Upgrade XR from 5.3.3 to 6.5.3
rosa
Hi all,
I'am going to upgrade my network from 5.3.3 to 6.5.3 XR version. Do i need some special SMU, or some special steps, or can i only install ADD all packages and them activate them ?
Many thx
tkarnani
Hi Rosa
As long as you are upgrading to 6.5.3 32bit XR, the upgrade procedure should be the standard.
admin install add harddisk:/filename.tar
admin install activate *6.5.3*
Just be sure the hardware is supported
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-5/general/release/notes/b-release-notes-asr9k-653.html
if you have trident based cards, it will not boot with 653
if you have typhoon and higher you will be fine
https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116726-qanda-product-00.html
tkarnani
Hi Rosa
Many thx for quickly response.
Upgrade without any issue. i did not have any of those HW. Was replaced before.
Thx
