Yang module for show bgp ipv4 unicast community
Hi ,
kindly let me know which yang module to find this corresponding cli
RP/0/RP0/CPU0:dedsdf1002jl1#sh bgp ipv4 unicast community 62300:19
Fri May 26 14:33:08.165 EDT
BGP router identifier 10.80.68.69, local AS number 62300
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0xe0000000 RD version: 340402
BGP main routing table version 340402
BGP NSR Initial initsync version 3666 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
  i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
  Network Next Hop Metric LocPrf Weight Path
*>i10.80.68.66/32 10.80.68.66 0 100 0 ?
* i 10.80.68.68 0 100 0 ?
*>i10.80.68.67/32 10.80.68.67 0 100 0 ?
*>i10.80.68.70/32 10.80.68.70 0 100 0 ?
* i 10.80.68.70 0 100 0 ?
*>i10.80.68.71/32 10.80.68.71 0 100 0 ?
* i 10.80.68.71 0 100 0 ?
*>i10.80.68.72/32 10.80.68.72 0 100 0 ?
* i 10.80.68.72 0 100 0 ?
*>i10.80.68.73/32 10.80.68.73 0 100 0 ?
* i 10.80.68.73 0 100 0 ?
We unable to get the same out put when we are using Cisco-ios-xr-ipv4-bgp-oper model
Jay
1 ACCEPTED SOLUTION
Jay,
IOS XR doesn't model show commands in YANG.  So, you won't have an RPC or an operational data model that matches a specific show command.  Instead, you have a BGP operational model that can be seen as the raw data used to implement all BGP show commands.  The YDK api for that model is at:
http://ydk.cisco.com/py/docs/gen_doc_408eed019715fbec66d36658ec93bcefe15e2706.html
You can find sample YDK scripts that use the oper models to implement some show commands at:
ydk-py-samples/samples/basic/crud/models/cisco-ios-xr/Cisco-IOS-XR-clns-isis-oper at master · CiscoDevNet/ydk-py-samples…
I know your goal is not to reproduce show commands, but those samples will shed some light on how data on an oper model can be leveraged to obtain equivalent output to an existing show command.
3 REPLIES 3
Hi ,
Please let us know RPC for this cli
Jay
Thanks for your question. However, this may not be the right forum for BGP-specific questions. You can search through the documentation for the YDK cisco-ios-xr bundle where you may find the data model you are looking for: http://ydk.cisco.com/py/docs/gen_doc_408eed019715fbec66d36658ec93bcefe15e2706.html.
Jay,
Content for Community-Ad
