02-15-2014 11:03 PM
Cisco recently released Cisco XRv 5.1.1 which is IOS XR running in a VM. I thought it would be nice track features working not working and if Cisco could comment on the roadmap.
Working:
ISIS
BGP
LDP
Not working:
EoMPLS
VPLS
Control plane is up for EoMPLS and VPLS but no traffic passes through. Post anything you have tested.
Daniel Dib
CCIE #37149
Please rate helpful posts.
09-18-2014 03:46 AM
no it working with me , subinterfaces with ISIS , OSPF , OSPFv3.0 working fine
Sample Configuration :
router isis 1
is-type level-2-only
net 49.0001.0000.0000.0019.00
address-family ipv4 unicast
mpls ldp auto-config
interface Loopback0
passive
interface GigabitEthernet0/0/0/0.519
circuit-type level-2-only
hello-password hmac-md5 encrypted 05223526127E1B312B
interface GigabitEthernet0/0/0/0.619
hello-password hmac-md5 encrypted 002D202F37695D3E3D
interface GigabitEthernet0/0/0/0.1920
Neighborship status :
RP/0/0/CPU0:XR1# sh isis neighbors
Fri Sep 19 01:42:49.594 UTC
IS-IS 1 neighbors:
System Id Interface SNPA State Holdtime Type IETF-NSF
R6 Gi0/0/0/0.619 ca01.0c14.0008 Up 8 L2 Capable
R5 Gi0/0/0/0.519 ca00.0c14.0008 Up 9 L2 Capable
XR2 Gi0/0/0/0.1920 0800.2722.67b9 Up 28 L2 Capable
10-27-2014 05:39 PM
Hello, sharawy_2001,
What version are you using. I'm using XRv 5.1.2 and I simply can't establish any IS-IS adjacency through sub-interfaces.
Through interfaces, it runs smoothly. Did you make any special configuration to get it running?
Kind regards!
10-28-2014 07:47 AM
Hello
Yes this is a known issue. It is related to PDU MTUs
You can try to change clns mtu or disable hello padding
http://certcollection.org/forum/topic/241895-xr-neighborship-with-r8-and-r9-issue/
Sherif Ismail
07-03-2015 01:41 AM
Hello, Sherif,
Sorry for taking too long to answer. I just would like to let you know that it was exactly what you said. It was an issue. Thanks this plus many other fixed small details, I could correctly study and pass my CCIE SP. :-)
Thank you!
07-05-2015 10:58 PM
Big congratulations dear :)
04-30-2014 08:35 AM
SNMPv3 works
Here is my statement:
snmp-server user evanr observium v3 auth md5 Password05$ priv aes 128 Password05$
snmp-server view observium iso included
snmp-server group observium v3 auth read observium write observium
control-plane
management-plane
inband
allow SNMP peer
address ipv4 172.16.1.4
Edit: Tried with sha and aes 128 and it worked with observium
Tried with sha and aes 256 and it would not work. Not sure if this is a limitation of xrv or of observium
05-02-2014 01:04 AM
Hello all,
during my tests I experienced that the ethernet OAM, CFM and L2VPN (Bridge with BVI and PBB) doesn't work on ios-xrv.
Relating on OAM and CFM seem the ios-xrv have not the software module enabled.
Relating on l2vpn we see the packets arrives on the l2-subint but they aren't sent to the bridge.
Any comments about this ?
Isacco
05-06-2014 08:34 AM
I was installed the XRv just a couple of days ago, and would like to report, that I couldn't find a way to activate the "per-packet load-sharing" feature.
05-07-2014 06:55 PM
I've always got core dump whenever try to apply QoS policy on XRv interface. Anyone has the same issues?
05-22-2014 08:01 AM
Dears
Have you tried mVPN with XRv. OIL interface at XRv is always null. Not sure from where is the issue
Please check below for details
https://supportforums.cisco.com/blog/12212086/multicast-multicast-vpn-xrv
Sherif Ismail
Many Thanks
05-22-2014 09:47 AM
Yup. Same issue here with mVPN.
05-22-2014 06:30 PM
Many thanks .. that was driving me crazy :)
05-29-2014 11:59 AM
class & policy-maps don't seem to work or commit, following on from previous poster who said he gets a core dump when applying the service-policy at the interface level....
RP/0/0/CPU0:XRv(config)#class-map match-all DS-TE
RP/0/0/CPU0:XRv(config-cmap)# match dscp ef
RP/0/0/CPU0:XRv(config-pmap-c)#show
Thu May 29 18:53:42.171 UTC
% No such configuration item(s)
RP/0/0/CPU0:XRv(config-pmap-c)#commit
Thu May 29 18:53:44.041 UTC
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed' from this session to view the errors
RP/0/0/CPU0:XRv(config-pmap-c)#do show config failed
Thu May 29 18:54:04.229 UTC
can vinijain confirm?
07-03-2014 12:18 AM
I also received the same problem when I tried to commit service-policy. Here's a copy of what I did and what I got.
RP/0/0/CPU0:PE1#conf t
Thu Jul 3 14:15:08.434 UTC
RP/0/0/CPU0:PE1(config)#class-map ICMP
RP/0/0/CPU0:PE1(config-cmap)#match protocol ICMP
RP/0/0/CPU0:PE1(config-cmap)#exit
RP/0/0/CPU0:PE1(config)#policy-map shapeIPv4
RP/0/0/CPU0:PE1(config-pmap)#class ICMP
RP/0/0/CPU0:PE1(config-pmap-c)#shape average 64 kbps
RP/0/0/CPU0:PE1(config-pmap-c)#commit
Thu Jul 3 14:15:46.321 UTC
RP/0/0/CPU0:PE1(config-pmap-c)#exit
RP/0/0/CPU0:PE1(config-pmap)#exit
RP/0/0/CPU0:PE1(config)#int g0/0/0/1
RP/0/0/CPU0:PE1(config-if)#service-policy output shapeIPv4
RP/0/0/CPU0:PE1(config-if)#commit
Thu Jul 3 14:16:06.390 UTC
RP/0/0/CPU0:Jul 3 14:16:06.420 : dumper[53]: %OS-DUMPER-4-SIGSEGV : Thread 1 received SIGSEGV - Segmentation Fault
RP/0/0/CPU0:Jul 3 14:16:06.420 : dumper[53]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0x1 at PC 0x4206ef4. Signal code 1 - SEGV_MAPPER. Address not mapped.
RP/0/0/CPU0:Jul 3 14:16:06.420 : dumper[53]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 323675 (pkg/bin/netio)
RP/0/0/CPU0:PE1(config-if)#show config fail
Thu Jul 3 14:16:11.939 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface GigabitEthernet0/0/0/1
!!% 'ifmgr' detected the 'try again' condition 'The operation encountered communication issues with the EA, NetIO or a remote IM. It may be retried'
end
McKwack
09-18-2014 03:44 AM
BFD Not working also
