Has anyone been able to work with YDK using IOS XRv 6.0.1 or IOS XRv 6.1.3 routers?
mohammadyasini
There is no bundle for these two versions after I did the "Second step: Generate & install the core" mentioned here :
https://github.com/CiscoDevNet/ydk-gen
I tried to make the bundle based on the list of availabe Yang models these routers have inside (for instance for XRv 6.1.3), as bellow, and then I installed that bundle:
   "name":"cisco-ios-xr",
   "description":"YDK bundle for Cisco IOS XR models",
   "version":"6.1.3",
   "core_version": "0.7.1",
   "author":"Cisco",
   "copyright":"Cisco",
   "models":{
      "description":"Each element on the list has details on git repositories to source models from, including commit ids and relative paths inside the repositories. If no commit id is specified, HEAD is taken. This is unwise. The nested dir and file references are interpreted the same way as specific dir and file references above.",
      "git":[
            "url":"https://github.com/YangModels/yang.git",
            "commits":[
                  "commitid":"0f20a6f9cbe2fea382235ab13884f4c0bd15a6df",
                  "file":[
                     "vendor/cisco/xr/613/Cisco-IOS-XR-Ethernet-SPAN-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-Ethernet-SPAN-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-Ethernet-SPAN-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-Ethernet-SPAN-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-Ethernet-SPAN-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-Ethernet-SPAN-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-Ethernet-SPAN-subscriber-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-lib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-locald-admin-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-locald-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-locald-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-locald-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-protocol-radius-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-protocol-radius-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-protocol-radius-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-protocol-radius-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-tacacs-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-tacacs-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-aaa-tacacs-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-alarmgr-server-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-alarmgr-server-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asic-errors-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asic-errors-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asic-errors-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-asic-errors-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-asic-errors-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-fsi-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-fsi-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-lc-ethctrl-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-lc-ethctrl-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-lc-ethctrl-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-lpts-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-lpts-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-netflow-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-netflow-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-netflow-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-netflow-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-netflow-oper-sub5.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-netflow-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-np-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-np-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-prm-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-qos-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-qos-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-qos-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-sc-envmon-admin-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-sc-envmon-admin-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-sc-envmon-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-sc-envmon-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-sc-invmgr-admin-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-sc-invmgr-admin-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-sc-invmgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-asr9k-sc-invmgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-atm-common-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-atm-vcm-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-atm-vcm-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-atm-vcm-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-atm-vcm-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-atm-vcm-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-atm-vcm-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-bundlemgr-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-bundlemgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-bundlemgr-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-bundlemgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-cdp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-cdp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-cdp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-cfgmgr-rollback-act.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-clns-isis-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-clns-isis-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-clns-isis-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-clns-isis-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-clns-isis-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-cmproxy-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-cmproxy-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-common-acl-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-config-cfgmgr-exec-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-config-cfgmgr-exec-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-config-mda-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-config-mibs-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-controller-optics-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-controller-optics-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-controller-optics-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-controller-otu-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-controller-otu-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-controller-otu-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-macsec-mka-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-macsec-mka-if-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-macsec-mka-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-macsec-mka-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-macsec-pl-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-macsec-pl-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-macsec-secy-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-macsec-secy-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-sam-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-sam-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-sam-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-ssh-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-ssh-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-crypto-ssh-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-driver-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-driver-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-netflow-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-netflow-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-netflow-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-netflow-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-netflow-oper-sub5.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-netflow-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-port-mapper-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dnx-port-mapper-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-drivers-icpe-ethernet-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-drivers-media-eth-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-drivers-media-eth-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-drivers-media-eth-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dwdm-ui-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dwdm-ui-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-dwdm-ui-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-es-ace-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-es-acl-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-es-acl-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-es-acl-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-es-acl-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-cfm-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-cfm-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-cfm-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-cfm-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-cfm-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-cfm-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-cfm-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-cfm-sat-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-link-oam-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-link-oam-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-link-oam-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-lldp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-lldp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-lldp-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ethernet-lldp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fia-hw-profile-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fia-internal-tcam-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fia-internal-tcam-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fib-common-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fib-common-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fib-common-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fib-common-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fib-common-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fib-common-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-flashmib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-drop-stats-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-drop-stats-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-hw-resources-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-hw-resources-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-hw-resources-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-npu-stats-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-npu-stats-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-resources-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-resources-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-fretta-bcm-dpa-resources-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-group-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ha-eem-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ha-eem-policy-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ha-eem-policy-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-oper-sub5.