Highlighted
Beginner
Sample apps for XR syslog using CRUD/gNMI
Hi there,
I am introducing a new set of sample applications which configures syslog and debug timestamps for XR data model using the CRUD service and the gNMI provider.
This set of sample applications include eight boilerplate applications and seventeen custom applications:
gn-create-xr-infra-syslog-cfg-10-ydk.py - Create boilerplate
gn-create-xr-infra-syslog-cfg-11-ydk.py - Create boilerplate
gn-create-xr-infra-syslog-cfg-20-ydk.py - Disable log timestamps
gn-create-xr-infra-syslog-cfg-22-ydk.py - Uptime log timestamps
gn-create-xr-infra-syslog-cfg-24-ydk.py - Local time log timestamps
gn-create-xr-infra-syslog-cfg-26-ydk.py - Local time log/debug timest.
gn-create-xr-infra-syslog-cfg-28-ydk.py - Detailed log/debug timestamp
gn-create-xr-infra-syslog-cfg-30-ydk.py - Logging console disable
gn-create-xr-infra-syslog-cfg-32-ydk.py - Logging buffered
gn-create-xr-infra-syslog-cfg-40-ydk.py - Logging archive disk1
gn-create-xr-infra-syslog-cfg-42-ydk.py - Logging archive harddisk
gn-create-xr-infra-syslog-cfg-50-ydk.py - ipv4 remote logging server
gn-create-xr-infra-syslog-cfg-51-ydk.py - ipv6 remote logging server
gn-create-xr-infra-syslog-cfg-52-ydk.py - ipv4 remote logging server w/VRF
gn-create-xr-infra-syslog-cfg-53-ydk.py - ipv6 remote logging server w/VRF
gn-create-xr-infra-syslog-cfg-60-ydk.py - Logging suppression
gn-create-xr-infra-syslog-cfg-62-ydk.py - Logging correlation
gn-delete-xr-infra-syslog-cfg-10-ydk.py - Delete boilerplate
gn-delete-xr-infra-syslog-cfg-11-ydk.py - Delete boilerplate
gn-delete-xr-infra-syslog-cfg-20-ydk.py - Delete all timestamp config
gn-delete-xr-infra-syslog-cfg-30-ydk.py - Delete all logging config
gn-read-xr-infra-syslog-cfg-10-ydk.py   - Read boilerplate
gn-read-xr-infra-syslog-cfg-11-ydk.py   - Read boilerplate
gn-update-xr-infra-syslog-cfg-10-ydk.py - Update boilerplate
gn-update-xr-infra-syslog-cfg-11-ydk.py - Update boilerplate
 You can find the python files, JSON files, and CLI files in the following directory: https://github.com/deom119/ydk-py-samples/tree/master/samples/basic/crud/gnmi/models/cisco-ios-xr/Cisco-IOS-XR-infra-syslog-cfg
Everyone's tags (5)
Content for Community-Ad
August's Community Spotlight Awards
