05-22-2017 04:21 PM
Hi, All!
Would this be the correct community to post Yang Model code and XML Template code for NSO and get advice to be able to fix problems? If not, can anybody point in the right direction?
Thanks!
c.
Solved! Go to Solution.
05-23-2017 09:06 AM
For any NSO related discussions, code or even downloads (to those who are entitled), I would say the right place to go is the NSO Developer Hub at Cisco DevNet: cisco.com/go/nsodevnet Then click "The NSO Developer Hub" to get straight to the discussion forum.
05-23-2017 09:06 AM
05-23-2017 03:49 PM
Thank you very much, Jan. Will do!
