help with failed ydk core install / compilation
dave_stern
Having trouble getting past the core and netconf bundle installs. Assuming the error I get when installing the cisco-asr-ios-xr bundle is because the compliation of the core has failed (second error not shown or in the error log attached simply says it can't find ydk).
Can you give me an idea of what is wrong?
Getting an error when installing the core bundle
creating /usr/local/etc/bash_completion.d
    error: can't copy 'etc/bash_completion.d/pyang': doesn't exist or not a regular file
--compile failed with error code 1 in /tmp/pip_build_root/pyang
Exception information:
Traceback (most recent call last):
  File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 122, in main
    status = self.run(options, args)
  File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 283, in run
    requirement_set.install(install_options, global_options, root=options.root_path)
  File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1436, in install
    requirement.install(install_options, global_options, *args, **kwargs)
  File "/usr/lib/python2.7/dist-packages/pip/req.py", line 707, in install
    cwd=self.source_dir, filter_stdout=self._filter_install, show_stdout=False)
  File "/usr/lib/python2.7/dist-packages/pip/util.py", line 715, in call_subprocess
    % (command_desc, proc.returncode, cwd))
InstallationError: Command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip_build_root/pyang/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-n3EUej-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip_build_root/pyang
12 Replies 12
xiaoqinz
Level 4
Level 4
Hi David,
Thanks for raising this issue. Are you installing ydk core under virtualenv? I found a similar issue here, and the suggested approach is to "Running pip install --upgrade pip within virtualenv fixed this issue.". Would this help for this issue?
This didn't help fix the pyang compilation issue but I was able to clear some of the warnings during the compilation by executing the following after a warning with the new pip wheel I installed.
sudo -H pip install --no-index --find-links=/home/id22/Desktop/pywrapperetc/ /home/id22/Desktop/ydk-py-master/core/dist/ydk-0.5.2.tar.gz
Other sites offer that since we are using the virtual environment that I should not have to sudo.
I can now execute
some of the other pyang type messages point to bad pointers in the distribution, I just don't know.
Attached the latest log. Any assistance is appreciated, still have the same problem but solved another one with sudo -H
This ended up being the solution. I had to go into the pyang tar file (used the tar and not the wheel) and edit per the link that you sent. I was actually able to do this in Ubuntu which actually repacked it then it automagically then it all worked well. I did not try the wheel so it is possible that it was fixed in the wheel but not the tar. here
I have this issue trying to pip install on my macbook pro in a virtualenvwrapper. This is what I discovered:
There seems to be a problem with in pyang setup.py. I added the correct path to pyang in the pyang setup.py data_files and it worked.
Changed From:
data_files=[
('share/man/man1', man1),
('share/yang/modules/iana', modules_iana),
('share/yang/modules/ietf', modules_ietf),
('share/yang/xslt', xslt),
('share/yang/images', images),
('share/yang/schema', schema),
('etc/bash_completion.d', ['etc/bash_completion.d/pyang']),
To:
data_files=[
#('etc/bash_completion.d', ['etc/bash_completion.d/pyang']),
('etc/bash_completion.d', ['bin/pyang']),
saalvare
It'd great if you can share the details on OS and version you're using.
Ubuntu 14.04 LTS
Is there network limitation on this machine, so the local tarballs for ydk dependencies are used?
Correct. There is an Internet limitation. This machine does not and will not have access to the Internet. The machine does have access to an internal network but it does not host a local repo.
The installation process takes care of many dependencies and relies on internet connectivity.  I'm not familiar with the changes needed to make the installation work on a disconnected host.  Let me suggest a couple of alternatives.  We have a Vagrant sandbox that gives you an Ubuntu machine with YDK-Py pre-installed with hundreds of sample apps.  The only requirement to run the sandbox is a host with Virtualbox and Vagrant installed.  Alternatively, we can try sharing an OVA of that sandbox.
Ouch! I was hoping you would have an idea with the pip error log's.
We can move this app to virtualbox if we have too.
