Error while installing ydk on pyats
jkalaise
Hi Team,
In my 64 bit machine, I am hitting error while installing ydk on a pyats environment. Any help is highly appreciated. Pasting the error below,
(pyats) jkalaise@access-ops-lnx /auto/tftp-access-ops/mgbl/pyats/ydk-gen/gen-api/python/ydk/dist > pip install ydk-0.8.3.tar.gz
Looking in indexes: http://pyats-pypi.cisco.com/simple
Processing ./ydk-0.8.3.tar.gz
Requirement already satisfied: pybind11>=2.1.1 in /auto/tftp-access-ops/mgbl/pyats/lib/python3.4/site-packages (from ydk==0.8.3) (2.3.0)
Installing collected packages: ydk
Running setup.py install for ydk ... error
Complete output from command /auto/tftp-access-ops/mgbl/pyats/bin/python3.4 -u -c "import setuptools, tokenize;__file__='/tmp/pip-req-build-yt_uoxuv/setup.py';f=getat:
running install
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.4
creating build/lib.linux-x86_64-3.4/ydk
copying ydk/exthook.py -> build/lib.linux-x86_64-3.4/ydk
copying ydk/__init__.py -> build/lib.linux-x86_64-3.4/ydk
creating build/lib.linux-x86_64-3.4/ydk/models
copying ydk/models/__init__.py -> build/lib.linux-x86_64-3.4/ydk/models
creating build/lib.linux-x86_64-3.4/ydk/filters
copying ydk/filters/__init__.py -> build/lib.linux-x86_64-3.4/ydk/filters
creating build/lib.linux-x86_64-3.4/ydk/entity_utils
copying ydk/entity_utils/entity_utils.py -> build/lib.linux-x86_64-3.4/ydk/entity_utils
copying ydk/entity_utils/__init__.py -> build/lib.linux-x86_64-3.4/ydk/entity_utils
creating build/lib.linux-x86_64-3.4/ydk/types
copying ydk/types/py_types.py -> build/lib.linux-x86_64-3.4/ydk/types
copying ydk/types/__init__.py -> build/lib.linux-x86_64-3.4/ydk/types
creating build/lib.linux-x86_64-3.4/ydk/providers
copying ydk/providers/codec_provider.py -> build/lib.linux-x86_64-3.4/ydk/providers
copying ydk/providers/netconf_provider.py -> build/lib.linux-x86_64-3.4/ydk/providers
copying ydk/providers/__init__.py -> build/lib.linux-x86_64-3.4/ydk/providers
creating build/lib.linux-x86_64-3.4/ydk/errors
copying ydk/errors/error_handler.py -> build/lib.linux-x86_64-3.4/ydk/errors
copying ydk/errors/__init__.py -> build/lib.linux-x86_64-3.4/ydk/errors
creating build/lib.linux-x86_64-3.4/ydk/logging
copying ydk/logging/__init__.py -> build/lib.linux-x86_64-3.4/ydk/logging
creating build/lib.linux-x86_64-3.4/ydk/path
copying ydk/path/__init__.py -> build/lib.linux-x86_64-3.4/ydk/path
creating build/lib.linux-x86_64-3.4/ydk/ext
copying ydk/ext/__init__.py -> build/lib.linux-x86_64-3.4/ydk/ext
creating build/lib.linux-x86_64-3.4/ydk/_core
copying ydk/_core/_importer.py -> build/lib.linux-x86_64-3.4/ydk/_core
copying ydk/_core/_dm_meta_info.py -> build/lib.linux-x86_64-3.4/ydk/_core
copying ydk/_core/__init__.py -> build/lib.linux-x86_64-3.4/ydk/_core
creating build/lib.linux-x86_64-3.4/ydk/services
copying ydk/services/executor_service.py -> build/lib.linux-x86_64-3.4/ydk/services
copying ydk/services/codec_service.py -> build/lib.linux-x86_64-3.4/ydk/services
copying ydk/services/__init__.py -> build/lib.linux-x86_64-3.4/ydk/services
