Highlighted
May I know if any project in Github DevNet regarding YDK ?
Hello Sir,
There are only some examples in http://ydk.cisco.com/py/docs/developer_guide.html
If I would like to learn YDK more deeply I think reading excellent programmer's coding is best way.
Do we have any project regarding YDK in Github DevNet which we could refer to ?   Or other approaches to develop the ability to play with YDK more well ?
Thanks a lot
Jacky Zhang
Global Telecom
1 ACCEPTED SOLUTION
Highlighted
Participant
Please check this repository for multiple samples of YDK empowered scripts. Also, under ydk-gen/sdk/python/core/tests you can find hundreds unit tests for all YDK capabilities.
Yan Gorelik
YDK Solutions
1 REPLY 1
Highlighted
Participant
Yan Gorelik
YDK Solutions