Dave
Hi Dave,
Would you mind provide some detailed information about those local files you have on that machine? I've purchased a laptop and just have ubuntu 14.04 installed, maybe I could try to reproduce this issue.
within virtual (ydk-py)
ecdsa (0.13)
enum34 (1.1.3)
lxml (3.4.4)
paramiko (1.15.2)
pip (8.1.2)
pycrypto (2.6.1)
setuptools (28.8.0)
wheel (0.29.0)
***the compliation fails when building the pyang, I can try to install pyang on the base system, that shouldn't be required but that is an idea we can try. Before I do that would be interested to see if you can reproduce.
on base system
adium-theme-ubuntu (0.3.4)
apt-xapian-index (0.45)
chardet (2.0.1)
colorama (0.2.5)
command-not-found (0.3)
configobj (4.7.2)
debtagshw (0.1)
defer (1.0.6)
dirspec (13.10)
duplicity (0.6.23)
ecdsa (0.13)
enum34 (1.1.3)
html5lib (0.999)
httplib2 (0.8)
Landscape-Client (14.12)
lockfile (0.8)
lxml (3.4.4)
oauthlib (0.6.1)
oneconf (0.3.7.14.4.1)
PAM (0.4.2)
paramiko (1.15.2)
pbr (1.10.0)
pexpect (3.1)
Pillow (2.3.0)
pip (9.0.1)
piston-mini-client (0.7.5)
pycrypto (2.6.1)
pycups (1.9.66)
pygobject (3.12.0)
pyOpenSSL (0.13)
pyserial (2.6)
pysmbc (1.0.14.1)
python-apt (0.9.3.5ubuntu1)
python-debian (0.1.21-nmu2ubuntu2)
pyxdg (0.25)
reportlab (3.0)
requests (2.2.1)
sessioninstaller (0.0.0)
setuptools (3.3)
six (1.10.0)
software-center-aptd-plugins (0.0.0)
ssh-import-id (3.21)
stevedore (1.19.1)
system-service (0.1.6)
Twisted-Core (13.2.0)
Twisted-Web (13.2.0)
unity-lens-photos (1.0)
urllib3 (1.7.1)
virtualenv (15.1.0)
virtualenv-clone (0.2.6)
virtualenvwrapper (4.7.2)
wheel (0.24.0)
xdiagnose (3.6.3build2)
zope.interface (4.0.5)
Thanks. I tried to reproduce and run into the same error when I tried to "pip install pyang-1.6.tar.gz" downloaded pypi.https://pypi.python.org/pypi/pyang/1.6 Other archive files for pyang 1.6 works fine for me(either pyang-1.6-py2.py3-none-any.whl from the same page or pyang 1.6 release from their GitHub release page).
I was able to install using the same command if I replace the "pyang-1.6.tar.gz" with "pyang-1.6-py2.py3-none-any.whl".
Failed log:
λ ~/ pip list
argparse (1.2.1)
boto (2.20.1)
chardet (2.0.1)
colorama (0.2.5)
configobj (4.7.2)
debtagshw (0.1)
defer (1.0.6)
dirspec (13.10)
duplicity (0.6.23)
ecdsa (0.13)
enum34 (1.1.3)
html5lib (0.999)
httplib2 (0.8)
lockfile (0.8)
lxml (3.3.3)
oauthlib (0.6.1)
oneconf (0.3.7.14.04.1)
PAM (0.4.2)
pbr (1.10.0)
pexpect (3.1)
Pillow (2.3.0)
pip (1.5.4)
pycrypto (2.6.1)
pycups (1.9.66)
pycurl (7.19.3)
pygobject (3.12.0)
pyOpenSSL (0.13)
pyserial (2.6)
pysmbc (1.0.14.1)
python-apt (0.9.3.5ubuntu2)
python-cloudfiles (1.7.10)
pyxdg (0.25)
reportlab (3.0)
requests (2.2.1)
setuptools (3.3)
six (1.10.0)
stevedore (1.20.0)
urllib3 (1.7.1)
virtualenv (15.1.0)
wheel (0.24.0)
wsgiref (0.1.2)
λ ~/ workon ydk-py
/home/saber/.virtualenvs/ydk-py/bin/python: No module named virtualenvwrapper
(ydk-py) λ ~/ pip list
ecdsa (0.13)
enum34 (1.1.3)
lxml (3.4.4)
paramiko (1.15.2)
pip (8.1.2)
pycrypto (2.6.1)
setuptools (28.8.0)
wheel (0.29.0)
You are using pip version 8.1.2, however version 9.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
(ydk-py) λ ~/ pwd
/home/saber
(ydk-py) λ ~/ ls -al Downloads
total 45372
drwxr-xr-x  2 saber saber     4096 Jan 20 17:59 .
drwxr-xr-x 33 saber saber     4096 Jan 20 18:01 ..