copying ydk/services/netconf_service.py -> build/lib.linux-x86_64-3.4/ydk/services
copying ydk/services/crud_service.py -> build/lib.linux-x86_64-3.4/ydk/services
creating build/lib.linux-x86_64-3.4/ydk/path/sessions
copying ydk/path/sessions/restconf_session.py -> build/lib.linux-x86_64-3.4/ydk/path/sessions
copying ydk/path/sessions/netconf_session.py -> build/lib.linux-x86_64-3.4/ydk/path/sessions
copying ydk/path/sessions/__init__.py -> build/lib.linux-x86_64-3.4/ydk/path/sessions
running build_ext
-- The C compiler identification is GNU 4.4.7
-- The CXX compiler identification is GNU 4.4.7
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
python version: 3.4m
-- Found PythonLibs: /usr/lib64/libpython3.4m.so (found version "3.4.5")
pybind11 include: /auto/tftp-access-ops/mgbl/pyats/include/site/python3.4;/auto/tftp-access-ops/mgbl/pyats/include/site/python3.4
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
curl_location
linked by target "ydk_" in directory /tmp/pip-req-build-yt_uoxuv
pcre_location
ssh_location
ssh_threads_location
ydk_location
-- Configuring incomplete, errors occurred!
See also "/tmp/pip-req-build-yt_uoxuv/build/temp.linux-x86_64-3.4/CMakeFiles/CMakeOutput.log".
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/pip-req-build-yt_uoxuv/setup.py", line 145, in <module>
zip_safe=False,
File "/auto/tftp-access-ops/mgbl/pyats/lib/python3.4/site-packages/setuptools/__init__.py", line 145, in setup
return distutils.core.setup(**attrs)
File "/auto/pysw/cel63/python64/3.4.1/lib/python3.4/distutils/core.py", line 148, in setup
dist.run_commands()
File "/auto/pysw/cel63/python64/3.4.1/lib/python3.4/distutils/dist.py", line 955, in run_commands
self.run_command(cmd)
File "/auto/pysw/cel63/python64/3.4.1/lib/python3.4/distutils/dist.py", line 974, in run_command
cmd_obj.run()
File "/auto/tftp-access-ops/mgbl/pyats/lib/python3.4/site-packages/setuptools/command/install.py", line 61, in run
return orig.install.run(self)
File "/auto/pysw/cel63/python64/3.4.1/lib/python3.4/distutils/command/install.py", line 554, in run
self.run_command('build')
File "/auto/pysw/cel63/python64/3.4.1/lib/python3.4/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/auto/pysw/cel63/python64/3.4.1/lib/python3.4/distutils/command/build.py", line 126, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-req-build-yt_uoxuv/setup.py", line 68, in run
self.build_extension(ext)
File "/tmp/pip-req-build-yt_uoxuv/setup.py", line 100, in build_extension
subprocess.check_call([cmake_executable, ext.sourcedir] + cmake_args, cwd=self.build_temp)
File "/auto/pysw/cel63/python64/3.4.1/lib/python3.4/subprocess.py", line 561, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['cmake', '/tmp/pip-req-build-yt_uoxuv', '-DCMAKE_LIBRARY_OUTPUT_DIRECTORY=/tmp/pip-req-build-yt_uoxuv/build/lib.linux-x86_64-1
Command "/auto/tftp-access-ops/mgbl/pyats/bin/python3.4 -u -c "import setuptools, tokenize;__file__='/tmp/pip-req-build-yt_uoxuv/setup.py';f=getattr(tokenize, 'open', ope/
6 Replies 6
saalvare
Have you installed the matching libydk?
