Highlighted
kindly let us know xml filter is correct or wrong for the cli
kindly let us know xml filter is correct or wrong for the corresponding cli
we are using ncclient to get xml output from cisco router
RP/0/RP0/CPU0:dedsdf1001jl1#show bgp ipv4 labeled-unicast neighbors 10.80.68.67 advertised-routes
Wed May 10 05:07:24.387 EDT
Network            Next Hop        From            AS Path
10.0.6.0/32        10.60.63.61     10.61.0.229     ?
10.0.6.1/32        10.60.63.61     10.61.0.229     ?
def read(host, user, password):
    try:
        with manager.connect(host=host,  username=user, password=password, look_for_keys=False,timeout=100) as m:
            bgp_filter = '''
      <bgp xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-bgp-oper">
        <instances>
          <instance>
            <instance-name>default</instance-name>
            <instance-active>
              <default-vrf>
                <afs>
                  <af>
                    <af-name>ipv4-labeled-unicast</af-name>
                    <advertised-path-xr>
                     <advertised-path>
                        <neighbor-address/>
                        <path-information>
                          <bgp-prefix>
                            <prefix>
                              <afi/>
                              <ipv4-address/>
                            </prefix>
                          </bgp-prefix>
                          <neighbor-address>
                            <afi/>
                            <ipv4-address/>
                          </neighbor-address>
                          <next-hop>
                            <afi/>
                            <ipv4-address/>
                          </next-hop>
                        </path-information>
                      </advertised-path>
                    </advertised-path-xr>
                  </af>
                </afs>
              </default-vrf>
            </instance-active>
          </instance>
        </instances>
      </bgp>
            cisco_bgp = m.get(('subtree', bgp_filter))
            print (cisco_bgp)
We are not getting exact next-hop out put with the above xml-filter . kindly let us know the same
Jay
1 ACCEPTED SOLUTION
Highlighted
Beginner
Hi Jay,
The request looks correct to me, but there is a different table for advertised paths (which includes ad paths). Below is a sample request. Could you please try this:
<get>
<filter type="subtree">
   <instances>
    <instance>
      <instance-active>
       <default-vrf>
        <afs>
         <af>
          <af-name>ipv4-unicast</af-name>
           <advertised-paths>
            <advertised-path>
             <paths>
              <neighbor-address-xr/>
              <path-information>
               <bgp-prefix>
                <prefix>
                 <afi/>
                 <ipv4-address/>
                </prefix>
               </bgp-prefix>
               <neighbor-address>
                <afi/>
                <ipv4-address/>
               </neighbor-address>
               <next-hop>
                <afi/>
                <ipv4-address/>
               </next-hop>
              </path-information>
             </paths>
            </advertised-path>
           </advertised-paths>
          </af>
         </afs>
        </default-vrf>
       </instance-active>
     </instance>
   </instances>
</bgp>
</filter>
</get>
---------- OUTPUT ----
----------- Received from NETCONF agent --------------
#1340
<?xml version="1.0"?>
<rpc-reply message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<data>
   <instances>
    <instance>
     <instance-active>
      <default-vrf>
       <afs>
        <af>
         <advertised-paths>
          <advertised-path>
           <rd>0000000000000000</rd>
           <network>0d000100</network>
           <prefix-length>24</prefix-length>
           <neighbor-address>10.10.10.1</neighbor-address>
           <paths>
            <neighbor-address-xr>
             <afi>ipv4</afi>
             <ipv4-address>10.10.10.1</ipv4-address>
            </neighbor-address-xr>
            <path-information>
             <bgp-prefix>
              <prefix>
               <afi>ipv4</afi>
               <ipv4-address>13.0.1.0</ipv4-address>
              </prefix>
             </bgp-prefix>
             <neighbor-address>
              <afi>ipv4</afi>
              <ipv4-address>0.0.0.0</ipv4-address>
             </neighbor-address>
             <next-hop>
              <afi>ipv4</afi>
              <ipv4-address>10.10.10.2</ipv4-address>
             </next-hop>
            </path-information>
           </paths>
          </advertised-path>
#165
         </advertised-paths>
        </af>
       </afs>
      </default-vrf>
     </instance-active>
    </instance>
   </instances>
  </bgp>
</data>
</rpc-reply>
1 REPLY 1
Highlighted
Beginner
Hi Jay,
<get>
   <instances>
    <instance>
      <instance-active>
       <default-vrf>
        <afs>
         <af>
           <advertised-paths>
            <advertised-path>
             <paths>
              <path-information>
               <bgp-prefix>
                <prefix>
                 <afi/>
                 <ipv4-address/>
                </prefix>
               </bgp-prefix>
               <neighbor-address>
                <afi/>
                <ipv4-address/>
               </neighbor-address>
               <next-hop>
                <afi/>
                <ipv4-address/>
               </next-hop>
              </path-information>
             </paths>
            </advertised-path>
           </advertised-paths>
          </af>
         </afs>
        </default-vrf>
       </instance-active>
     </instance>
   </instances>
</bgp>
</filter>
</get>
#1340
<data>
   <instances>
    <instance>
     <instance-active>
      <default-vrf>
       <afs>
        <af>
         <advertised-paths>
          <advertised-path>
           <paths>
             <afi>ipv4</afi>
            <path-information>
             <bgp-prefix>
              <prefix>
               <afi>ipv4</afi>
              </prefix>
             </bgp-prefix>
             <neighbor-address>
              <afi>ipv4</afi>
             </neighbor-address>
             <next-hop>
              <afi>ipv4</afi>
             </next-hop>
            </path-information>
           </paths>
          </advertised-path>
#165
         </advertised-paths>
        </af>
       </afs>
      </default-vrf>
     </instance-active>
    </instance>
   </instances>
  </bgp>
</data>
</rpc-reply>
Content for Community-Ad
Cisco Community October 2020 Spotlight Award Winners
