Highlighted
Sample apps for XR SR mapping configuration
Related image
Hello Community,
I have added a new set of sample applications which configure segment routing SID mappings (IPv4 and IPv6) for XR data model using the gNMI provider and the CRUD service.
This set of sample applications includes the following four boilerplate apps and five custom apps:
gn-create-xr-segment-routing-ms-cfg-10-ydk.py - create boilerplate
gn-create-xr-segment-routing-ms-cfg-20-ydk.py - IPv4 single mapping
gn-create-xr-segment-routing-ms-cfg-21-ydk.py - IPv6 single mapping
gn-create-xr-segment-routing-ms-cfg-22-ydk.py - IPv4 multiple mappings
gn-create-xr-segment-routing-ms-cfg-23-ydk.py - IPv6 multiple mappings
gn-delete-xr-segment-routing-ms-cfg-10-ydk.py - delete boilerplate
gn-delete-xr-segment-routing-ms-cfg-20-ydk.py - delete all mapping cfg
gn-read-xr-segment-routing-ms-cfg-10-ydk.py   - read boilerplate
gn-update-xr-segment-routing-ms-cfg-10-ydk.py - update boilerplate
 These python files, JSON files, and CLI config files are all located in the following directory:
https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic/crud/gnmi/models/cisco-ios-xr/Cisco-IOS-XR-segment-routing-ms-cfg
Start your day with YDK-py sample apps!
Best,
0 REPLIES 0
Content for Community-Ad
Cisco Community October 2020 Spotlight Award Winners
