取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
新手请教思科C9300堆叠怎么插线配置呀
Moer
思科C9300 堆叠连线 和配置
2 条回复2
C9300的堆叠和配置可以参考下如下文档,注意相关限制。
Restrictions for Switch Stacks
The following are restrictions for your switch stack configuration:
  • Only homogenous stacking is supported, that is, a stack of Cisco Catalyst 9300 Series Switches stack with only Cisco Catalyst 9300 Series Switches as stack members.
    Cisco Catalyst 9300L Series Switches stack with only Cisco Catalyst 9300L Series Switches as stack members.
    C9300-24UB, C9300-24UXB, and C9300-48UB switches can only be stacked with each other.
  • During a switchover, when the standby device syncs with the active device, the following log message is displayed on the console:
    %SM-4-BADEVENT: Event 'standby_phy_link_up' is invalid for
    the current state 'NO_NEIGHBOR': rep_lsl_rx Gix/x/x -Traceback=
    Ignore this message. It does not have any functional or operational impact.
  • You cannot have a switch stack containing a mix of different license levels.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-3/configuration_guide/stck_mgr_ha/b_173_stck_mgr_ha_9300_cg/managing_switch_stacks.html
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
快捷链接
