rob.vande.laar85
Beginner
Installation problems ydk-gen
I'm trying to install this package but I receive an error.
I've created a virtual env for this:
(py2) rob@ubuntu:ydk-gen$ pip list
alabaster (0.7.10)
Babel (2.4.0)
docutils (0.14)
gitdb (0.6.4)
GitPython (1.0.1)
imagesize (0.7.1)
Jinja2 (2.9.6)
MarkupSafe (1.0)
pip (9.0.1)
pyang (1.6)
Pygments (2.2.0)
pytz (2017.2)
rstr (2.2.6)
setuptools (36.2.7)
six (1.10.0)
smmap (0.9.0)
snowballstemmer (1.2.1)
Sphinx (1.4a1)
sphinx-rtd-theme (0.1.9)
wheel (0.29.0)
I can generate the CORE with /generate.py --python --core
But when I want to install it, it fails:
(py2) rob@ubuntu:ydk-gen$ pip install gen-api/python/ydk/dist/ydk*.tar.gz
Processing ./gen-api/python/ydk/dist/ydk-0.6.0.tar.gz
Collecting pybind11>=2.1.1 (from ydk==0.6.0)
  Using cached pybind11-2.1.1-py2.py3-none-any.whl
Building wheels for collected packages: ydk
[b]  Running setup.py bdist_wheel for ydk ... error[/b]
  Complete output from command /home/rob/.virtualenvs/py2/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-W4OeBF-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpWKtY0Ypip-wheel- --python-tag cp27:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-x86_64-2.7
  creating build/lib.linux-x86_64-2.7/ydk
  copying ydk/__init__.py -> build/lib.linux-x86_64-2.7/ydk
  copying ydk/exthook.py -> build/lib.linux-x86_64-2.7/ydk
  creating build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/__init__.py -> build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/codec_service.py -> build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/executor_service.py -> build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/netconf_service.py -> build/lib.linux-x86_64-2.7/ydk/services
  copying ydk/services/crud_service.py -> build/lib.linux-x86_64-2.7/ydk/services
  creating build/lib.linux-x86_64-2.7/ydk/ext
  copying ydk/ext/__init__.py -> build/lib.linux-x86_64-2.7/ydk/ext
  creating build/lib.linux-x86_64-2.7/ydk/errors
  copying ydk/errors/__init__.py -> build/lib.linux-x86_64-2.7/ydk/errors
  copying ydk/errors/error_handler.py -> build/lib.linux-x86_64-2.7/ydk/errors
  creating build/lib.linux-x86_64-2.7/ydk/logging
  copying ydk/logging/__init__.py -> build/lib.linux-x86_64-2.7/ydk/logging
  creating build/lib.linux-x86_64-2.7/ydk/types
  copying ydk/types/__init__.py -> build/lib.linux-x86_64-2.7/ydk/types
  copying ydk/types/py_types.py -> build/lib.linux-x86_64-2.7/ydk/types
  creating build/lib.linux-x86_64-2.7/ydk/filters
  copying ydk/filters/__init__.py -> build/lib.linux-x86_64-2.7/ydk/filters
  creating build/lib.linux-x86_64-2.7/ydk/models
  copying ydk/models/__init__.py -> build/lib.linux-x86_64-2.7/ydk/models
  creating build/lib.linux-x86_64-2.7/ydk/entity_utils
  copying ydk/entity_utils/__init__.py -> build/lib.linux-x86_64-2.7/ydk/entity_utils
  creating build/lib.linux-x86_64-2.7/ydk/providers
  copying ydk/providers/__init__.py -> build/lib.linux-x86_64-2.7/ydk/providers
  copying ydk/providers/codec_provider.py -> build/lib.linux-x86_64-2.7/ydk/providers
  creating build/lib.linux-x86_64-2.7/ydk/path
  copying ydk/path/__init__.py -> build/lib.linux-x86_64-2.7/ydk/path
  creating build/lib.linux-x86_64-2.7/ydk/path/sessions
  copying ydk/path/sessions/__init__.py -> build/lib.linux-x86_64-2.7/ydk/path/sessions
  copying ydk/path/sessions/netconf_session.py -> build/lib.linux-x86_64-2.7/ydk/path/sessions
  copying ydk/path/sessions/restconf_session.py -> build/lib.linux-x86_64-2.7/ydk/path/sessions
  running build_ext
  Installing collected packages: pybind11
  Successfully installed pybind11-2.1.1
  -- The C compiler identification is GNU 5.4.0
  -- The CXX compiler identification is GNU 5.4.0
  -- Check for working C compiler: /usr/bin/cc
  -- Check for working C compiler: /usr/bin/cc -- works
  -- Detecting C compiler ABI info
  -- Detecting C compiler ABI info - done
  -- Detecting C compile features
  -- Detecting C compile features - done
  -- Check for working CXX compiler: /usr/bin/c++
