03-07-2018 01:28 PM
I'm trying to use ydk to configure Huawei VRP devices using netconf.
So far, I've managed to generate the ydk for the Huawei YANG files (located here: https://github.com/Huawei/yang), and have started to play with the API.
I've got a simple bit of code as so:
from ydk.services import CRUDService
from ydk.providers import NetconfServiceProvider
from ydk.models.huawei import huawei_ifm
provider = NetconfServiceProvider(address="cor1.lond2.lab",
port=22,
username="username",
password="password",
protocol="ssh")
ifm = huawei_ifm.Ifm.Interfaces.Interface()
ifm.ifname = 'GigabitEthernet1/1/1.200'
ifm.ifparentifname = 'GigabitEthernet1/1/1'
ifm.ifmtu = 9600
ifm.ifdescr = "This is a test description"
crud = CRUDService()
interface = crud.create(provider, ifm)
From the debugs, the netconf session connects, so that part all looks good. The issue appears to be with the generating of the API call.
Traceback (most recent call last):
File "test.py", line 19, in <module>
File "/home/dave/.virtualenvs/py2/local/lib/python2.7/site-packages/ydk/errors/error_handler.py", line 112, in helper
return func(self, provider, entity, *args, **kwargs)
File "/home/dave/.virtualenvs/py2/local/lib/python2.7/site-packages/ydk/services/crud_service.py", line 30, in create
return self._crud.create(provider, entity)
File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
self.gen.throw(type, value, traceback)
File "/home/dave/.virtualenvs/py2/local/lib/python2.7/site-packages/ydk/errors/error_handler.py", line 82, in handle_runtime_error
_raise(_exc)
File "/home/dave/.virtualenvs/py2/local/lib/python2.7/site-packages/ydk/errors/error_handler.py", line 56, in _raise
raise exc
ydk.errors.YPYInvalidArgumentError: Path is invalid: huawei-ifm:ifm/interfaces/interface[ifName='GigabitEthernet1/1/1.200']
The path according to the YANG file is valid however:
yang -f tree --tree-path="ifm/interfaces" huawei-ifm.yang | head -n 6
module: huawei-ifm
+--rw ifm
+--rw interfaces
+--rw interface* [ifName]
+--rw ifName pub-type:ifName
+--ro ifIndex? uint32
Using the CodecService this does appear to generate something that looks correct however. If I alter my code, I get this:
Code:
from ydk.services import CodecService
from ydk.providers import CodecServiceProvider
provider = CodecServiceProvider(type='xml')
codec = CodecService()
ifm.ifmtu = 9600
print (codec.encode(provider, ifm))
Output:
<interface xmlns="http://www.huawei.com/netconf/vrp/huawei-ifm">
<ifName>GigabitEthernet1/1/1.200</ifName>
<ifParentIfName>GigabitEthernet1/1/1</ifParentIfName>
<ifDescr>This is a test description</ifDescr>
<ifMtu>9600</ifMtu>
</interface>
Any ideas or clues would be greatly appreciated!
Dave
Solved! Go to Solution.
03-12-2018 07:56 AM
CRUD Service create always uses the merge operation. You may want to use the NetconfService (http://ydk.cisco.com/py/docs/api/services/netconf_service.html) which lets you define custom operations.
interface = netconf_service.edit_config(provider, DataStore.running, ifm_obj)
03-08-2018 01:00 PM
Hi Dave,
Can you please try the below? You can try passing in the top level object
from ydk.services import CRUDService from ydk.providers import NetconfServiceProvider from ydk.models.huawei import huawei_ifm provider = NetconfServiceProvider(address="cor1.lond2.lab", port=22, username="username", password="password", protocol="ssh") ifm_obj = huawei_ifm.Ifm() ifm = huawei_ifm.Ifm.Interfaces.Interface() ifm.ifname = 'GigabitEthernet1/1/1.200' ifm.ifparentifname = 'GigabitEthernet1/1/1' ifm.ifmtu = 9600 ifm.ifdescr = "This is a test description" ifm_obj.interfaces.interface.append(ifm) crud = CRUDService() interface = crud.create(provider, ifm_obj)
See the below open issue for why this is needed:
https://github.com/CiscoDevNet/ydk-gen/issues/603
Abhi
03-08-2018 01:17 PM
Hi Abhi,
Thanks for your response.
I gave that a go, but no luck. I now get the following error.
File "test2.py", line 23, in <module>
_raise(_exc)
raise exc
Using the Codec Service to print out the contents of ifm_obj does look better however:
<ifm xmlns="http://www.huawei.com/netconf/vrp/huawei-ifm">
<interfaces>
<interface>
<ifMtu>9600</ifMtu>
</interface>
</interfaces>
</ifm>
This is the same XML that I use when creating the netconf requests manually.
Dave
03-08-2018 01:44 PM
Further to this, I've added some logging, and am seeing the following:
Path where models are to be downloaded: /home/dave/.ydk/cor1.lond2.lab:22
Connected to cor1.lond2.lab on port 22 using ssh with timeout of -1
Executing CRUD create operation
Data is invalid according to the yang model. Error details: Invalid keyword "
Data is invalid according to the yang model. Error details: Module parsing failed.