Thank you for your response, I had done this
pip install -r ydk-gen/requirements.txt --index-url https://pypi.python.org/simple
(pyats) jkalaise@access-ops-lnx /auto/tftp-access-ops/mgbl/pyats > !cat
cat ydk-gen/requirements.txt
pyang==1.6
Sphinx==1.4a1
sphinx-rtd-theme==0.1.9
GitPython==2.1.11
rstr==2.2.6
enum34==1.1.3
lxml>=3.4.4
ncclient>=0.4.7
Does this you mean?? Below are the steps I had done,
278 source /auto/pyats/bin/lab_proxy.sh
279 git clone https://github.com/CiscoDevNet/ydk-gen
280 cat ydk-gen/requirements.txt
281 unset LC_ALL
285 pip install -r ydk-gen/requirements.txt --index-url https://pypi.python.org/simple
291 ./generate.py --core
292 ls ydk0.8.3/ydk/core
293 cd ydk0.8.3
294 ls ydk-0.8.3/ydk/_core
git clone https://github.com/CiscoDevNet/ydk-py
319 cd ydk-gen
320 cd gen-api/python/ydk/dist
321 pip install ydk-0.8.3.tar.gz
ygorelik
Hello jkalaise
Before installing python component you need to install C++ libraries libydk and optionally libydk_gnmi, if you are planning to use gNMI protocol. But before that you need to satisfy requirements on your host system. Please refer to documentation for all the details.
Yan
jkalaise
I tried installing ydklib, however my system is RHEL 6.8 where the dependency could not be resolved. Could you please let me know how to proceed further?
--> Finished Dependency Resolution
Error: Package: libydk-0.8.3-1.x86_64 (/libydk-0.8.3-1.x86_64)
Requires: python-pip
Requires: cmake3
Requires: libssh-devel
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Uploading Enabled Repositories Report
Loaded plugins: refresh-packagekit
[root@access-ops-lnx ~]# yum install python-pip cmake3 libssh-devel
Loaded plugins: enabled_repos_upload, package_upload, refresh-packagekit, search-disabled-repos, security
Setting up Install Process
https://rhn-cap3-ams.cisco.com/pulp/repos/PROD/Library/CEL-PROD-6_8-DevSuite/content/dist/rhel/server/6/6Server/x86_64/extras/os/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 504"
Trying other mirror.
https://rhn-cap3-ams.cisco.com/pulp/repos/PROD/Library/CEL-PROD-6_8-DevSuite/content/fastrack/rhel/server/6/x86_64/os/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 504"
https://rhn-cap3-ams.cisco.com/pulp/repos/PROD/Library/CEL-PROD-6_8-DevSuite/content/dist/rhel/server/6/6.8/x86_64/optional/os/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 504"
https://rhn-cap3-ams.cisco.com/pulp/repos/PROD/Library/CEL-PROD-6_8-DevSuite/content/dist/rhel/server/6/6.8/x86_64/os/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 504"
https://rhn-cap3-ams.cisco.com/pulp/repos/PROD/Library/CEL-PROD-6_8-DevSuite/content/dist/rhel/server/6/6Server/x86_64/sat-tools/6.3-puppet4/os/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 504"
https://rhn-cap3-ams.cisco.com/pulp/repos/PROD/Library/CEL-PROD-6_8-DevSuite/content/dist/rhel/server/6/6Server/x86_64/sat-tools/6.3/os/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 504"
https://rhn-cap3-ams.cisco.com/pulp/repos/PROD/Library/CEL-PROD-6_8-DevSuite/content/dist/rhel/server/6/6.8/x86_64/supplementary/os/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 504"
No package python-pip available.
No package cmake3 available.
No package libssh-devel available.
Error: Nothing to do
The YDK is currently not supported on RHEL-6/CenOS-6 platforms due to some incompatibilities with 3-rd party packages/libraries, which are required for YDK. This issue is documented here. The only way forward in this situation is upgrade the platform to RHEL-7/CenOS-7.
jkalaise
Hi Team,
Appreciate all your help. Having RHEL 7.0 solved this issue. Please close this thread.
Thanks & Regards,
Jasmine.K
