Coredump check yang model info reqd
I tried yang model cisco-ios-xr 6.2.1 version for finding coredump check below cli command
P/0/RP0/CPU0:Router#dir harddisk:
Mon May  8 00:10:28.134 EDT
Directory of harddisk:
    20 drwxr-xr-x 2       4096 Jul  1  2016 dumper
    55 -rw-r--r-- 1     117127 Apr 19 18:33 cleaf1_show_tech_arp.c2.tgz
    57 -rw-r--r-- 1      83445 Apr 19 18:34 cleaf1_show_tech_spp.c2.tgz
    52 -rwxr--r-- 1     679137 Apr 19 19:15 netio_trace.c1
    12 drwxr-xr-x 2       4096 Jul  1  2016 tftpboot
   107 -rwx------ 1      61169 Mar  1 13:17 dedsdf1003jl1-sh-run-03012017
    60 -rw-r--r-- 1      68443 Apr 19 18:38 cleaf1_show_tech_spio.c2.tgz
So could you please let me know the yang model for finding dir harddisk:
Jay
Jay,
First, my explanation was slightly wrong. The content is a single 32-bit number with two 16-bit values in it. The community list is here in the YANG tree (and maybe in other places):
module: Cisco-IOS-XR-ipv4-bgp-oper
+--ro bgp
+--ro instances
+--ro instance*
+--ro instance-active
+--ro default-vrf
+--ro afs
+--ro af*
+--ro advertised-path-xr
+--ro advertised-path*
+--ro attributes-after-policy-in
+--ro common-attributes
+--ro community*
+--ro entry? uint32
As you can see, the type is a uint32, which means that a number, as you received, is the correct wire representation. A display like "13979:3101” is a presentation layer issue, and must be implemented by your code. For example:
14:54 $ python
Python 2.7.13 (default, Dec 18 2016, 07:03:39)
on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> community = 916130845
>>> c_upper = community & 0xffff0000
>>> c_lower = community & 0x0000ffff
>>> print('%d:%d' % (c_upper >> 16, c_lower))
13979:3101
Cheers,
Einar
8 Replies 8
saalvare
Jay,
An RPC model is required for that action.  It is currently not available on released software.  Let me look at the roadmap and get back to you. Thanks.
Jay,
The target date for the release of file system RPCs hasn't been confirmed yet.  Currently, you'd need to retrieve the fails in the file system vis CLI.  We're working on closing these gaps as soon as possible, but we just don't have a firm date for this one in particular. In a month or two, we should have better visibility.  HTH.
Hi Santiago,
Please ignore my previous reply about few cli related yang model.
I am trying to find the cli output for yangmodel
RP/0/RP0/CPU0:dedsdf1011jl1#sh bgp ipv4 unicast advertised neighbor 10.20.20.26
Wed May 24 07:11:19.574 EDT
10.20.20.70/32 is advertised to 10.20.20.26
  Path info:
    neighbor: Local           neighbor router id: 10.20.20.70
    valid  redistributed  best
Received Path ID 0, Local Path ID 0, version 6
  Attributes after inbound policy was applied:
    next hop: 0.0.0.0
    MET ORG AS COMM
    origin: incomplete  metric: 0
    aspath:
    community: 13979:3111 62301:21
  Attributes after outbound policy was applied:
    next hop: 10.20.20.70
    MET ORG AS COMM
    aspath:
Please let us know which yang model needs to refer this above cli putput . We are getting in XML rpcreply with community as 916130845  instead of 13979:3111
Please let me know your inputs
Jay
916130845 is the equivalent of 13979:3101 if you treat it as a 64-bit number. The upper 32-bits are 13979, and the lower 32-bits are 3101.
What path are you using to retrieve the data you get?
Hi Einar,
Thank you your prompt response , its very helpful to resolve the issue
Also i would like to show the RPC which i am using to get route-policy community output .
def read(host, user, password):
    try:
        with manager.connect(host=host,  username=user, password=password, look_for_keys=False,timeout=150) as m:
            bgp_filter = '''
      <bgp xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-bgp-oper">
        <instances>
          <instance>
            <instance-name>default</instance-name>
            <instance-active>
              <default-vrf>
                <afs>
                  <af>
                    <af-name>ipv4-unicast</af-name>
                    <advertised-path-xr>
                      <advertised-path/>
                    </advertised-path-xr>
                  </af>
                </afs>
              </default-vrf>
            </instance-active>
          </instance>
        </instances>
      </bgp>
            cisco_bgp = m.get(('subtree', bgp_filter))
            print (cisco_bgp)
            with open("/tmp/difficultipv4ncc167new1.xml", "w+") as file_obj:
                file_obj.write(str(cisco_bgp))
    except Exception as exe:
        print 'Exception caught in read()',exe
With these RPC , we are getting XML RPC reply . But when we are grepping community set its showing as 916130845  instead of 13979:3101
So how we can get the community output as 13979:3101 .
Here we are trying show bgp ipv4 unicast advertised neighbor 10.80.65.60 and out put will provide the nexthop and community value.
Jay
Jay,
+--ro bgp
+--ro instances
+--ro instance*
+--ro default-vrf
+--ro afs
+--ro af*
+--ro community*
+--ro entry? uint32
14:54 $ python
on darwin
13979:3101
Cheers,
Einar
Thank you Einar for the resolution !!!
