Netconf to retrieve ospf configuration using Python
sqambera
I wrote following code to fetch ospf configuration from the CSR router but not able to obtain it. Please see the output. Can anyone please help me know what's wrong?
from xml.dom import minidom
from ncclient import manager
m = manager.connect(host = "10.10.20.48",
port = 830,
username = "developer",
password = "C1sco12345",
hostkey_verify = False)
print(m.connected)
filter_routing = """
<filter>
<ospf xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-ospf">
</ospf>
</filter>
running = m.get_config("running", filter_routing)
running_xml = minidom.parseString(running.xml)
print(running_xml.toprettyxml(indent = " "))
OUTPUT:
C:\Users\Image\PycharmProjects\Netconf\venv\Scripts\python.exe C:/Users/Image/PycharmProjects/Netconf/Routing.py
True
<?xml version="1.0" ?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="urn:uuid:902cbaa2-aea3-4e00-b19a-2278007b50f0">
<data/>
</rpc-reply>
The actual ospf configuration on router is following:
csr1000v-1#sh run | section ospf
router ospf 1
network 172.16.24.0 0.0.0.255 area 0
Attached is the XML output of running configuration.
Qamber
You could also use the native model
        rpc = '''
                <config>
                    <native xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-native">
                        <router>
                            </ospf>
                        </router>
                    </native>
                </config>
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
5 Replies 5
Alex Stevenson
Hello @sqambera,
You are on the right track! Cisco Code Exchange will help you complete the task. I searched there for “ospf, yang, netconf”:
Cisco Code Exchange
Examples found therein:
Of course, you will need to adjust your code, including filtering results for ospf.
        rpc = '''
                <config>
                        <router>
                            </ospf>
                        </router>
                    </native>
                </config>
Hello @sqambera,
I'm running IOS-XR, so things may be different, but I was able to run the following command on the router to determine the available OSPF namespaces
show netconf-yang capabilities | in ospf
Mon Dec  6 19:25:57.698 UTC
http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-ospf-act                               |2016-09-14|
http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-ospf-cfg                               |2018-05-14|
http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-ospf-oper                              |2018-04-18|
http://cisco.com/ns/yang/Cisco-IOS-XR-ipv6-ospfv3-act                             |2016-09-14|
http://cisco.com/ns/yang/Cisco-IOS-XR-ipv6-ospfv3-cfg                             |2018-05-14|
http://cisco.com/ns/yang/Cisco-IOS-XR-ipv6-ospfv3-oper                            |2018-06-15|
After a bit of trial and error, I found that I could produce useful output with the following filter:
<filter>
<ospf xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-ospf-cfg">
</ospf>
</filter>
The following is a portion of the output:
<rpc-reply xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="urn:uuid:f7d22dbd-db09-43b1-b0e9-c43909a359f4">
  <data>
      <processes>
        <process>
          <process-name>10</process-name>
          <nsr>true</nsr>
          <default-vrf>
            <adjacency-changes>detail</adjacency-changes>
Hope this helps!!!
fjm
@ittybittypacket
fracjackmac
Hello@sqambera,
By the way, THANKS for your post!!
This gave me an opportunity to actually take the leap and start exploring netconf in the lab.
fjm
@ittybittypacket
Thank you