  -- Check for working CXX compiler: /usr/bin/c++ -- works
  -- Detecting CXX compiler ABI info
  -- Detecting CXX compiler ABI info - done
  -- Detecting CXX compile features
  -- Detecting CXX compile features - done
  python library: /usr/lib/python2.7/config-x86_64-linux-gnu/libpython2.7.so
  python include: /usr/include/python2.7
  pybind11 include: /home/rob/.virtualenvs/py2/include/site/python2.7;/home/rob/.virtualenvs/py2/include/site/python2.7
  -- Configuring done
  -- Generating done
  -- Build files have been written to: /tmp/pip-W4OeBF-build/build/temp.linux-x86_64-2.7
  Scanning dependencies of target ydk_
  [ 50%] Building CXX object CMakeFiles/ydk_.dir/python.cpp.o
  /tmp/pip-W4OeBF-build/python.cpp:22:35: fatal error: ydk/restconf_client.hpp: No such file or directory
  compilation terminated.
  CMakeFiles/ydk_.dir/build.make:62: recipe for target 'CMakeFiles/ydk_.dir/python.cpp.o' failed
  make[2]: *** [CMakeFiles/ydk_.dir/python.cpp.o] Error 1
  CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/ydk_.dir/all' failed
  make[1]: *** [CMakeFiles/ydk_.dir/all] Error 2
  Makefile:83: recipe for target 'all' failed
  make: *** [all] Error 2
  Traceback (most recent call last):
    File "<string>", line 1, in <module>
    File "/tmp/pip-W4OeBF-build/setup.py", line 157, in <module>
      zip_safe=False,
    File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
      dist.run_commands()
    File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
      self.run_command(cmd)
    File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
      cmd_obj.run()
    File "/home/rob/.virtualenvs/py2/local/lib/python2.7/site-packages/wheel/bdist_wheel.py", line 179, in run
      self.run_command('build')
    File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
      self.distribution.run_command(command)
      cmd_obj.run()
    File "/usr/lib/python2.7/distutils/command/build.py", line 128, in run
      self.run_command(cmd_name)
      cmd_obj.run()
    File "/tmp/pip-W4OeBF-build/setup.py", line 69, in run
      self.build_extension(ext)
    File "/tmp/pip-W4OeBF-build/setup.py", line 94, in build_extension
      subprocess.check_call(['cmake', '--build', '.'], cwd=self.build_temp)
    File "/usr/lib/python2.7/subprocess.py", line 541, in check_call
      raise CalledProcessError(retcode, cmd)
  subprocess.CalledProcessError: Command '['cmake', '--build', '.']' returned non-zero exit status 2
  Failed building wheel for ydk
  Running setup.py clean for ydk
Failed to build ydk
Installing collected packages: pybind11, ydk
  Running setup.py install for ydk ... error
    Complete output from command /home/rob/.virtualenvs/py2/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-W4OeBF-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-jD4xpB-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/rob/.virtualenvs/py2/include/site/python2.7/ydk:
    running install
    running build
    running build_py
    creating build
    running build_ext
    -- Configuring done
    -- Generating done
        zip_safe=False,
        dist.run_commands()
        cmd_obj.run()
      File "/home/rob/.virtualenvs/py2/local/lib/python2.7/site-packages/setuptools/command/install.py", line 61, in run
        return orig.install.run(self)
      File "/usr/lib/python2.7/distutils/command/install.py", line 601, in run
        cmd_obj.run()
        cmd_obj.run()
[b]Command "/home/rob/.virtualenvs/py2/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-W4OeBF-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-jD4xpB-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/rob/.virtualenvs/py2/include/site/python2.7/ydk" failed with error code 1 in /tmp/pip-W4OeBF-build/[/b]
1 ACCEPTED SOLUTION
The other option could be if you are trying to build from source off the latest master, you cannot use the prebuilt binary (libydk) to satisfy the system dependency. You'd need to first build libydk from source and install it, then install the python core.
