tompl1985
Beginner
TRACK RTR - track sysdb state unkown - ASR1000v
Got some issues with IPSLA/Track on ASR100v ver. 5.2.0. The IPSLA seems to work:
RP/0/0/CPU0:XRv2#show ipsla statistics
Mon Sep 29 09:43:36.777 UTC
Entry number: 1
    Modification time: 09:37:01.893 UTC Mon Sep 29 2014
    Start time       : 09:37:01.913 UTC Mon Sep 29 2014
    Number of operations attempted: 6
    Number of operations skipped  : 1
    Current seconds left in Life  : Forever
    Operational state of entry    : Active
    Operational frequency(seconds): 60
    Connection loss occurred      : FALSE
    Timeout occurred              : FALSE
    Latest RTT (milliseconds)     : 1
    Latest operation start time   : 09:43:02.149 UTC Mon Sep 29 2014
    Next operation start time     : 09:44:02.149 UTC Mon Sep 29 2014
    Latest operation return code  : OK
    RTT Values:
      RTTAvg  : 1          RTTMin: 1          RTTMax : 1
      NumOfRTT: 1          RTTSum: 1          RTTSum2: 1
But TRACKing doesnt:
RP/0/0/CPU0:XRv2#show track track1
Mon Sep 29 09:44:34.733 UTC
Track track1
        Response Time Reporter 1 reachability
        ipsla operation not in progress
RP/0/0/CPU0:XRv2#show track track1 bri
Mon Sep 29 09:44:38.782 UTC
Track                            Object                                   Parameter        Value
track1                           IPSLA Operation 1                        reachability     Down
RP/0/0/CPU0:XRv2#
And the debug info:
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (handle_ot_mgd_timer_expired) :
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]:(handle_ot_mgd_timer_expired) : RTR_SHM_POLL_INTERVAL expired
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: RTR_SHM_POLL_INTERVAL timer triggered for track : track1
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering(ot_rtr_read_shm_after_timer_expired) :
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: (ot_rtr_read_shm_after_timer_expired) : track_name = track1
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (hash_db_get_track_item) :
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (stop_ot_timer) :
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (shm_read_ipsla_stats) :
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (track_rtr_init) :
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]:  Failed to initialize ipsla shared mem
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Corresponding ipsla operation with op id 1 is not running
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: latestReturnCode = 0, latestResponseTime = 0
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (object_tracking_set_track_state_in_sysdb) :
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: (object_tracking_set_track_state_in_sysdb) : track track1 state Unknown
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: (object_tracking_set_track_state_in_sysdb) : track track1 sysdb state Unknown
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (get_timer_ctx) :
RP/0/0/CPU0:Sep 29 09:37:24.112 : object_tracking[318]: Entering (set_ot_shm_poll_wait_timer) :
RP/0/0/CPU0:Sep 29 09:37:24.112 : syslog_dev[70]: object_tracking[318]: Unable to find window ipsla_ot
All states under for tracking under VRRP/ROUTE shows that tracked object is DOWN. This was the same as for 5.1.1
4 REPLIES 4
xthuijs
can you share your ipsla config please, I would like to see what you are tracking.
there is a known DDTS that tracks the requirement of route reachability verification that you may be hitting: CSCua95880
xander
Thank you xander,
here is the cfg you requested:
conf t
hostname XRv1
ipv4 access-list abf-track
10 permit any any nexthop track TRACK_ICMP 192.168.0.1
ipsla
 operation 253
  type icmp echo
   source address 192.168.10.1
   destination address 192.168.10.100
   frequency 10
  exit
 exit
 schedule operation 253
  start-time now
  life forever
exit
track TRACK_ICMP
type rtr 253 reachability
exit
interface gi0/0/0/4
description SW F1/0
no shut
interface gi0/0/0/4.10
encapsulation dot1q 10
ipv4 address 192.168.10.1/24
no shut
router vrrp
address-family ipv4
 vrrp 10
 addr 192.168.10.10
 prio 105
 track object TRACK_ICMP
thanks for that config. I used it in my setup to verify ifs and hows.
I am running XR 512 on real hardware (I think you have an XRv there based on the name right?) and I was hoping to see the problem, but it worked straight up for me!