Data is invalid according to the yang model. Error details: Importing "huawei-ifm" module into "huawei-ifm-deviations-OC-NE-X3" failed.
Data is invalid according to the yang model. Error details: Module "huawei-ifm-deviations-OC-NE-X3" parsing failed.
Data is invalid according to the yang model. Error details: Module not found. Path: '/huawei-ifm'
Path 'huawei-ifm:ifm' is invalid
File "test2.py", line 28, in <module>
_raise(_exc)
raise exc
Disconnected from device
Looking at the files that are in the folder /home/dave/.ydk/cor1.lond2:22, I'm seeing a lot of junk:
Copyright (C) 2013-2017 Huawei Technologies Co., Ltd. All rights reserved.
module huawei-ifm {
namespace "http://www.huawei.com/netconf/vrp/huawei-ifm";
prefix ifm;
import huawei-pub-type {
prefix pub-type;
import huawei-rsa {
prefix rsa;
import ietf-inet-types {
prefix inet;
import huawei-extension {
prefix ext;
Where are these models being obtained from? Is it from the device itself?
Dave
03-09-2018 07:20 AM
I've done more digging. The yang models it is complaining about are indeed being sent by the device.
I believe this could be a YDK bug. When debugging on the device I am attempting to configure, it shows the module being sent looking like:
<?xml version="1.0" encoding="UTF-8"?>
<rpc-reply message-id="1" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<data xmlns="urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring">/*
submodule huawei-rsa-type {
belongs-to huawei-rsa {
prefix rsa;
organization
"Huawei Technologies Co.,Ltd.";
contact
"Huawei Industrial
As this is XML, I think the character encoding is probably OK. I notice that some of them are correctly being decoded, such as &qout; for quotes when it is stored in the cache directory under ~/.ydk/device/
The codes I've encountered so far which are not being decoded are:
I tried to investigate into the ydk sdk code, but I have no clue as to where any decoding may be done. Can anyone confirm if this encoding should be there, so I can rase an issue with the correct people.
I fixed up the local cache of the downloaded YANG files, and its now generating an RPC call:
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<edit-config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<target>
<candidate/>
</target>
<error-option>rollback-on-error</error-option>
<config><ifm xmlns="http://www.huawei.com/netconf/vrp/huawei-ifm" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" nc:operation="merge">
<interfaces>
<interface>
<ifName>GigabitEthernet0/2/6.200</ifName>
<ifParentIfName>GigabitEthernet0/2/6</ifParentIfName>
<ifMtu>9600</ifMtu>
</interface>
</interfaces>
</ifm>
</config>
</edit-config>
</rpc>
The response I'm getting is the following:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="1">
<rpc-error>
<error-type>application</error-type>
<error-tag>operation-not-supported</error-tag>
<error-severity>error</error-severity>
<error-message>This operation is not supported.</error-message>
<error-info>
<bad-attribute>operation</bad-attribute>
<bad-element>ifm</bad-element>
</error-info>
</rpc-error>
</rpc-reply>
Further investigation shows that the kit I'm using doesn't support merge - it only supports create. The documentation I'm reading says that ydk doesn't support create, only merge. Is this right?
Dave
03-09-2018 03:26 PM
The issue with weird characters was fixed recently. The fix will be included as part of the next release of ydk (0.7.1)
03-11-2018 04:18 PM
Thanks for your response. I've submitted a PR to fix the also.
Do you have any ideas about the second part of my issue?
Dave
03-11-2018 07:55 PM
Sorry I missed that. YDK does support create. Not sure where you saw that YDK only supports merge.
Please refer to the example here and use 'YFIlter.create' instead of 'YFilter.replace':
http://ydk.cisco.com/py/docs/guides/crud_guide.html#creating-and-replacing-a-configuration
03-12-2018 03:36 AM
Thanks for your help so far, I feel I'm getting very close.
This is what I have so far:
from ydk.filters import YFilter
# Logging
import logging
log = logging.getLogger('ydk')
log.setLevel(logging.INFO)
handler = logging.StreamHandler()
log.addHandler(handler)
port=22,
username="user",
password="pass",
protocol="ssh")
ifm.ifname = 'GigabitEthernet0/2/6.200'
ifm.ifparentifname = 'GigabitEthernet0/2/6'
ifm.ifmtu = 9600
ifm.yfilter = YFilter.create
ifm_obj.yfilter = YFilter.not_set
This produces the following:
<target>
<candidate/>
</target>
<interfaces>
<interface nc:operation="create">
<ifMtu>9600</ifMtu>
</interface>
</interfaces>
</ifm>
</config>
</edit-config>
</rpc>
That merge operation on the ifm object needs to be removed. Setting the YFilter on the ifm object seems to do nothing. Am I doing something wrong again?
Dave
03-12-2018 07:56 AM
03-12-2018 10:05 AM
Awesome, that was the last push I needed! Using the netconf service works well.
For completion, my full test script is as follows.
from ydk.services import NetconfService, Datastore
# Logging
import logging
port=22,
username="user",
password="pass",
protocol="ssh")
netconf = NetconfService()
ifm.ifmtu = 9600
interface = netconf.edit_config(provider, Datastore.running, ifm_obj)
Dave
03-12-2018 11:17 AM
Great! Glad it worked
