How to remove a specific bgp neighbor
Treemanzhou1
Hi developers
     Here is my script to create a bgp neighbor , How can I  remove the neighbor then?  I tried to
def config_bgp(bgp):
    """Add config data to bgp object."""
    # global configuration
    instance = bgp.Instance()
    instance.instance_name = "default"
    instance_as = instance.InstanceAs()
    instance_as.as_ = 0
    four_byte_as = instance_as.FourByteAs()
    four_byte_as.as_ = 65000
    four_byte_as.bgp_running = Empty()
    # global address family
    global_af = four_byte_as.default_vrf.global_.global_afs.GlobalAf()
    global_af.af_name = xr_ipv4_bgp_datatypes.BgpAddressFamilyEnum.ipv4_unicast
    global_af.enable = Empty()
    four_byte_as.default_vrf.global_.global_afs.global_af.append(global_af)
    instance_as.four_byte_as.append(four_byte_as)
    instance.instance_as.append(instance_as)
    bgp.instance.append(instance)
    # configure IBGP neighbor group
    neighbor_groups = four_byte_as.default_vrf.bgp_entity.neighbor_groups
    neighbor_group = neighbor_groups.NeighborGroup()
    neighbor_group.neighbor_group_name = "IBGP"
    neighbor_group.create = Empty()
    # remote AS
    neighbor_group.remote_as.as_xx = 0
    neighbor_group.remote_as.as_yy = 65001
    neighbor_group.update_source_interface = "Loopback0"
    neighbor_groups.neighbor_group.append(neighbor_group)
    # ipv4 unicast
    neighbor_group_af = neighbor_group.neighbor_group_afs.NeighborGroupAf()
    neighbor_group_af.af_name = xr_ipv4_bgp_datatypes.BgpAddressFamilyEnum.ipv4_unicast
    neighbor_group_af.activate = Empty()
    neighbor_group_afs = neighbor_group.neighbor_group_afs
    neighbor_group_afs.neighbor_group_af.append(neighbor_group_af)
    neighbor = four_byte_as.default_vrf.bgp_entity.neighbors.Neighbor()
    neighbor.neighbor_address = "172.16.1.3"
    neighbor.neighbor_group_add_member = "IBGP"
    four_byte_as.default_vrf.bgp_entity.neighbors.neighbor.append(neighbor)
if __name__ == "__main__":
    # create NETCONF provider
    provider = NetconfServiceProvider(address="10.2.2.2.",
                                      port=830,
                                      username="cisco",
                                      password="123456",
                                      protocol="ssh")
    # create CRUD service
    crud = CRUDService()
    bgp = xr_ipv4_bgp_cfg.Bgp()  # create object
    config_bgp(bgp)  # add object configuration
    # create configuration on NETCONF device
    crud.create(provider,neighbor)
    provider.close()
    exit()
# End of script
einarnn
Have you tried using crud.delete(...)?
Yep I tried to crud.delete(provider,neighbor) but it raise the error :AttributeError: '_MetaInfoClass' object has no attribute 'namespaces'
abhirame
Can you try the below?
instance_as.as_ = 0
crud.delete(provider, neighbor)