RP/0/RSP0/CPU0:A9K-BNG#show vrrp
Fri Oct 17 07:46:38.677 EDT
IPv4 Virtual Routers:
                      A indicates IP address owner
                      | P indicates configured to preempt
Interface   vrID Prio A P State    Master addr     VRouter addr
Gi0/0/0/0.10   10   95   P Master   local           192.168.10.10
RP/0/RSP0/CPU0:A9K-BNG#RP/0/RSP0/CPU0:Oct 17 07:47:22.713 : object_tracking[356]: %SERVICES-OT-6-TRACK_INFO : track TRACK_ICMP state Track_Up
I can bring it down by removing the probe host:
RP/0/RSP0/CPU0:A9K-BNG#RP/0/RSP0/CPU0:Oct 17 07:46:08.650 : object_tracking[356]: %SERVICES-OT-6-TRACK_INFO : track TRACK_ICMP state Track_Down
That means to me that it is either one of the 3 things:
you are running into a bug in the XRv code that you have, or XRv has a deficiency in relation to running vrrp with ipsla probes or maybe the pinged/probed host configured is not reachable from inside the Xrv?
Any case, the config is good.
I would recommend playing with a different version maybe if possible and meanwhile I'll check if this can be run on Xrv in general.
Also run the VRRP on a signle node and see if that makes a difference whether the VRRP is messing up the probe, dunno but worth the try.
regards
xander
We have also XR 5.1.2 on ASR9001, the config works on that device but only for the first time after you assign tracking object to VRRP instance.
The ouput:
RP/0/RSP0/CPU0:ASR9001#sho vrrp det
Thu Oct  9 07:45:51.859 UTC
Bundle-Ether3.11 - IPv4 vrID 11
  State is Master
    9 state changes, last state change 6d22h
    State change history:
    Sep 29 15:32:45.980 UTC  Init     -> Backup   Delay timer expired
    Sep 29 15:32:49.570 UTC  Backup   -> Master   Master down timer expired
    Sep 29 16:16:18.939 UTC  Master   -> Init     Interface Down update
    Oct  2 09:04:59.379 UTC  Init     -> Backup   Delay timer expired
    Oct  2 09:05:02.971 UTC  Backup   -> Master   Master down timer expired
  Last resign sent:     Sep 29 16:16:18.941 UTC
  Last resign received: Never
  Virtual IP address is X.X.X.X
  Virtual MAC address is 0000.5E00.010b, state is active
  Master router is local
  Version is 2
  Advertise time 1 secs
    Master Down Timer 3.589 (3 x 1 + (151 x 1/256))
  Minimum delay 1 sec, reload delay 5 sec
  Current priority 105
    Configured priority 105, may preempt
      minimum delay 180 secs
  Authentication enabled, string "11"
    Tracked items: 1/1 up: 0 decrement
      Object name                State     Decrement
      TRACK_OBJECT    Up            10
RP/0/RSP0/CPU0:ASR9001#show track TRACK_OBJECT
Thu Oct  9 07:46:44.946 UTC
Track TRACK_OBJECT
        Response Time Reporter 253 reachability
        2 changes, last change 07:45:40 UTC Thu Oct 09 2014
        Latest operation return code: SockBindError
        Latest RTT (millisecs) : 0
RP/0/RSP0/CPU0:ASR9001#sho ipsla statistics 253
Thu Oct  9 07:46:28.506 UTC
Entry number: 253
    Modification time: 07:41:27.301 UTC Thu Oct 09 2014
    Start time       : 07:41:27.309 UTC Thu Oct 09 2014
    Number of operations attempted: 250
    Number of operations skipped  : 52
    Operational frequency(seconds): 1
    Latest RTT (milliseconds)     : Unknown
    Latest operation start time   : 07:46:28.310 UTC Thu Oct 09 2014
    Next operation start time     : 07:46:29.310 UTC Thu Oct 09 2014
    Latest operation return code  : SockBindError
    RTT Values:
      RTTAvg  : 0          RTTMin: 0          RTTMax : 0
      NumOfRTT: 0          RTTSum: 0          RTTSum2: 0
If you assign the tracking object for VRRP when the destination of ipsla is unreachable, it will be marked as down and wont change even if tracking will be recovered ;]
5.1.2 with no Service Packs, don't have access to downloads yet.