-rw-rw-r--  1 saber saber    86911 Jan 20 17:44 ecdsa-0.13-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber    61307 Jan 20 17:31 enum34-1.1.3-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber    12427 Jan 20 17:38 enum34-1.1.6-py2-none-any.whl
-rw-rw-r--  1 saber saber  3537508 Jan 20 17:37 lxml-3.4.4.tar.gz
-rw-rw-r--  1 saber saber  6759203 Jan 20 17:36 lxml-3.7.2-cp27-cp27m-manylinux1_x86_64.whl
-rw-rw-r--  1 saber saber   201470 Jan 20 17:33 m3-libxml2-python-2.6.9.tar.gz
-rw-rw-r--  1 saber saber    63151 Jan 20 17:29 ncclient-0.5.3.tar.gz
-rw-rw-r--  1 saber saber  1220578 Jan 20 17:39 paramiko-1.15.2.tar.gz
-rw-rw-r--  1 saber saber   172565 Jan 20 17:35 paramiko-2.1.1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber    96932 Jan 20 17:40 pbr-1.10.0-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber  1198961 Jan 20 17:33 pip-8.1.2-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber  1254803 Jan 20 17:42 pip-9.0.1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber   114913 Jan 20 17:37 protobuf-3.0.0b2.post2.tar.gz
-rw-rw-r--  1 saber saber   347537 Jan 20 17:38 protobuf-3.1.0.post1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber   128322 Jan 20 17:43 pyang-1.6.tar.gz
-rw-rw-r--  1 saber saber   300545 Jan 20 17:35 pyang-1.7.1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber   446240 Jan 20 17:50 pycrypto-2.6.1.tar.gz
-rw-rw-r--  1 saber saber    10341 Jan 20 17:43 six-1.10.0-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber    38891 Jan 20 17:32 stevedore-1.19.1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber  2938611 Jan 20 17:44 Twisted-16.1.1.tar.bz2
-rw-rw-r--  1 saber saber  2986179 Jan 20 17:34 Twisted-16.7.0rc1.tar.bz2
-rw-rw-r--  1 saber saber  1820727 Jan 20 17:39 virtualenv-15.1.0-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber     5691 Jan 20 17:43 virtualenv-clone-0.2.6.tar.gz
-rw-rw-r--  1 saber saber    90599 Jan 20 17:30 virtualenvwrapper-4.7.2.tar.gz
-rw-rw-r--  1 saber saber 22241779 Jan 20 17:47 ydk-py-0.5.2.zip
-rw-rw-r--  1 saber saber   150572 Jan 20 17:41 zope.interface-4.3.3.tar.gz
(ydk-py) λ ~/ ls -al Cisco/ydk-py/core/dist
total 52
drwxrwxr-x 2 saber saber  4096 Jan 20 09:32 .
drwxrwxr-x 6 saber saber  4096 Jan 20 09:32 ..
-rw-rw-r-- 1 saber saber 41896 Jan 20 09:32 ydk-0.5.2.tar.gz
(ydk-py) λ ~/ pip install --no-index --find-links=/home/saber/Downloads/ /home/saber/Cisco/ydk-py/core/dist/ydk-0.5.2.tar.gz
Ignoring indexes: https://pypi.python.org/simple
Processing ./Cisco/ydk-py/core/dist/ydk-0.5.2.tar.gz
Requirement already satisfied (use --upgrade to upgrade): ecdsa==0.13 in ./.virtualenvs/ydk-py/lib/python2.7/site-packages (from ydk==0.5.2)
Requirement already satisfied (use --upgrade to upgrade): enum34==1.1.3 in ./.virtualenvs/ydk-py/lib/python2.7/site-packages (from ydk==0.5.2)
Requirement already satisfied (use --upgrade to upgrade): lxml==3.4.4 in ./.virtualenvs/ydk-py/lib/python2.7/site-packages (from ydk==0.5.2)
Requirement already satisfied (use --upgrade to upgrade): paramiko==1.15.2 in ./.virtualenvs/ydk-py/lib/python2.7/site-packages (from ydk==0.5.2)
Collecting pyang==1.6 (from ydk==0.5.2)
Requirement already satisfied (use --upgrade to upgrade): pycrypto==2.6.1 in ./.virtualenvs/ydk-py/lib/python2.7/site-packages (from ydk==0.5.2)
Collecting Twisted>=16.0.0 (from ydk==0.5.2)
Collecting protobuf==3.0.0b2.post2 (from ydk==0.5.2)
Collecting ncclient>=0.4.7 (from ydk==0.5.2)
Collecting zope.interface>=3.6.0 (from Twisted>=16.0.0->ydk==0.5.2)
Collecting six>=1.9 (from protobuf==3.0.0b2.post2->ydk==0.5.2)
Requirement already satisfied (use --upgrade to upgrade): setuptools in ./.virtualenvs/ydk-py/lib/python2.7/site-packages (from protobuf==3.0.0b2.post2->ydk==0.5.2)
Building wheels for collected packages: ydk, pyang, Twisted, protobuf, ncclient, zope.interface
  Running setup.py bdist_wheel for ydk ... done
  Stored in directory: /home/saber/.cache/pip/wheels/2f/2a/e4/9b3bdc32336f3bdcc46c54d9b4f355f360ee579a2d88ecddcf
  Running setup.py bdist_wheel for pyang ... error
  Complete output from command /home/saber/.virtualenvs/ydk-py/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-kTgihB/pyang/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" bdist_wheel -d /tmp/tmpMzihazpip-wheel- --python-tag cp27:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-x86_64-2.7
  creating build/lib.linux-x86_64-2.7/pyang
  copying pyang/plugin.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/grammar.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/syntax.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/util.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/__init__.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/yang_parser.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/statements.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/hello.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/error.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/yin_parser.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/types.py -> build/lib.linux-x86_64-2.7/pyang
  copying pyang/xpath.py -> build/lib.linux-x86_64-2.7/pyang