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-oper-sub6.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-oper-sub7.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-oper-sub8.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-icpe-infra-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-iedge4710-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-iedge4710-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-iedge4710-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-iedge4710-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-iedge4710-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ifmgr-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ifmgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ifmgr-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ifmgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-alarm-logger-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-alarm-logger-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-alarm-logger-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-alarm-logger-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-ceredundancymib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-confcopymib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-correlator-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-correlator-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-correlator-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-dumper-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-infra-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-infra-clock-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-infra-clock-linux-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-infra-locale-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-ltrace-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-objmgr-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-objmgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-objmgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-policymgr-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-policymgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-policymgr-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-policymgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rcmd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rcmd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rcmd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rmf-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rmf-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rsi-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rsi-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rsi-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rsi-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-rsi-subscriber-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-sla-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-sla-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-sla-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-statsd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-statsd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-statsd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-syslog-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-syslog-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-syslog-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-systemmib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-tc-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-tc-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-infra-tc-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-installmgr-admin-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-installmgr-admin-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-installmgr-admin-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-installmgr-admin-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-invmgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-invmgr-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-invmgr-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-invmgr-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-invmgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-bfd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-bfd-oper-sub1-deviations.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-bfd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-bfd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-domain-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-domain-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-domain-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-iarm-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-iarm-v4-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-iarm-v4-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-iarm-v6-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-iarm-v6-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-iarm-vrf-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-icmp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-iep-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-iep-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-iep-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-mobileip-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-ntp-admin-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-ntp-admin-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-ntp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-ntp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-ntp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-pfilter-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-pfilter-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-pfilter-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-pfilter-subscriber-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-rib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-rib-ipv4-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-rib-ipv4-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-rib-ipv6-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-rib-ipv6-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-rsvp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-rsvp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-rsvp-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-rsvp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-sbfd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-sbfd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-sbfd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-static-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-tcp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-tcp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-tcp-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-tcp-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-tcp-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-tcp-oper-sub5.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-tcp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-udp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-udp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-udp-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-udp-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-udp-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ip-udp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-ace-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-acl-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-acl-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-acl-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-acl-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-arp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-arp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-arp-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-arp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-autorp-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-autorp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-autorp-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-autorp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-bgp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-bgp-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-bgp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-bgp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-dhcpd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-filesystems-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-hsrp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-hsrp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-hsrp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-igmp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-igmp-dyn-tmpl-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-igmp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-igmp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-io-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-io-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-io-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-io-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-ma-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-ma-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-ma-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-ma-subscriber-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-mfwd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-ospf-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-ospf-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-ospf-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