XR VM fails to start on NC57-36H6D-S
ThomasD86
We're trying to get this LC working in an NCS5508 chassis. We upgraded the fabric cards and fan trays to the second-generation version and installed the LC in the chassis alongside the older NC55-18H18F.
The fan trays and fabric cards are working OK, the 18H18F is working as well but it seems there's an issue with installing XR onto the LC:
0/1/ADMIN0:Oct 14 22:38:08.890 CEST: inst_agent[2105]: %INFRA-INSTAGENT-4-XR_PART_PREP_RESP : SDR/XR partition preparation completed successfully
0/1/ADMIN0:Oct 14 22:38:26.214 CEST: vm_manager[2162]: %INFRA-VM_MANAGER-4-INFO : Info: vm_manager started VM default-sdr--1
LC/0/1/CPU0:Oct 14 22:38:59.576 CEST: fia_driver[294]: BCM-DPA: Optics Driver connection not established yet,Allow couple of min to establish
LC/0/1/CPU0:Oct 14 22:39:21.843 CEST: processmgr[51]: %OS-SYSMGR-6-INFO : pm_audit_tier: ack not received for sysmgr shutdown event from :bfd_agent(256)
LC/0/1/CPU0:Oct 14 22:39:21.964 CEST: syslog_dev[111]: sdr_instagt[321] PID-2928: RL: waiting for completion of shutdown delay 30 secs, pending secs 3
LC/0/1/CPU0:Oct 14 22:39:21.964 CEST: sdr_instagt[321]: %INFRA-REBOOT_LIB-6-SHUTDOWN_DELAY : Waiting for completion of shutdown delay 30 secs, pending 3 secs
LC/0/1/CPU0:Oct 14 22:39:22.637 CEST: fia_driver[294]: %PLATFORM-OFA-6-INFO : NPU #0 Initialization Completed
LC/0/1/CPU0:Oct 14 22:39:24.964 CEST: syslog_dev[111]: sdr_instagt[321] PID-2928: RL: Reboot initiated with code 36, cause Reboot triggered by failed install operation reboot_timeout 30 shutdown delay 30
LC/0/1/CPU0:Oct 14 22:39:24.964 CEST: sdr_instagt[321]: %INFRA-REBOOT_LIB-5-REBOOT_INITIATED : Reboot initiated with code:36 cause:'Reboot triggered by failed install operation' reboot timeout:30 shutdown delay: 30
LC/0/1/CPU0:Oct 14 22:39:24.964 CEST: sdr_instagt[321]: %INFRA-REBOOT_LIB-5-REBOOT_STARTED : Started processing reboot request
LC/0/1/CPU0:Oct 14 22:39:24.964 CEST: syslog_dev[111]: sdr_instagt[321] PID-2928: RL: Shutdown initiated
LC/0/1/CPU0:Oct 14 22:39:24.965 CEST: sdr_instagt[321]: %INFRA-REBOOT_LIB-6-INVMGR_CONN_SUCCESS : Connected successfully to invmgr
LC/0/1/CPU0:Oct 14 22:39:24.965 CEST: syslog_dev[111]: sdr_instagt[321] PID-4185: Query the node to be reloaded
LC/0/1/CPU0:Oct 14 22:39:24.966 CEST: syslog_dev[111]: sdr_instagt[321] PID-4185: Invmgr : Obj not found  nobjs = 0
LC/0/1/CPU0:Oct 14 22:39:24.968 CEST: syslog_dev[111]: sdr_instagt[321] PID-4185: sending stop hb
LC/0/1/CPU0:Oct 14 22:39:24.968 CEST: syslog_dev[111]: sdr_instagt[321] PID-4185: Cause: Reboot triggered by failed install operation
LC/0/1/CPU0:Oct 14 22:39:24.968 CEST: syslog_dev[111]: sdr_instagt[321] PID-4185: VM IP addr sent for reload 192.0.8.3
LC/0/1/CPU0:Oct 14 22:39:24.969 CEST: sdr_instagt[321]: %INFRA-REBOOT_LIB-6-SDRNM_INVOKED : SDR NM invoked to reload VM 192.0.8.3
0/1/ADMIN0:Oct 14 22:39:31.373 CEST: vm_manager[2162]: %INFRA-VM_MANAGER-4-INFO : Info: vm_manager brought down VM default-sdr--1
In the admin VM, the line card is displayed as operative:
admin show plat
Tue Oct 15 12:31:53.018 CEST
Location  Card Type               HW State      SW State      Config State
0/0       NC55-18H18F             OPERATIONAL   OPERATIONAL   NSHUT
0/1       NC57-36H6D-S            OPERATIONAL   OPERATIONAL   NSHUT
Looking at the logs however we see this output:
0/1/ADMIN0:Oct 15 03:43:38.401 : inst_agent[2105]: %INFRA-INSTAGENT-4-XR_PART_PREP_RESP : SDR/XR partition preparation completed successfully
0/1/ADMIN0:Oct 15 04:02:40.888 : sdr_mgr[2140]: %SM-SDR_MANAGER-3-MSG_VMM_ERROR : VMM returned error (SDR NM : sdr default-sdr vmid 1 start failed with error VM_MANAGER_ERR_UNABLE_TO_START_DOMAIN)
0/1/ADMIN0:Oct 15 04:02:40.888 : vm_manager[2162]: %INFRA-VM_MANAGER-3-MSG_VM_START_ERROR : Unable to start VM default-sdr--1 (virDomainCreate() call returned error -1)
0/RP0/ADMIN0:Oct 15 10:46:35.729 : shelf_mgr[2107]: %INFRA-SHELF_MGR-6-USER_ACTION : User admin(192.0.108.4) requested CLI action 'force card reload' for location 0/1
Sometimes (not always) the output also displays this:
LC/0/1/CPU0:Oct 15 13:51:27.438 CEST: arp[292]: %OS-EVM-3-EVM_CONTEXT : event_async_attach: failed to retrieve the evm_context. error(22)Invalid argument  : arp : (PID=4237) :  -Traceback= 7fe133212a8f 557f7c029395
The partition is created and it appears the LC is about to start except that it then gets brought down by a non specified "failed install operation"
We've tried to reimage the card with the "hw-module location 0/1/ bootmedia network reload" cli but the results are the same. We also tried restarting the chassis, leaving only the NC57-36H6D inserted and again observed the same behaviour. Right now, we're running 7.7.21 which should support this LC.
I confirmed that the device is working in compatibility mode through the "show hw-module profile npu-operating-mode" CLI.
Any suggestions in what we can try next to get this LC to boot or pinpoint exactly what is failing to install?
0 Replies 0