  creating build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/lint.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/jsonxsl.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/__init__.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/jstree.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/sample-xml-skeleton.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/name.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/hypertree.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/depend.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/check_update.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/omni.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/uml.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/capability.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/jtox.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/xmi.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/ietf.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/smi.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  copying pyang/plugins/tree.py -> build/lib.linux-x86_64-2.7/pyang/plugins
  creating build/lib.linux-x86_64-2.7/pyang/translators
  copying pyang/translators/dsdl.py -> build/lib.linux-x86_64-2.7/pyang/translators
  copying pyang/translators/schemanode.py -> build/lib.linux-x86_64-2.7/pyang/translators
  copying pyang/translators/__init__.py -> build/lib.linux-x86_64-2.7/pyang/translators
  copying pyang/translators/yin.py -> build/lib.linux-x86_64-2.7/pyang/translators
  copying pyang/translators/yang.py -> build/lib.linux-x86_64-2.7/pyang/translators
  running build_scripts
  creating build/scripts-2.7
  copying and adjusting bin/pyang -> build/scripts-2.7
  copying and adjusting bin/yang2html -> build/scripts-2.7
  copying bin/yang2dsdl -> build/scripts-2.7
  copying and adjusting bin/json2xml -> build/scripts-2.7
  changing mode of build/scripts-2.7/pyang from 664 to 775
  changing mode of build/scripts-2.7/yang2html from 664 to 775
  changing mode of build/scripts-2.7/json2xml from 664 to 775
  installing to build/bdist.linux-x86_64/wheel
  running install
  running install_lib
  creating build/bdist.linux-x86_64
  creating build/bdist.linux-x86_64/wheel
  creating build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/plugin.py -> build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/grammar.py -> build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/syntax.py -> build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/util.py -> build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/__init__.py -> build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/yang_parser.py -> build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/statements.py -> build/bdist.linux-x86_64/wheel/pyang
  creating build/bdist.linux-x86_64/wheel/pyang/translators
  copying build/lib.linux-x86_64-2.7/pyang/translators/dsdl.py -> build/bdist.linux-x86_64/wheel/pyang/translators
  copying build/lib.linux-x86_64-2.7/pyang/translators/schemanode.py -> build/bdist.linux-x86_64/wheel/pyang/translators
  copying build/lib.linux-x86_64-2.7/pyang/translators/__init__.py -> build/bdist.linux-x86_64/wheel/pyang/translators
  copying build/lib.linux-x86_64-2.7/pyang/translators/yin.py -> build/bdist.linux-x86_64/wheel/pyang/translators
  copying build/lib.linux-x86_64-2.7/pyang/translators/yang.py -> build/bdist.linux-x86_64/wheel/pyang/translators
  copying build/lib.linux-x86_64-2.7/pyang/hello.py -> build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/error.py -> build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/yin_parser.py -> build/bdist.linux-x86_64/wheel/pyang
  copying build/lib.linux-x86_64-2.7/pyang/types.py -> build/bdist.linux-x86_64/wheel/pyang
  creating build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/lint.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/jsonxsl.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/__init__.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/jstree.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/sample-xml-skeleton.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/name.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/hypertree.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/depend.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/check_update.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/omni.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/uml.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/capability.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/jtox.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/xmi.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/ietf.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/smi.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/plugins/tree.py -> build/bdist.linux-x86_64/wheel/pyang/plugins
  copying build/lib.linux-x86_64-2.7/pyang/xpath.py -> build/bdist.linux-x86_64/wheel/pyang
  running install_data
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share/man
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share/man/man1
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share/yang
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share/yang/modules
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share/yang/modules/iana
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share/yang/modules/ietf
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share/yang/xslt
