12-14-2019 08:48 PM
Received the following error when running the below code and not sure how to troubleshoot it or see if it's a known bug on the code level I'm running on the switch or YDK library (any pointers on where to look for open bugs would be appreciated too).
Error:
>>> native_model = netconf_service.get_config(nd_provider, Datastore.running)
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/home/dpeterson/NetAutomation/lib/python3.6/site-packages/ydk/services/netconf_service.py", line 108, in get_config
return _ns_get(provider, source, read_filter, self._ns.get_config)
File "/home/dpeterson/NetAutomation/lib/python3.6/site-packages/ydk/services/netconf_service.py", line 153, in _ns_get
return _read_entities(provider, get_config=is_config)
File "/usr/lib/python3.6/contextlib.py", line 99, in __exit__
self.gen.throw(type, value, traceback)
File "/home/dpeterson/NetAutomation/lib/python3.6/site-packages/ydk/errors/error_handler.py", line 82, in handle_runtime_error
_raise(_exc)
File "/home/dpeterson/NetAutomation/lib/python3.6/site-packages/ydk/errors/error_handler.py", line 54, in _raise
exec("raise exc from None")
File "<string>", line 1, in <module>
ydk.errors.YCoreError: Couldn't fetch child entity 'cisco-ospf:redistribution' in parent /ietf-routing:routing/routing-instance[name='default']/routing-protocols/routing-protocol[type='ietf-ospf:ospfv2'][name='1']/ietf-ospf:ospf/instance[af='ietf-routing:ipv4']
Code:
from ydk.providers import NetconfServiceProvider
from ydk.services import NetconfService, Datastore
from ydk.models.cisco_ios_xe import Cisco_IOS_XE_native \
as xe_native
import json
import yaml
class network_device(object):
# The class "constructor" - It's actually an initializer
def __init__(self, hostname, ssh_port = 22, yang_port = 830, username = "dnac_admin", password = "******"):
self.hostname = hostname
self.ssh_port = ssh_port
self.yang_port = yang_port
self.username = username
self.password = password
self.protocol = "ssh"
device = network_device("172.19.247.222")
nd_provider = NetconfServiceProvider(address=device.hostname,
port=device.yang_port,
username=device.username,
password=device.password,
protocol = device.protocol)
netconf_service = NetconfService()
test = netconf_service.get_config(nd_provider, Datastore.running)
12-14-2019 11:22 PM
12-15-2019 09:13 AM - edited 12-15-2019 09:15 AM
12-15-2019 09:53 AM
I found this error in the log:
Data is invalid according to the yang model. Libyang error: Invalid keyword "[1-9][0-9]{1,2}|[1-9])\.\.(409[0-4]|"".
Data is invalid according to the yang model. Libyang error: Module "openconfig-vlan-types" parsing failed.
This error points to a bug in third party library libyang, which I have fixed yesterday. In order to get the fix you need recompile libydk and reinstall core components. Here is simplified procedure:
git clone -b 0.8.4 https://github.com/CiscoDevNet/ydk-gen.git
cd ydk-gen
./generate.py --core --cpp -is
./generate.py --core --python -is
12-15-2019 01:10 PM
I'll try and get that going a little later today or tomorrow and validate the fix, thank you. Out of curiosity (and not meaning to dogpile) but I will occasionally receive a segmentation fault when connecting to a switch. It will typically clear out and I can't find a rhyme or reason but it seams like it's almost like the switch has to wake up or something and then it starts working. I know that doesn't help but is it a known instance and possibly related to this library? Last couple of lines I see before error shown below. If this is a separate topic just let me know and I'll create another post accordingly, thanks.
Going into child routing-protocol in parent /ietf-routing:routing/routing-instance[name='default']/routing-protocols
Looking for 'routing-protocol'
Created entity child 'routing-protocol' in parent '/ietf-routing:routing/routing-instance[name='default']/routing-protocols'
Looking at parent entity 'routing-protocol'
Looking at child leaf '/ietf-routing:routing/routing-instance[name='default']/routing-protocols/routing-protocol[type='ietf-routing:static'][name='1']/type'
Creating entity leaf 'type' of value 'ietf-routing:static' in parent '/ietf-routing:routing/routing-instance[name='default']/routing-protocols/routing-protocol[type='ietf-routing:static'][name='1']'
Created entity leaf 'type' of value 'ietf-routing:static' in parent '/ietf-routing:routing/routing-instance[name='default']/routing-protocols/routing-protocol[type='ietf-routing:static'][name='1']'
Looking at child leaf '/ietf-routing:routing/routing-instance[name='default']/routing-protocols/routing-protocol[type='ietf-routing:static'][name='1']/name'
Creating entity leaf 'name' of value '1' in parent '/ietf-routing:routing/routing-instance[name='default']/routing-protocols/routing-protocol[type='ietf-routing:static'][name='1']'
Created entity leaf 'name' of value '1' in parent '/ietf-routing:routing/routing-instance[name='default']/routing-protocols/routing-protocol[type='ietf-routing:static'][name='1']'
Segmentation fault (core dumped)
12-15-2019 09:25 PM
12-16-2019 09:48 AM
So I went back through the installation process and I think I found that I have the wrong libssh library. I'm running Ubuntu 18.04 and I'm not sure how to update the package (or downgrade it if recommended). When I look around for the libssh package versions I see that 0.8.0 is for Ubuntu 18.04 (which I'm running) any quick pointers on how to get to a good release for libssh?
(NetAutomation) dpeterson@Linux-DHCP:~$ apt list --installed | grep libssh
libssh-4/bionic-updates,bionic-security,now 0.8.0~20170825.94fa1e38-1ubuntu0.5 amd64 [installed]
libssh-dev/bionic-updates,bionic-security,now 0.8.0~20170825.94fa1e38-1ubuntu0.5 amd64 [installed]
12-16-2019 01:11 PM
The libssh installation is described here on the GitHub. Please make sure the system requirements are satisfied before the compilation.
