09-24-2022 08:42 AM - edited 09-24-2022 07:16 PM
Hi guys we are trying to ship data from an ios xe device to telegraf collector. Platform Cat 9k running 17.6.3
Simple filter paths like cpu utlisation / ip-sla oper data models work without any issues.
We are also trying to ship ip mroute operational data for a particular S,G inside a vrf for a business use case. This data is not being shipped to the telegraf.
the xpath filter we are using is /mroute-ios-xe-oper:mroute-oper-data/mroute-state[vrf=\"xxxx\"][af=\"mroute-af-ipv4\"][source=\"xxxx\"][group=\"xxxx\"]/hw-kbits-per-second
Have anyone had success with the mroute-ios-xe-oper data model.?
The xpath filter says it is valid. and all mandatory leaf parameters have been given . The receiver shows connected in the validation command. Can anyone help?Thanks.
btw i validated the xpath using netconf get request for the particular model through yang-suite and i am getting perfect replies from the device.
@bigevilbeardcan you kindly help or point me towards someone?
09-26-2022 09:49 AM
Your Xpath contains keys vrf, af, source, and group. Yangsuite supports adding keys to the Xpath and builds the correct RPC to send to the device. The rpc-reply from the device gives you the correct values based on the specific RPC sent. For telemetry, I do not think the device supports keys and prefixes in the Xpath filter. You would have to use /mroute-oper-data/mroute-stat/hw-kbits-per-second and then filter out the results in the collector based on vrf, af, source, and group.
09-30-2022 09:24 PM
Thanks for the reply. the suggested xpath would definitely work but would send a huge stream of data to the receiver. I have been using keys as part of xpath in my other use cases such as ip sla etc where i would ship the metric of a particular oper id . But shipping the mroute statistics for all vrf and all sources would become a headache to manage at the collecter end. i am still working on a solution to ship only the metrics of source and group for a particular vrf
10-03-2022 04:49 PM
If the telemetry path configurations you setup on the device support xpath keys for ip-sla, the mroute xpaths must be the issue. I suspect they had not added telemetry support for those by 17.6.3. If possible, try it out on a later release. Might be documented somewhere also.