-ospf-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-pim-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-pim-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-pim-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-pim-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-smiap-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-telnet-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-telnet-mgmt-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-vrrp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-vrrp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv4-vrrp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-ace-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-acl-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-acl-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-acl-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-acl-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-io-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-io-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-io-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-ma-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-ma-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-ma-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-ma-subscriber-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-nd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-nd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-nd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-nd-subscriber-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-new-dhcpv6d-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-new-dhcpv6d-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-new-dhcpv6d-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-new-dhcpv6d-subscriber-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-ospfv3-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-ospfv3-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-ospfv3-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ipv6-smiap-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2-eth-infra-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2-eth-infra-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2-eth-infra-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2-eth-infra-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2-eth-infra-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2-eth-infra-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2vpn-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2vpn-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2vpn-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2vpn-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2vpn-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-l2vpn-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lib-keychain-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lib-keychain-macsec-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lib-keychain-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lib-keychain-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lib-mpp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lib-mpp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lib-mpp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-linux-os-reboot-history-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-linux-os-reboot-history-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lpts-lib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lpts-pre-ifib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lpts-pre-ifib-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lpts-pre-ifib-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-lpts-punt-flowtrap-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-macsec-ctrlr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-macsec-ctrlr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-man-ems-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-man-ems-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-man-ems-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-man-netconf-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-man-xml-ttyagent-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-man-xml-ttyagent-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-man-xml-ttyagent-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-manageability-object-tracking-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-manageability-object-tracking-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-manageability-object-tracking-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-manageability-object-tracking-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-manageability-perfmgmt-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-manageability-perfmgmt-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-manageability-perfmgmt-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-manageability-perfmgmt-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mdrv-lib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-ldp-cfg-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-ldp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-ldp-oper-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-ldp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-ldp-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-ldp-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-ldp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-lsd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-lsd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-lsd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-oam-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-static-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-static-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-static-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper-sub5.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper-sub6.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper-sub7.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper-sub8.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper-sub9.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-te-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-vpn-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-mpls-vpn-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs1k-macsec-ea-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs1k-macsec-ea-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs1k-mxp-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs1k-mxp-headless-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs1k-mxp-headless-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs1k-mxp-lldp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs1k-mxp-lldp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs1k-mxp-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs1k-mxp-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs5500-coherent-node-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs5500-coherent-node-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs5500-coherent-portmode-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs5500-coherent-portmode-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs5500-qos-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs5500-qos-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-ncs5500-qos-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-nto-misc-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-nto-misc-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-nto-misc-shmem-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-nto-misc-shmem-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-nto-misc-shprocmem-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-nto-misc-shprocmem-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-openconfig-optical-client-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-openconfig-terminal-device-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-openconfig-terminal-device-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-openconfig-terminal-device-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-optics-driver-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-otnifmib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-parser-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-patch-panel-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pbr-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pbr-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pbr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pbr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pbr-subscriber-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pbr-vservice-ea-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pbr-vservice-ea-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pbr-vservice-mgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pbr-vservice-mgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pfi-im-cmd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pfi-im-cmd-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pfi-im-cmd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-plat-chas-invmgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-plat-chas-invmgr-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-plat-chas-invmgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-platform-pifib-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-platform-pifib-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pmengine-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pmengine-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-pmengine-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-policy-repository-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-policy-repository-deviations.