XR Command for RIB-Failure
visehgal
I was trying to search through IOS-XR documentation for equivalent command of show IP BGP rib-failure in XR but could not find one.
Do you know if there is any equivalent command ?
Sakthi Malli
I don't believe we have the same command in XR. However any rib-failed route will have "r"  appended in the output of "show bgp vpnv4 unicast" or equivalent commands to indicate a "rib-failure"
Sakthi Malli
also the show bgp <prefix> detail will provide some extra details on the prefix, whether it was imported, or not, advertised and to whom.
the rib-failure as such I am not aware of having a direct equivalent indeed.
cheers!
xander
