337
saalvare
Setting the device locale
One of the simplest models you can getting started with is Cisco-IOS-XR-infra-infra-locale-cfg.yang.  It allows you to set the device locale (country and language).  You can find sample apps for this model at:
https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic/ydk/models/infra
Make sure you read the README file for basic apps.  It explains how apps are named and how to run them.
Happy coding!
0 REPLIES 0
Create
Recognize Your Peers
Content for Community-Ad