./generate.py --cpp --core
cd gen-api/cpp/ydk/build && make && sudo make install
cd -
./generate.py --python --core
16 REPLIES 16
abhirame
Have you installed the system requirements?
GitHub - CiscoDevNet/ydk-gen: Generate model-driven APIs from YANG models
cd -
Thank you for your suggestions.
In order to install it, I had to install cmake v3.8. Also I had to change the generate.py file so it uses clang++-3.8 and clang-3.8.
Afterwards I managed to run your code succesfully.
Then I configured this: ./generate.py --python --bundle profiles/bundles/cisco-ios-xe_16_5_1.json -v
It worked, but on the last line I saw:
Parsing file /home/test/ydk-gen//gen-api/.cache/models/cisco_ios_xe@16.5.1/CISCO-IPSEC-MIB.yang. Module name: CISCO-IPSEC-MIB. Revision: None
Parsing file /home/test/ydk-gen//gen-api/.cache/models/cisco_ios_xe@16.5.1/MPLS-LDP-STD-MIB.yang. Module name: MPLS-LDP-STD-MIB. Revision: None
Parsing file /home/test/ydk-gen//gen-api/.cache/models/cisco_ios_xe@16.5.1/Cisco-IOS-XE-wccp.yang. Module name: Cisco-IOS-XE-wccp. Revision: None
Parsing file /home/test/ydk-gen//gen-api/.cache/models/cisco_ios_xe@16.5.1/MPLS-TC-STD-MIB.yang. Module name: MPLS-TC-STD-MIB. Revision: None
Parsing file /home/test/ydk-gen//gen-api/.cache/models/cisco_ios_xe@16.5.1/CISCO-CONTEXT-MAPPING-MIB.yang. Module name: CISCO-CONTEXT-MAPPING-MIB. Revision: None
Parsing file /home/test/ydk-gen//gen-api/.cache/models/cisco_ios_xe@16.5.1/CISCO-SESS-BORDER-CTRLR-STATS-MIB.yang. Module name: CISCO-SESS-BORDER-CTRLR-STATS-MIB. Revision: None
Killed
I don't know if Killed is a good thing?
But now, when I want to install ydk-0.6.0.tar.gz , I get the same error.
(py2) test@ubuntu:~/ydk-gen/gen-api/python/ydk/dist$ pip install ydk-0.6.0.tar.gz
Processing ./ydk-0.6.0.tar.gz
Requirement already satisfied: pybind11>=2.1.1 in /home/test/.virtualenvs/py2/lib/python2.7/site-packages (from ydk==0.6.0)
  Complete output from command /home/test/.virtualenvs/py2/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-qfogy6-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmplGl84wpip-wheel- --python-tag cp27:
  running bdist_wheel
  running build
  running build_py
  creating build
  running build_ext
  -- Check for working C compiler: /usr/bin/gcc
  -- Check for working C compiler: /usr/bin/gcc -- works
  pybind11 include: /home/test/.virtualenvs/py2/include/site/python2.7;/home/test/.virtualenvs/py2/include/site/python2.7
  -- Configuring done
  -- Generating done
  -- Build files have been written to: /tmp/pip-qfogy6-build/build/temp.linux-x86_64-2.7
  /tmp/pip-qfogy6-build/python.cpp:600:135: warning: unused parameter ‘port’ [-Wunused-parameter]
              [](ydk::NetconfServiceProvider &nc_provider, const string& address, const string& username, const string& password, void* port, const string& protocol, bool on_demand, bool common_cache) {
  c++: internal compiler error: Killed (program cc1plus)
  Please submit a full bug report,
  with preprocessed source if appropriate.
  See <file:///usr/share/doc/gcc-5/README.Bugs> for instructions.
  make[2]: *** [CMakeFiles/ydk_.dir/python.cpp.o] Error 4
    File "/tmp/pip-qfogy6-build/setup.py", line 157, in <module>
      zip_safe=False,
      dist.run_commands()
      cmd_obj.run()
    File "/home/test/.virtualenvs/py2/local/lib/python2.7/site-packages/wheel/bdist_wheel.py", line 179, in run
      cmd_obj.run()
      cmd_obj.run()
    File "/tmp/pip-qfogy6-build/setup.py", line 69, in run
    File "/tmp/pip-qfogy6-build/setup.py", line 94, in build_extension
Failed to build ydk
Installing collected packages: ydk
    Complete output from command /home/test/.virtualenvs/py2/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-qfogy6-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-aONghA-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/test/.virtualenvs/py2/include/site/python2.7/ydk:
    running install
    running build
    running build_py
    creating build
    running build_ext
    -- Configuring done
    -- Generating done
        zip_safe=False,
        dist.run_commands()
        cmd_obj.run()
      File "/home/test/.virtualenvs/py2/local/lib/python2.7/site-packages/setuptools/command/install.py", line 61, in run
        cmd_obj.run()
        cmd_obj.run()
Command "/home/test/.virtualenvs/py2/bin/python2.7 -u -c "import setuptools, tokenize;__file__='/tmp/pip-qfogy6-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-aONghA-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/test/.virtualenvs/py2/include/site/python2.7/ydk" failed with error code 1 in /tmp/pip-qfogy6-build/
I just did run v0.55 and it worked without any problems.
