XR BGP default conditional advertisng
cisco_lad2004
Level 5
Level 5
Dear all,
I am working on CGN setup, using 2 vrfs IN and OUT. For the inside, I annonce the default route wich point to the ServiceApp.
My challenge is that I only want to annonce this default if the OUT vrf has a default route pointing to global next hop, or if the next hop interface is actually up.
I am trying to avoid, blackhling CGN natted traffic in case next hop is no longer available.
It seems that advertise-map command is no longer supported, and even if it was how can I track a route which is in another vrf ?
Any thoughts?
TIA
/Samir
cisco_lad2004
Level 5
Level 5
Decided to deploy a simple method. Use same bundle or physical port for both IN and OUT traffic, this means if port goes down no traffic would be routed to this CGN enabled PE. Traffic would be routed to redundant node.
Initial problem wa sthat if outbound port fails, CGN enabled node would still announce a default route to its vrf, resulting in a blackhole.
/Sam
