XRV 5.3.0 Multicast over Traffic Engineering P2MP tunnel
takao.nakamaru
Hello everyone
I am trying to make a simple test for multicast over MPLS Traffic-Engineering P2MP tunnels for IOS XR. I am using XRV for this test and as far as I can see the control plane works alright. The tunnel comes up the the correspoding MPLS labels are destributed in the test topology.
But I have not been able to test this with multicast traffic (to verify that traffic is flowing from head-end to receivers). For this I am using ping to send  multicast packets from router R6 => R2, R1. I have not been successful and my attempts to find the cause of the problem have not been fruitful.
I was wondering if anyone has successfully test multicast over MPLS Traffic-Engineering P2MP tunnels in XRV (Is this feature supported in XRV in the first place?)
Specifically the multicast traffic does not  seem to enter the tunnel (much more leave the router):
RP/0/0/CPU0:R6#sh mfib interface tunnel-mte 126
Sat May  9 19:23:38.276 UTC
Interface : tunnel-mte126 (Enabled)
SW Mcast pkts in : 0, SW Mcast pkts out : 2814  <<<<===
TTL Threshold : 0
Ref Count : 5
RP/0/0/CPU0:R6#sh interfaces tunnel-mte 126
Sat May  9 19:27:47.049 UTC
tunnel-mte126 is up, line protocol is up
  Interface state transitions: 13
  Hardware is Tunnel-MTE
  Internet address is 6.6.6.6/32
  MTU 1500 bytes, BW 0 Kbit
     reliability 255/255, txload Unknown, rxload Unknown
  Encapsulation TUNNEL,  loopback not set,
  Last input never, output never
  5 minute output rate 0 bits/sec, 0 packets/sec   <<<<===
     0 packets input, 0 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 broadcast packets, 0 multicast packets
     0 packets output, 0 bytes, 0 total output drops
     Output 0 broadcast packets, 0 multicast packets
RP/0/0/CPU0:R6#sh mfib route 232.0.0.1
Sat May  9 19:28:07.067 UTC
Failure Counts: RPF / TTL / Empty Olist / Encap RL / Other
(192.168.60.254,232.0.0.1),   Flags:
  Up: 1d03h
  Last Used: never
  SW Forwarding Counts: 0/0/0
  SW Replication Counts: 0/0/0
  SW Failure Counts: 0/0/0/0/0
  tunnel-mte126 Flags:  NS EG LVIF, Up:23:37:39
  GigabitEthernet0/0/0/0.60 Flags:  A, Up:1d03h
Is this an XRV limitation or should I continue try to find the error?
9 Replies 9
I am joining to question. But at first I am interested BGP mvpn session.
I have success working NG-MVPN (P2MP signalled RSVP-TE) on juniper devices M-series.
I joined IOSv PE to the working topology. On cisco PE I turned on ipv4 mvpn family and A-D and C-multicast routes had been success recieved from members of multicast VPN
Routes type 1 - received
Route Distinguisher: 10.95.95.52:1 (default for vrf mvpn-tm-pe)
 *>i [1][10.95.95.52:1][10.94.94.1]/12
                       10.95.95.1                    100      0 i
 *>i [1][10.95.95.52:1][10.94.94.31]/12
                       10.95.95.31                   100      0 i
 *>i [1][10.95.95.52:1][10.94.94.38]/12
                       10.95.95.38                   100      0 i
 *>i [1][10.95.95.52:1][10.94.94.42]/12
                       10.95.95.42                   100      0 i
 *>i [1][10.95.95.52:1][10.95.95.43]/12
                       10.95.95.43                   100      0 i
Routes other types are also received.
But Cisco PE doesn't advertise even A-D route Type-1  as member this VPN.
Then I tried on XRv. 2 PE joined each other.
Config one of PE's
hostname XR6
explicit-path name to5
 index 1 next-address strict ipv4 unicast 1.1.1.5
vrf A
 vpn id 1:1
 address-family ipv4 unicast
  import route-target
   1:1
  export route-target
   1:1
 address-family ipv4 multicast
interface Loopback0
 ipv4 address 6.6.6.6 255.255.255.255
interface Loopback1
 vrf A
 ipv4 address 172.16.0.6 255.255.255.255
interface tunnel-mte1
 ipv4 unnumbered Loopback0
 destination 1.1.1.5
  path-option 1 explicit name to5
 signalled-bandwidth 1000
interface MgmtEth0/0/CPU0/0
 shutdown
interface GigabitEthernet0/0/0/0
 ipv4 address 1.1.1.6 255.255.255.0
route-policy rpf
  set core-tree p2mp-te
end-policy
route-policy pim-to-bgp
  if destination in (5.5.5.5/32) then
    set c-multicast-routing bgp
  endif
end-policy
router isis 1
 is-type level-2-only
 net 49.0000.0000.0006.00
  metric-style wide
  mpls traffic-eng level-2-only
  mpls traffic-eng router-id Loopback0
  mpls traffic-eng multicast-intact
 interface Loopback0
  passive
router bgp 1
 bgp router-id 6.6.6.6
  network 6.6.6.6/32
 address-family vpnv4 unicast
 address-family ipv4 mvpn
  retain route-target all
 address-family vpnv4 multicast
 neighbor 5.5.5.5
  remote-as 1
  update-source Loopback0
 vrf A
  rd 1:6
  bgp router-id 172.16.0.6
   network 172.16.0.6/32
rsvp
  bandwidth
mpls traffic-eng
mpls ldp
 address-family ipv4
multicast-routing
 address-family ipv4
   enable
  mdt source Loopback0
  core-tree-protocol rsvp-te
  bgp auto-discovery p2mp-te
   leaf-info-required
  mdt static p2mp-te tunnel-mte1
 vrf A
  address-family ipv4
   interface Loopback1
    enable
    segmented
    leaf-info-required
router igmp
 vrf A
  interface Loopback1
   join-group 239.59.0.1
router pim
 address-family ipv4
  mdt data announce-interval 3
   enable
 vrf A
  address-family ipv4
   rpf topology route-policy rpf
   mdt c-multicast-routing bgp
    unicast-reachability source-as enable
   rp-address 172.16.0.6
   interface Loopback1
    enable
end
I got the same result. No advertise even 1-type routes.
