deom
Sample apps for OSPFv3 using XR/gNMI
Related image
Hi YDK Community,
We have added a new set of sample apps for Open Shortest Path First version 3 (OSPFv3) configuration for XR using gNMI.
This set of sample apps configures XR OSPFv3 using the gNMI provider and the CRUD service:
gn-create-xr-ipv6-ospfv3-cfg-10-ydk.py - create boilerplate
gn-create-xr-ipv6-ospfv3-cfg-20-ydk.py - single-area  IPv6 routing
gn-create-xr-ipv6-ospfv3-cfg-30-ydk.py - IPv6 ABR
gn-create-xr-ipv6-ospfv3-cfg-32-ydk.py - IPv6 ABR with stub area
gn-create-xr-ipv6-ospfv3-cfg-34-ydk.py - IPv6 ABR with totally stub area
gn-delete-xr-ipv6-ospfv3-cfg-10-ydk.py - delete boilerplate
gn-delete-xr-ipv6-ospfv3-cfg-20-ydk.py - delete all OSPFv3 configuration
gn-read-xr-ipv6-ospfv3-cfg-10-ydk.py   - read boilerplate
gn-update-xr-ipv6-ospfv3-cfg-10-ydk.py - update boilerplate
You can also see the full shot of OSPFv3/gNMI sample apps in the following link: https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic/crud/gnmi/models/cisco-ios-xr/Cisco-IOS-XR-ipv6-ospfv3-cfg
Why don't you give it a try to run the OSPFv3 sample apps today?
Best,
0 REPLIES 0
Content for Community-Ad
