 0 RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (object_tracking_set_track_state_in_sysdb) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: (object_tracking_set_track_state_in_sysdb) : track track1 state Unknown RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (hash_db_get_track_item) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: (object_tracking_set_track_state_in_sysdb) : track track1 sysdb state Unknown RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (get_timer_ctx) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (stop_ot_timer) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (get_timer_ctx) : RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (set_ot_shm_poll_wait_timer) : RP/0/0/CPU0:Sep 29 09:37:24.112 : syslog_dev[70]: object_tracking[318]: Unable to find window ipsla_ot
All states under for tracking under VRRP/ROUTE shows that tracked object is DOWN. This was the same as for 5.1.1
10-10-2014 06:39 AM
can you share your ipsla config please, I would like to see what you are tracking.
there is a known DDTS that tracks the requirement of route reachability verification that you may be hitting: CSCua95880
xander
10-17-2014 01:08 AM
Thank you xander,
here is the cfg you requested:
10-17-2014 04:58 AM
thanks for that config. I used it in my setup to verify ifs and hows.
I am running XR 512 on real hardware (I think you have an XRv there based on the name right?) and I was hoping to see the problem, but it worked straight up for me!
RP/0/RSP0/CPU0:A9K-BNG#show vrrp
Fri Oct 17 07:46:38.677 EDT
IPv4 Virtual Routers:
A indicates IP address owner
| P indicates configured to preempt
Interface vrID Prio A P State Master addr VRouter addr
Gi0/0/0/0.10 10 95 P Master local 192.168.10.10
RP/0/RSP0/CPU0:A9K-BNG#RP/0/RSP0/CPU0:Oct 17 07:47:22.713 : object_tracking[356]: %SERVICES-OT-6-TRACK_INFO : track TRACK_ICMP state Track_Up
I can bring it down by removing the probe host:
RP/0/RSP0/CPU0:A9K-BNG#RP/0/RSP0/CPU0:Oct 17 07:46:08.650 : object_tracking[356]: %SERVICES-OT-6-TRACK_INFO : track TRACK_ICMP state Track_Down
That means to me that it is either one of the 3 things:
you are running into a bug in the XRv code that you have, or XRv has a deficiency in relation to running vrrp with ipsla probes or maybe the pinged/probed host configured is not reachable from inside the Xrv?
Any case, the config is good.
I would recommend playing with a different version maybe if possible and meanwhile I'll check if this can be run on Xrv in general.
Also run the VRRP on a signle node and see if that makes a difference whether the VRRP is messing up the probe, dunno but worth the try.
regards
xander
10-20-2014 01:19 AM
We have also XR 5.1.2 on ASR9001, the config works on that device but only for the first time after you assign tracking object to VRRP instance.
The ouput:
RP/0/RSP0/CPU0:ASR9001#sho vrrp det
Thu Oct 9 07:45:51.859 UTC
Bundle-Ether3.11 - IPv4 vrID 11
State is Master
9 state changes, last state change 6d22h
State change history:
Sep 29 15:32:45.980 UTC Init -> Backup Delay timer expired
Sep 29 15:32:49.570 UTC Backup -> Master Master down timer expired
Sep 29 16:16:18.939 UTC Master -> Init Interface Down update
Oct 2 09:04:59.379 UTC Init -> Backup Delay timer expired
Oct 2 09:05:02.971 UTC Backup -> Master Master down timer expired
Last resign sent: Sep 29 16:16:18.941 UTC
Last resign received: Never
Virtual IP address is X.X.X.X
Virtual MAC address is 0000.5E00.010b, state is active
Master router is local
Version is 2
Advertise time 1 secs
Master Down Timer 3.589 (3 x 1 + (151 x 1/256))
Minimum delay 1 sec, reload delay 5 sec
Current priority 105
Configured priority 105, may preempt
minimum delay 180 secs
Authentication enabled, string "11"
Tracked items: 1/1 up: 0 decrement
Object name State Decrement
TRACK_OBJECT Up 10
RP/0/RSP0/CPU0:ASR9001#show track TRACK_OBJECT
Thu Oct 9 07:46:44.946 UTC
Track TRACK_OBJECT
Response Time Reporter 253 reachability
2 changes, last change 07:45:40 UTC Thu Oct 09 2014
Latest operation return code: SockBindError
Latest RTT (millisecs) : 0
RP/0/RSP0/CPU0:ASR9001#sho ipsla statistics 253
Thu Oct 9 07:46:28.506 UTC
Entry number: 253
Modification time: 07:41:27.301 UTC Thu Oct 09 2014
Start time : 07:41:27.309 UTC Thu Oct 09 2014
Number of operations attempted: 250
Number of operations skipped : 52
Operational frequency(seconds): 1
Latest RTT (milliseconds) : Unknown
Latest operation start time : 07:46:28.310 UTC Thu Oct 09 2014
Next operation start time : 07:46:29.310 UTC Thu Oct 09 2014
Latest operation return code : SockBindError
RTT Values:
RTTAvg : 0 RTTMin: 0 RTTMax : 0
NumOfRTT: 0 RTTSum: 0 RTTSum2: 0
If you assign the tracking object for VRRP when the destination of ipsla is unreachable, it will be marked as down and wont change even if tracking will be recovered ;]
5.1.2 with no Service Packs, don't have access to downloads yet.