Experts like Luc de Gein we are waiting your answer.
There is a fix so the control-plane is working for the mVPN, I tested several profiles but the forwarding is not supported.
Maybe in XRv 9000 they will have full forwarding capabilities also for mVPN.
Hello
I have even not working control plane between 2 XRv. No any AD routes. Show me your config and issue "show bgp ipv4 mvpn summ" pls
Hey,
You need a SMU for this to work.
I any case I'll recommend to use SSM if you plan to put this in production, for learning purposes is ok.
There are a few wrong or missing parts in your configuration.
I have a running topology with profile 26 Partitioned MDT - P2MP TE - BGP-AD - BGP C-mcast signaling not very different from your profile 18 default Static MDT - P2MP TE - BGP-AD - PIM C-mcast signaling.
Here are some relevant parts of the config
RP/0/RSP0/CPU0:PE01#sh run multicast-routing
Thu May 28 01:10:10.348 UTC
multicast-routing
 address-family ipv4
  interface Loopback0
   enable
  interface Loopback1
   enable
  ssm range SSM-MDT
 vrf vrf1
  address-family ipv4
   interface GigabitEthernet0/0/0/2
    enable
   mdt source Loopback1
   ssm range C-MULTICAST
   rate-per-route
   accounting per-prefix
    leaf-info-required
   mdt partitioned p2mp-te attribute-set VRF1
RP/0/RSP0/CPU0:PE01#sh run router pim
Thu May 28 01:10:31.333 UTC
router pim
 address-family ipv4
  interface Loopback0
   enable
  interface Loopback1
   enable
 vrf vrf1
  address-family ipv4
   rpf topology route-policy P2MP-TE-PARTITIONED
    enable
RP/0/RSP0/CPU0:PE01#sh run mpls traffic-eng
Thu May 28 01:10:40.535 UTC
mpls traffic-eng
 interface GigabitEthernet0/0/0/1
 logging events preemption
 logging events frr-protection
 auto-tunnel p2mp
  tunnel-id min 1000 max 2000
 auto-tunnel backup
  timers removal unused 20
  tunnel-id min 5000 max 6000
 reoptimize 1
 attribute-set p2mp-te VRF1
  logging events lsp-status reoptimize
  logging events lsp-status reroute
  logging events lsp-status bw-change
  logging events lsp-status insufficient-bandwidth
  signalled-bandwidth 10000 class-type 0
  fast-reroute
RP/0/RSP0/CPU0:PE01#sh run ipv4 unnumbered mpls traffic-eng
Thu May 28 01:11:47.214 UTC
ipv4 unnumbered mpls traffic-eng Loopback1
RP/0/RSP0/CPU0:PE01#sh run router bgp
Thu May 28 01:13:32.744 UTC
router bgp 12345
 bgp router-id 192.168.0.10
  additional-paths receive
  network 192.168.1.10/32 route-policy RPL-PE-MVPN
  allocate-label route-policy RPL-ALLOCATE-LABEL-LBGP
 address-family ipv4 mdt
 address-family l2vpn vpls-vpws
 neighbor-group PE-RR-VPN
  remote-as 12345
  update-source Loopback1
 neighbor-group DR-RR-IPV4
  remote-as 12345
 neighbor-group DR-RR-LBGP
  remote-as 12345
  update-source Loopback2
  address-family ipv4 labeled-unicast
   route-policy RPL-DR-RR-LBGP-IN in
   route-policy RPL-DR-RR-LBGP-OUT out
 neighbor 192.168.0.9
  use neighbor-group DR-RR-IPV4
 neighbor 192.168.1.9
  use neighbor-group PE-RR-VPN
 neighbor 192.168.2.9
  use neighbor-group DR-RR-LBGP
 vrf vrf1
  rd 1:1
   redistribute connected
   redistribute static
let me issie "show bgp ipv4 mvpn su"  pls
and show advertise mvpn routes  pls
Status codes: s suppressed, d damped, h history, * valid, > best
              i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network            Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:1 (default for vrf vrf1)
*>i[1][192.168.1.1]/40
                      192.168.1.1                   100      0 i
*> [1][192.168.1.10]/40
                      0.0.0.0                                0 i
*>i[3][0][0.0.0.0][0][0.0.0.0][192.168.1.1]/120
                      192.168.1.1                   100      0 i
*> [3][0][0.0.0.0][0][0.0.0.0][192.168.1.10]/120
                      0.0.0.0                                0 i
*>i[4][3][1:1][0][0.0.0.0][0][0.0.0.0][192.168.1.10][192.168.1.1]/224
                      192.168.1.1                   100      0 i
*>i[7][1:1][16422][32][192.168.232.46][32][233.232.0.14]/184
                      192.168.1.1                   100      0 i
Is it configuration on XRv or on real XR?
XRv, on hardware box the forwarding works but on XRv not.
I understood. Type me in PM your skype
