trunk vrf
nwag_2009
I am trying to establish a trunked (static, bgp)vrf link between two routers, how do you go about creating this. Do you need to use subinterfaces, Can you send some config examples please?
Ruben Cocheno
You can have 2 types of setup:
For both scenarios you need setup the vrfs
ip vrf cust1
rd 1:1
ip vrf cust2
rd 1:2
1. Using a trunk
vlan 12
vlan 14
interface vlan 12
ip vrf forwarding cust1
ip address 172.16.12.1 255.255.255.0
interface vlan 14
ip vrf forwarding cust2
 ip address 172.16.14.1 255.255.255.0
2. Using SubInterfaces
interface FastEthernet0/0.12
 encapsulation dot1Q 12
interface FastEthernet0/0.14
 encapsulation dot1Q 14
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
One additional note; the "option 1" is for the 7600 or an IOS based device, for XR you would want to use the BVI method:
Define the "efp" (eg vlan trunk port)
int g 0/0/0/0.12 l2transport
encap dot1q 12
rewrite ingress tag pop 1 symmetric
Create a bridge group and link it to a BVI:
l2vpn
bridge group BLA
bridge-domain BLABLA
int g 0/0/0/0.12
routed interface BVI 10
int bvi 10
vrf cust1
ipv4 add 1.1.1.1 255.255.255.0
regards
xander