I have come across this error previously if the compiler runs out of memory for example when compiling extremely large files. I'm not sure why you are seeing this.
Is there a specific reason you are using the generator tool (ydk-gen) to install YDK?
If not, can you try the quick install of prebuilt ydk-py package as documented here?
Yes I think you're right. My knowledge is growing
Chicken and the egg problem.
But now I managed to get everything up and running
Glad it worked!
test1239
I am getting below error while installing ydk
    pybind11 include: /root/nacm/nacm_env/include/site/python3.4;/root/nacm/nacm_env/include/site/python3.4
    CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
    Please set them or make sure they are set and tested correctly in the CMake files:
    curl_location
        linked by target "ydk_" in directory /tmp/pip-build-kp_4zvyy/ydk
    xml2_location
    xslt_location
    ydk_location
    -- Configuring incomplete, errors occurred!
    See also "/tmp/pip-build-kp_4zvyy/ydk/build/temp.linux-x86_64-3.4/CMakeFiles/CMakeOutput.log".
Can you provide some details about your OS? Are you following the instructions here to install the system requirements?
we are using CentOS Linux release 7.3.1611 (Core) .
We installed all packages mentioned  in that document.
[root@bgl-netconf ~]# yum install epel-release libssh-devel gcc-c++
Loaded plugins: fastestmirror, langpacks, priorities
Loading mirror speeds from cached hostfile
* base: mirror.dhakacom.com
* epel: epel.scopesky.iq
* extras: mirror.dhakacom.com
* updates: mirror.dhakacom.com
Package epel-release-7-10.noarch already installed and latest version
Package libssh-devel-0.7.1-2.el7.x86_64 already installed and latest version
Package gcc-c++-4.8.5-11.el7.x86_64 already installed and latest version
[root@bgl-netconf ~]# yum install https://devhub.cisco.com/artifactory/rpm-ydk/0.6.0/libydk-0.6.0-1.x86_64.rpm
libydk-0.6.0-1.x86_64.rpm        | 1.0 MB  00:00:07
Examining /var/tmp/yum-root-zPki5O/libydk-0.6.0-1.x86_64.rpm: libydk-0.6.0-1.x86_64
/var/tmp/yum-root-zPki5O/libydk-0.6.0-1.x86_64.rpm: does not update installed package.
Then after we got below error.
(cafy_env) [skopperl@bgl-netconf ~]$ pip install ydk==0.6.0
Collecting ydk==0.6.0
  Using cached ydk-0.6.0.tar.gz
Requirement already satisfied: pybind11>=2.1.1 in ./cafy_env/lib/python3.6/site-packages (from ydk==0.6.0)
  Found existing installation: ydk 0.5.5
    Uninstalling ydk-0.5.5:
      Successfully uninstalled ydk-0.5.5
    Complete output from command /users/skopperl/cafy_env/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-uotkxcx1/ydk/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-1ib6x8ws-record/install-record.txt --single-version-externally-managed --compile --install-headers /users/skopperl/cafy_env/include/site/python3.6/ydk:
    /users/skopperl/cafy_env/lib/python3.6/site-packages/setuptools/version.py:1: UserWarning: Module ydk was already imported from None, but /tmp/pip-build-uotkxcx1/ydk is being added to sys.path
      import pkg_resources
    running install
    running build
    running build_py
    creating build
    creating build/lib.linux-x86_64-3.6
    creating build/lib.linux-x86_64-3.6/ydk
    copying ydk/__init__.py -> build/lib.linux-x86_64-3.6/ydk
    copying ydk/exthook.py -> build/lib.linux-x86_64-3.6/ydk
    creating build/lib.linux-x86_64-3.6/ydk/entity_utils
    copying ydk/entity_utils/__init__.py -> build/lib.linux-x86_64-3.6/ydk/entity_utils
    creating build/lib.linux-x86_64-3.6/ydk/errors
    copying ydk/errors/__init__.py -> build/lib.linux-x86_64-3.6/ydk/errors
    copying ydk/errors/error_handler.py -> build/lib.linux-x86_64-3.6/ydk/errors
    creating build/lib.linux-x86_64-3.6/ydk/ext