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share/yang/images
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/share/yang/schema
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/etc
  creating build/bdist.linux-x86_64/wheel/pyang-1.6.data/data/etc/bash_completion.d
  Failed building wheel for pyang
  Running setup.py clean for pyang
  Running setup.py bdist_wheel for Twisted ... done
  Stored in directory: /home/saber/.cache/pip/wheels/c0/76/8f/ba7b7b0dfa5975c1454551ef43e5de68b26aa0c60c948024c2
  Running setup.py bdist_wheel for protobuf ... done
  Stored in directory: /home/saber/.cache/pip/wheels/25/ca/28/6ff47ee0ae155001a605492745f4a19f0bcffa43a95d4ba7c5
  Running setup.py bdist_wheel for ncclient ... done
  Stored in directory: /home/saber/.cache/pip/wheels/3f/37/2f/09def8777d43ab8c907caa6018cac8d3441f651cbe7b6df6aa
  Running setup.py bdist_wheel for zope.interface ... done
  Stored in directory: /home/saber/.cache/pip/wheels/d3/60/b9/0b9e9e7af3007493d65d82bf8c9293c4cc77c86c086265a751
Successfully built ydk Twisted protobuf ncclient zope.interface
Failed to build pyang
Installing collected packages: pyang, zope.interface, Twisted, six, protobuf, ncclient, ydk
  Running setup.py install for pyang ... error
    Complete output from command /home/saber/.virtualenvs/ydk-py/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-kTgihB/pyang/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-wfbB04-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/saber/.virtualenvs/ydk-py/include/site/python2.7/pyang:
    running install
    running build
    running build_py
    creating build
    running install_lib
    creating /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/plugin.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/grammar.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/syntax.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/util.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/__init__.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/yang_parser.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/statements.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    creating /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators
    copying build/lib.linux-x86_64-2.7/pyang/translators/dsdl.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators
    copying build/lib.linux-x86_64-2.7/pyang/translators/schemanode.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators
    copying build/lib.linux-x86_64-2.7/pyang/translators/__init__.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators
    copying build/lib.linux-x86_64-2.7/pyang/translators/yin.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators
    copying build/lib.linux-x86_64-2.7/pyang/translators/yang.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators
    copying build/lib.linux-x86_64-2.7/pyang/hello.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/error.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/yin_parser.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    copying build/lib.linux-x86_64-2.7/pyang/types.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    creating /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/lint.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/jsonxsl.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/__init__.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/jstree.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/sample-xml-skeleton.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/name.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/hypertree.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/depend.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/check_update.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/omni.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/uml.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/capability.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/jtox.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/xmi.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/ietf.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/smi.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/plugins/tree.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins
    copying build/lib.linux-x86_64-2.7/pyang/xpath.py -> /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugin.py to plugin.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/grammar.py to grammar.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/syntax.py to syntax.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/util.py to util.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/__init__.py to __init__.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/yang_parser.py to yang_parser.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/statements.py to statements.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators/dsdl.py to dsdl.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators/schemanode.py to schemanode.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators/__init__.py to __init__.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators/yin.py to yin.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/translators/yang.py to yang.