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-policy-repository-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-policy-repository-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-prm-server-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-prm-server-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-procmem-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-procmem-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-qos-ma-bng-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-qos-ma-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-qos-ma-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-qos-mibs-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-rgmgr-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-rgmgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-rgmgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-sdr-invmgr-diag-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-sdr-invmgr-diag-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-sdr-invmgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-segment-routing-ms-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-segment-routing-ms-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-segment-routing-ms-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-shellutil-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-shellutil-filesystem-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-shellutil-filesystem-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-shellutil-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-shellutil-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-show-fpd-loc-ng-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-show-fpd-loc-ng-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-skp-qos-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-skp-qos-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-skp-qos-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-agent-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-agent-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-agent-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-agent-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-agent-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-agent-oper-sub5.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-agent-oper-sub6.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-agent-oper-sub7.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-agent-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-ciscosensormib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-entitymib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-entitymib-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-entitymib-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-entstatemib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-frucontrolmib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-ifmib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-ifmib-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-ifmib-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-mib-rfmib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-sensormib-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-sensormib-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-sensormib-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-syslogmib-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-snmp-test-trap-act.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-spirit-corehelper-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-spirit-install-instmgr-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-spirit-install-instmgr-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-spirit-install-instmgr-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-subscriber-infra-tmplmgr-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-syslog-act.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-telemetry-model-driven-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-telemetry-model-driven-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-telemetry-model-driven-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-traffmon-netflow-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-management-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-management-cmd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-management-cmd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-management-datatypes.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-management-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-management-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-server-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-server-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-server-oper-sub2.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-server-oper-sub3.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-server-oper-sub4.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-server-oper-sub5.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-server-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tty-vty-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tunnel-gre-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tunnel-nve-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tunnel-nve-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-tunnel-nve-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-types.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-upgrade-fpd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-upgrade-fpd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-vservice-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-wanphy-ui-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-wanphy-ui-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-wanphy-ui-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-watchd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-wd-cfg.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-wd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-wd-oper.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-wdsysmon-fd-oper-sub1.yang",
                     "vendor/cisco/xr/613/Cisco-IOS-XR-wdsysmon-fd-oper.yang",
                     "vendor/cisco/xr/613/cisco-xr-ietf-netconf-monitoring-deviations.yang",
                     "vendor/cisco/xr/613/cisco-xr-openconfig-bgp-policy-deviations.yang",
                     "vendor/cisco/xr/613/cisco-xr-openconfig-if-aggregate-deviations.yang",
                     "vendor/cisco/xr/613/cisco-xr-openconfig-if-ethernet-deviations.yang",
                     "vendor/cisco/xr/613/cisco-xr-openconfig-if-ip-deviations.yang",
                     "vendor/cisco/xr/613/cisco-xr-openconfig-interfaces-deviations.yang",
                     "vendor/cisco/xr/613/cisco-xr-openconfig-mpls-deviations.yang",
                     "vendor/cisco/xr/613/cisco-xr-openconfig-telemetry-deviations.yang",
                     "vendor/cisco/xr/613/cisco-xr-openconfig-vlan-deviations.yang",
                     "vendor/cisco/xr/613/cisco-xr-routing-policy-deviations.yang",
                     "vendor/cisco/xr/613/iana-if-type.yang",
                     "vendor/cisco/xr/613/ietf-inet-types.yang",
                     "vendor/cisco/xr/613/ietf-interfaces.yang",
                     "vendor/cisco/xr/613/ietf-syslog-types.yang",
                     "vendor/cisco/xr/613/ietf-yang-types.yang",
                     "vendor/cisco/xr/613/openconfig-interfaces.yang",
                     "vendor/cisco/xr/613/openconfig-mpls-igp.yang",
                     "vendor/cisco/xr/613/openconfig-mpls-ldp.yang",
                     "vendor/cisco/xr/613/openconfig-mpls-rsvp.yang",
                     "vendor/cisco/xr/613/openconfig-mpls-sr.yang",
                     "vendor/cisco/xr/613/openconfig-mpls-static.yang",
                     "vendor/cisco/xr/613/openconfig-mpls-te.yang",
                     "vendor/cisco/xr/613/openconfig-mpls-types.yang",
                     "vendor/cisco/xr/613/openconfig-mpls.yang",
                     "vendor/cisco/xr/613/openconfig-routing-policy.yang",
                     "vendor/cisco/xr/613/openconfig-telemetry.yang",
                     "vendor/cisco/xr/613/openconfig-types.yang",
                     "vendor/cisco/xr/613/openconfig-vlan.yang"
   "dependency":[
         "name":"ietf",
         "version":"0.1.1",
         "core_version":"0.5.1",
         "uri":"file://profiles/bundles/ietf_0_1_1.json"
         "name":"openconfig",
         "version":"0.1.1",
         "uri":"file://profiles/bundles/openconfig_0_1_1.json"
______________________________________________________________________________________
but after running every sample codes I received this errors:
2018-05-02 18:34:23,558 - ydk - INFO - Path where models are to be downloaded: /home/bonsai/.ydk/172.16.1.82_830
2018-05-02 18:34:23,563 - ydk - INFO - Connected to 172.16.1.82 on port 830 using ssh with timeout of -1
2018-05-02 18:34:23,563 - ydk - INFO - Executing 'get' RPC on [Cisco-IOS-XR-clns-isis-cfg:isis] from running
2018-05-02 18:34:23,564 - ydk - ERROR - Data is invalid according to the yang model. Error details: Invalid keyword "[0-9]|25[0-5])\.){3}([1-9]?[0-9]|1[0-9][0-9]|2[0-4][0-9]"".
2018-05-02 18:34:23,564 - ydk - ERROR - Data is invalid according to the yang model. Error details: Module "Cisco-IOS-XR-types" parsing failed.
2018-05-02 18:34:23,564 - ydk - ERROR - Data is invalid according to the yang model. Error details: Importing "Cisco-IOS-XR-types" module into "Cisco-IOS-XR-clns-isis-cfg" failed.
2018-05-02 18:34:23,564 - ydk - ERROR - Data is invalid according to the yang model. Error details: Module "Cisco-IOS-XR-clns-isis-cfg" parsing failed.
2018-05-02 18:34:23,564 - ydk - ERROR - Data is invalid according to the yang model. Error details: Module not found. Path: '/Cisco-IOS-XR-clns-isis-cfg'
2018-05-02 18:34:23,564 - ydk - ERROR - Path 'Cisco-IOS-XR-clns-isis-cfg:isis' is invalid
Traceback (most recent call last):
  File "cisco_xr_get_sid.py", line 136, in <module>
    mdict[management_addr] = netconf.get_config(provider, Datastore.running, isis)
  File "/usr/local/lib/python3.5/dist-packages/ydk/services/netconf_service.py", line 115, in get_config
    result = self._ns.get_config(provider, source, filters)
  File "/usr/lib/python3.5/contextlib.py", line 77, in __exit__
    self.gen.throw(type, value, traceback)
  File "/usr/local/lib/python3.5/dist-packages/ydk/errors/error_handler.py", line 82, in handle_runtime_error
    _raise(_exc)
  File "/usr/local/lib/python3.5/dist-packages/ydk/errors/error_handler.py", line 54, in _raise
    exec("raise exc from None")
  File "<string>", line 1, in <module>
ydk.errors.YInvalidArgumentError:  Path is invalid: Cisco-IOS-XR-clns-isis-cfg:isis
2018-05-02 18:34:23,596 - ydk - INFO - Disconnected from device
pip list:
ydk                     0.7.1
ydk-models-cisco-ios-xr 6.1.3
ydk-models-ietf         0.1.5
ydk-models-openconfig   0.1.5
thanks for any help that you can provide.
abhirame
Just for clarity, are you using XR 6.0.1 or 6.1.3 server? Can you try the work around suggested in the below post? Need to edit the  model under your home directory under '~/.ydk/<hostname_port>' to change double quote to single quote.
Re: XR BGP Operational