    copying ydk/ext/__init__.py -> build/lib.linux-x86_64-3.6/ydk/ext
    creating build/lib.linux-x86_64-3.6/ydk/filters
    copying ydk/filters/__init__.py -> build/lib.linux-x86_64-3.6/ydk/filters
    creating build/lib.linux-x86_64-3.6/ydk/logging
    copying ydk/logging/__init__.py -> build/lib.linux-x86_64-3.6/ydk/logging
    creating build/lib.linux-x86_64-3.6/ydk/models
    copying ydk/models/__init__.py -> build/lib.linux-x86_64-3.6/ydk/models
    creating build/lib.linux-x86_64-3.6/ydk/path
    copying ydk/path/__init__.py -> build/lib.linux-x86_64-3.6/ydk/path
    creating build/lib.linux-x86_64-3.6/ydk/providers
    copying ydk/providers/__init__.py -> build/lib.linux-x86_64-3.6/ydk/providers
    copying ydk/providers/codec_provider.py -> build/lib.linux-x86_64-3.6/ydk/providers
    creating build/lib.linux-x86_64-3.6/ydk/services
    copying ydk/services/__init__.py -> build/lib.linux-x86_64-3.6/ydk/services
    copying ydk/services/codec_service.py -> build/lib.linux-x86_64-3.6/ydk/services
    copying ydk/services/crud_service.py -> build/lib.linux-x86_64-3.6/ydk/services
    copying ydk/services/executor_service.py -> build/lib.linux-x86_64-3.6/ydk/services
    copying ydk/services/netconf_service.py -> build/lib.linux-x86_64-3.6/ydk/services
    creating build/lib.linux-x86_64-3.6/ydk/types
    copying ydk/types/__init__.py -> build/lib.linux-x86_64-3.6/ydk/types
    copying ydk/types/py_types.py -> build/lib.linux-x86_64-3.6/ydk/types
    running build_ext
    -- The C compiler identification is GNU 4.8.5
    -- The CXX compiler identification is GNU 4.8.5
    python library: /usr/local/lib/python3.6/config-3.6m-x86_64-linux-gnu/libpython3.6m.a
    python include: /usr/local/include/python3.6m
    pybind11 include: /users/skopperl/cafy_env/include/site/python3.6;/users/skopperl/cafy_env/include/site/python3.6
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /tmp/pip-build-uotkxcx1/ydk/build/temp.linux-x86_64-3.6
    /tmp/pip-build-uotkxcx1/ydk/python.cpp:551:198: warning: unused parameter ���port��� [-Wunused-parameter]
    [100%] Linking CXX shared module ../lib.linux-x86_64-3.6/ydk_.so
    /usr/bin/ld: /usr/local/lib/python3.6/config-3.6m-x86_64-linux-gnu/libpython3.6m.a(abstract.o): relocation R_X86_64_32S against `_Py_NotImplementedStruct' can not be used when making a shared object; recompile with -fPIC
    /usr/local/lib/python3.6/config-3.6m-x86_64-linux-gnu/libpython3.6m.a: error adding symbols: Bad value
    collect2: error: ld returned 1 exit status
    gmake[2]: *** [../lib.linux-x86_64-3.6/ydk_.so] Error 1
    gmake[1]: *** [CMakeFiles/ydk_.dir/all] Error 2
    gmake: *** [all] Error 2
      File "/tmp/pip-build-uotkxcx1/ydk/setup.py", line 157, in <module>
        zip_safe=False,
      File "/usr/local/lib/python3.6/distutils/core.py", line 148, in setup
        dist.run_commands()
      File "/usr/local/lib/python3.6/distutils/dist.py", line 955, in run_commands
      File "/usr/local/lib/python3.6/distutils/dist.py", line 974, in run_command
        cmd_obj.run()
      File "/users/skopperl/cafy_env/lib/python3.6/site-packages/setuptools/command/install.py", line 61, in run
      File "/usr/local/lib/python3.6/distutils/command/install.py", line 545, in run
      File "/usr/local/lib/python3.6/distutils/cmd.py", line 313, in run_command
        cmd_obj.run()
      File "/usr/local/lib/python3.6/distutils/command/build.py", line 135, in run
        cmd_obj.run()
      File "/tmp/pip-build-uotkxcx1/ydk/setup.py", line 69, in run
      File "/tmp/pip-build-uotkxcx1/ydk/setup.py", line 94, in build_extension
      File "/usr/local/lib/python3.6/subprocess.py", line 291, in check_call
    subprocess.CalledProcessError: Command '['cmake', '--build', '.']' returned non-zero exit status 2.
