09-22-2020 02:12 AM
Hi!
I am trying to retrieve information from a cisco XR device.
I want the information on the interfaces.
The code i am running:
service = NetconfService() provider = NetconfServiceProvider(address=ip_address, username=user_name, password=password) model = test.InterfaceProperties.DataNodes.DataNode.SystemView.Interfaces.Interface() interfaceFilter = test.InterfaceProperties.DataNodes.DataNode.SystemView.Interfaces.Interface.interface interfaceFilter.interface_name = "Gi0/0/0/1" model.interface.append(interfaceFilter) interface = service.get(provider=provider, read_filter=interfaceFilter) print(interface)
The output i am getting:
interfaceFilter = test.InterfaceProperties.DataNodes.DataNode.SystemView.Interfaces.Interface.interface AttributeError: type object 'Interface' has no attribute 'interface'
Imports:
import ydk.models.cisco_ios_xr.Cisco_IOS_XR_ifmgr_oper as test from ydk.services.netconf_service import NetconfService from ydk.providers.netconf_provider import NetconfServiceProvider
May one of you be so kind as to give me any hints on how I can proceed to get around this issue?
Solved! Go to Solution.
09-23-2020 12:55 PM
To better understand data hierarchy you could try to get properties for all interfaces. Here is my example for CiscoDevNet XR sandbox:
#!/usr/bin/env python
import logging
log_ydk = logging.getLogger('ydk')
log_ydk.setLevel(logging.INFO)
handler = logging.StreamHandler()
log_ydk.addHandler(handler)
if __name__ == "__main__":
provider = NetconfServiceProvider(address="sbx-iosxr-mgmt.cisco.com",
port=10000,
username="admin",
password="C1sco12345")
all_ifcs = test.InterfaceProperties()
service.get(provider, all_ifcs)
I am getting the following (truncated due to long output):
ygorelik$ ./xr_interface_properties.py
Path where models are to be downloaded: /Users/ygorelik/.ydk/sbx-iosxr-mgmt.cisco.com
Connected to sbx-iosxr-mgmt.cisco.com on port 10000 using ssh with timeout of -1
Executing 'get' RPC on [Cisco-IOS-XR-ifmgr-oper:interface-properties]
============= Sending RPC to device =============
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><get xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<filter><interface-properties xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-oper"/></filter>
</get>
</rpc>
============= Received RPC from device =============
<?xml version="1.0"?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="4">
<data>
<interface-properties xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-oper">
<data-nodes>
<data-node>
<data-node-name>0/RP0/CPU0</data-node-name>
<locationviews>
<locationview>
<locationview-name>0/0/CPU0</locationview-name>
<interfaces>
<interface>
<interface>
<interface-name>GigabitEthernet0/0/0/0</interface-name>
<interface>GigabitEthernet0/0/0/0</interface>
<type>IFT_GETHERNET</type>
<state>im-state-admin-down</state>
<actual-state>im-state-admin-down</actual-state>
<line-state>im-state-admin-down</line-state>
<actual-line-state>im-state-admin-down</actual-line-state>
<encapsulation>ether</encapsulation>
<encapsulation-type-string>ARPA</encapsulation-type-string>
<mtu>1514</mtu>
<sub-interface-mtu-overhead>0</sub-interface-mtu-overhead>
<l2-transport>false</l2-transport>
<bandwidth>1000000</bandwidth>
</interface>
<interface>
<interface-name>GigabitEthernet0/0/0/1</interface-name>
<interface>GigabitEthernet0/0/0/1</interface>
<mtu>1514</mtu>
</interface>
</interfaces>
</locationview>
<locationview>
</locationview>
</locationviews>
</data-node>
</data-nodes>
</interface-properties>
</data>
</rpc-reply>
Important to note that data-node, locationview and interface are list elements and have to be handled properly!
Also, the get filter building must always start from the top level container!
Here is an example for getting properties of specific interface:
import logging
port=10000,
username="admin",
my_data_node = test.InterfaceProperties.DataNodes.DataNode()
my_data_node.data_node_name = '0/RP0/CPU0'
all_ifcs.data_nodes.data_node.append(my_data_node)
my_locationview = test.InterfaceProperties.DataNodes.DataNode.Locationviews.Locationview()
my_locationview.locationview_name = '0/RP0/CPU0'
my_data_node.locationviews.locationview.append(my_locationview)
my_ifc = test.InterfaceProperties.DataNodes.DataNode.Locationviews.Locationview.Interfaces.Interface()
my_ifc.interface_name = 'GigabitEthernet0/0/0/0'
my_locationview.interfaces.interface.append(my_ifc)
my_ifc_props = service.get(provider, my_ifc)
And results:
<filter><interface-properties xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-oper">
<data-nodes>
<data-node>
<locationviews>
<locationview>
<locationview-name>0/RP0/CPU0</locationview-name>
<interfaces>
<interface>
</interface>
</interfaces>
</locationview>
</locationviews>
</data-node>
</data-nodes>
</interface-properties></filter>
</get>
</rpc>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="1">
<data>
<data-nodes>
<data-node>
<locationviews>
<locationview>
<interfaces>
<interface>
<mtu>1514</mtu>
</interface>
</interfaces>
</locationview>
</locationviews>
</data-node>
</data-nodes>
</data>
</rpc-reply>
I hope that helps to understand the basics of building models.
09-22-2020 09:56 AM
These 2 lines do not correspond to the Model API:
Please work with documentation, IOS XR Model API, and hundreds of examples on the web.
09-23-2020 12:28 AM
Good morning yangorelik!
Thank you so much for a reply
I am trying to work with the documentation, but i find it rather limiting and hard to work with. But maybe you have a different documentation than I got.
I have also tried to search the web for examples but i found none that mached my case.
Perhaps you could provide a link to one of your examples? I would be grateful
I am sorry for been such a rookie, I appreciate the time you use for answering me
Kind regards,
Simon Johansen
09-23-2020 12:55 PM
import logging
port=10000,
username="admin",
</get>
</rpc>
<data>
<data-nodes>
<data-node>
<locationviews>
<locationview>
<interfaces>
<interface>
<interface>
<mtu>1514</mtu>
</interface>
<interface>
<mtu>1514</mtu>
</interface>
</interfaces>
</locationview>
<locationview>
</locationview>
</locationviews>
</data-node>
</data-nodes>
</data>
</rpc-reply>
import logging
port=10000,
username="admin",
And results:
<data-nodes>
<data-node>
<locationviews>
<locationview>
<interfaces>
<interface>
</interface>
</interfaces>
</locationview>
</locationviews>
</data-node>
</data-nodes>
</get>
</rpc>
<data>
<data-nodes>
<data-node>
<locationviews>
<locationview>
<interfaces>
<interface>
<mtu>1514</mtu>
</interface>
</interfaces>
</locationview>
</locationviews>
</data-node>
</data-nodes>
</data>
</rpc-reply>
09-24-2020 05:00 AM
Good day yangorelik!
Thank you so much for such a detailed answer
Your solution worked.
I encountered two issues after implementing your example:
The first was to find the "data_node_name". But the IT had the answer.
My data_node_name was: "0/RSP0/CPU0"
The second was that you use non-capital letters when appending and some words are snake case.
When you add models to variabels you use camel case.
Still think the doc and guide in itself is not descriptive enough, but with your helped it went rather fast. Thank you again
Hope you get a lovely day,
Best regards,
Simon Johansen