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/hello.py to hello.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/error.py to error.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/yin_parser.py to yin_parser.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/types.py to types.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/lint.py to lint.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/jsonxsl.py to jsonxsl.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/__init__.py to __init__.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/jstree.py to jstree.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/sample-xml-skeleton.py to sample-xml-skeleton.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/name.py to name.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/hypertree.py to hypertree.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/depend.py to depend.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/check_update.py to check_update.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/omni.py to omni.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/uml.py to uml.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/capability.py to capability.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/jtox.py to jtox.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/xmi.py to xmi.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/ietf.py to ietf.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/smi.py to smi.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/plugins/tree.py to tree.pyc
    byte-compiling /home/saber/.virtualenvs/ydk-py/lib/python2.7/site-packages/pyang/xpath.py to xpath.pyc
    creating /home/saber/.virtualenvs/ydk-py/share
    creating /home/saber/.virtualenvs/ydk-py/share/man
    creating /home/saber/.virtualenvs/ydk-py/share/man/man1
    creating /home/saber/.virtualenvs/ydk-py/share/yang
    creating /home/saber/.virtualenvs/ydk-py/share/yang/modules
    creating /home/saber/.virtualenvs/ydk-py/share/yang/modules/iana
    creating /home/saber/.virtualenvs/ydk-py/share/yang/modules/ietf
    creating /home/saber/.virtualenvs/ydk-py/share/yang/xslt
    creating /home/saber/.virtualenvs/ydk-py/share/yang/images
    creating /home/saber/.virtualenvs/ydk-py/share/yang/schema
    creating /home/saber/.virtualenvs/ydk-py/etc
    creating /home/saber/.virtualenvs/ydk-py/etc/bash_completion.d
Command "/home/saber/.virtualenvs/ydk-py/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-kTgihB/pyang/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-wfbB04-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/saber/.virtualenvs/ydk-py/include/site/python2.7/pyang" failed with error code 1 in /tmp/pip-build-kTgihB/pyang/
Succesful log:
ecdsa (0.13)
enum34 (1.1.3)
lxml (3.4.4)
paramiko (1.15.2)
pip (8.1.2)
pycrypto (2.6.1)
setuptools (28.8.0)
wheel (0.29.0)
(ydk-py) λ ~/ ls -al Downloads/
total 45440
drwxr-xr-x  2 saber saber     4096 Jan 20 18:17 .
drwxr-xr-x 34 saber saber     4096 Jan 20 18:19 ..
-rw-rw-r--  1 saber saber    86911 Jan 20 18:17 ecdsa-0.13-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber    61307 Jan 20 18:17 enum34-1.1.3-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber    12427 Jan 20 18:17 enum34-1.1.6-py2-none-any.whl
-rw-rw-r--  1 saber saber  3537508 Jan 20 18:17 lxml-3.4.4.tar.gz
-rw-rw-r--  1 saber saber  6759203 Jan 20 18:17 lxml-3.7.2-cp27-cp27m-manylinux1_x86_64.whl
-rw-rw-r--  1 saber saber   201470 Jan 20 18:17 m3-libxml2-python-2.6.9.tar.gz
-rw-rw-r--  1 saber saber    63151 Jan 20 18:17 ncclient-0.5.3.tar.gz
-rw-rw-r--  1 saber saber  1220578 Jan 20 18:17 paramiko-1.15.2.tar.gz
-rw-rw-r--  1 saber saber   172565 Jan 20 18:17 paramiko-2.1.1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber    96932 Jan 20 18:17 pbr-1.10.0-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber  1198961 Jan 20 18:17 pip-8.1.2-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber  1254803 Jan 20 18:17 pip-9.0.1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber   114913 Jan 20 18:17 protobuf-3.0.0b2.post2.tar.gz
-rw-rw-r--  1 saber saber   347537 Jan 20 18:17 protobuf-3.1.0.post1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber   299884 Jan 20 18:17 pyang-1.6-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber   300545 Jan 20 18:17 pyang-1.7.1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber   446240 Jan 20 18:17 pycrypto-2.6.1.tar.gz
-rw-rw-r--  1 saber saber    10341 Jan 20 18:17 six-1.10.0-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber    38891 Jan 20 18:17 stevedore-1.19.1-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber  2938611 Jan 20 18:17 Twisted-16.1.1.tar.bz2
-rw-rw-r--  1 saber saber  2986179 Jan 20 18:17 Twisted-16.7.0rc1.tar.bz2
-rw-rw-r--  1 saber saber  1820727 Jan 20 18:17 virtualenv-15.1.0-py2.py3-none-any.whl
-rw-rw-r--  1 saber saber     5691 Jan 20 18:17 virtualenv-clone-0.2.6.tar.gz
-rw-rw-r--  1 saber saber    90599 Jan 20 18:17 virtualenvwrapper-4.7.2.tar.gz
-rw-rw-r--  1 saber saber 22241779 Jan 20 18:17 ydk-py-0.5.2.zip
-rw-rw-r--  1 saber saber   150572 Jan 20 18:17 zope.interface-4.3.3.tar.gz
Successfully installed Twisted-16.1.1 ncclient-0.5.3 protobuf-3.0.0b2.post2 pyang-1.6 six-1.10.0 ydk-0.5.2 zope.interface-4.3.3