Sivananda
Thanks! Just googling this error shows this solution: python - Relocation R_X86_64_32S against '_Py_NotImplementedStruct' can not be used when making a shared object; recompi…
Can you let me know if this works for you?
gjaimes
Contributor
Same problem here :
u
buntu@ubuntu-xenial:/$ pip install ydk-models-cisco-ios-xr
Collecting ydk-models-cisco-ios-xr
  Downloading ydk_models_cisco_ios_xr-6.3.1-py2.py3-none-any.whl (19.9MB)
    100% |████████████████████████████████| 19.9MB 39kB/s
Collecting ydk-models-ietf>=0.1.3 (from ydk-models-cisco-ios-xr)
  Downloading ydk_models_ietf-0.1.4-py2.py3-none-any.whl (232kB)
    100% |████████████████████████████████| 235kB 364kB/s
Collecting ydk>=0.6.1 (from ydk-models-cisco-ios-xr)
  Downloading ydk-0.6.1.tar.gz
Collecting pybind11>=2.1.1 (from ydk>=0.6.1->ydk-models-cisco-ios-xr)
  Downloading pybind11-2.2.1-py2.py3-none-any.whl (143kB)
    100% |████████████████████████████████| 153kB 545kB/s
  Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-iYTs2_/ydk/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpNwpuFXpip-wheel- --python-tag cp27:
  running bdist_wheel
  running build
  running build_py
  creating build
  running build_ext
    File "/tmp/pip-build-iYTs2_/ydk/setup.py", line 157, in <module>
      zip_safe=False,
      dist.run_commands()
      cmd_obj.run()
    File "/usr/lib/python2.7/dist-packages/wheel/bdist_wheel.py", line 179, in run
      cmd_obj.run()
      cmd_obj.run()
    File "/tmp/pip-build-iYTs2_/ydk/setup.py", line 66, in run
      ", ".join(e.name for e in self.extensions))
  RuntimeError: CMake must be installed to build the following extensions: ydk_
Failed to build ydk
Installing collected packages: pybind11, ydk, ydk-models-ietf, ydk-models-cisco-ios-xr
Exception:
  File "/home/ubuntu/.local/lib/python2.7/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/home/ubuntu/.local/lib/python2.7/site-packages/pip/commands/install.py", line 342, in run
    prefix=options.prefix_path,
  File "/home/ubuntu/.local/lib/python2.7/site-packages/pip/req/req_set.py", line 784, in install
    **kwargs
  File "/home/ubuntu/.local/lib/python2.7/site-packages/pip/req/req_install.py", line 851, in install
    self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
  File "/home/ubuntu/.local/lib/python2.7/site-packages/pip/req/req_install.py", line 1064, in move_wheel_files
    isolated=self.isolated,
  File "/home/ubuntu/.local/lib/python2.7/site-packages/pip/wheel.py", line 345, in move_wheel_files
    clobber(source, lib_dir, True)
  File "/home/ubuntu/.local/lib/python2.7/site-packages/pip/wheel.py", line 316, in clobber
    ensure_dir(destdir)
  File "/home/ubuntu/.local/lib/python2.7/site-packages/pip/utils/__init__.py", line 83, in ensure_dir
    os.makedirs(path)
  File "/usr/lib/python2.7/os.py", line 157, in makedirs
    mkdir(name, mode)
OSError: [Errno 13] Permission denied: '/usr/local/lib/python2.7/dist-packages/pybind11-2.2.1.dist-info'
ubuntu@ubuntu-xenial:/$
Any help ?
Make sure you install libydk_0.6.1-1_amd64.deb.  If you're not installing in a Python virtual environment, you typically need to install your python packages as root.  See documentation at:
http://ydk.cisco.com/py/docs/getting_started.html#system-requirements
Thanks for the reply. But still having same errror, already tried under virtual environment. Can you please provide exact commands for  manual installation of libydk.
Content for Community-Ad
